  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Maybe for future version of the gateway would it be possible to add RF-link ? I guess you can still use a rflink by connecting it to a raspberry pi gateway in the normal way but it would be cool to be able to also control 433/868Mhz and Mi-light products from one gateway.
    kalinaK 1 Reply Last reply
      kalinaK
      kalinaK
      kalina
      Actually, not as you think, I'm going to use rflink to control my nodes. Gateway connects directly to the controller (as an example to raspberry pi) via USB, Wi-Fi or Ethernet connection.
      • D
        damsh
        @kalina When are you going to sell your devices? I'm going to buy one or two...
        • D damsh
          kalinaK
          kalinaK
          kalina
          @damsh I can sell MDMSGates already. I have sent to you PM.
          D 1 Reply Last reply
          • kalinaK kalina
            damsh
            @kalina Received gateway and tested it. The gateway is good made and work fine. Thank you!
            I'm using it as serial gateway for no, but late going to use it as MQTT ethernet gateway with Openhab.
            Thank you once more!
            • D damsh
              kalinaK
              kalinaK
              kalina
              Thanks. Nice to hear!
              • MiKaM
                MiKaM
                MiKa
                What is the type of enclosure? some order number?
                THX,
                MiKa
                • MiKaM MiKa
                  THX,
                  MiKa
                  kalinaK
                  kalinaK
                  kalina
                  This type
                  • kalinaK kalina
                    Hi everyone!
                    Today i have completed the development of new design of the enclosure. The sticker is printed on Oracal film.0_1474132068564_New_enclosure.jpg
                    @kalina the box is really beautiful. Perfect for getting a high spouse acceptance factor. Do you print the film yourself? What kind of printer is required?
                      kalinaK
                      kalinaK
                      kalina
                      No, I don't. This sticker is printed by an advertising company.
                      • R
                        R
                        RonnieMace
                        Hello Kalina, I'm new to the whole gateway and sensors world. Can I connect this gateway to a raspberry pi and then use the wifi and 868MHz at the same time? So I can use different types of sensors. Thanks in advance.
                        • P
                          P
                          pointbre
                          Hi Kalina,
                          I've been searching RF gateway with enclosure for Raspberry Pi and your one seems to fit my needs but I'd like to know what kind of library is used for RFM69.
                          Thanks in advance.
                          mfalkviddM kalinaK 2 Replies Last reply
                          • P pointbre
                            Hi Kalina,
                            Thanks in advance.
                            #42
                            Hi @pointbre, welcome to the MySensors community!
                            The library used, well, is MySensors :) https://www.mysensors.org/about/iot is a good place to start
                            P 1 Reply Last reply
                              P
                              P
                              pointbre
                              Hi @mfalkvidd , thanks for your reply. Does that mean that I can plug this MDMSGate into USB port of Raspberry Pi? I would like to use MDMSGate as a RF gateway(based on RFLink firmware, see http://www.nemcon.nl/blog2/), which can commuciate with Node-Red on Raspberry PI via USB serial connection(see https://nodered.org/docs/hardware/arduino).
                              • P pointbre
                                @pointbre no. It does not use the rflink protocol. It uses the MySensors protocol.
                                • P pointbre
                                  Hi Kalina,
                                  Thanks in advance.
                                  kalinaK
                                  kalinaK
                                  kalina
                                  #45
                                  Hi @pointbre, @mfalkvidd is right, MDMSGate uses firmware based on MySensors library by default, but if you look at MDMSGate as a hardware device - you can develop you own firmware. Оf course, you can connect MDMSGate to Raspberry via USB (linux already has drivers for CP2102 chip) or Ethernet.
                                  • R RonnieMace
                                    kalinaK
                                    kalinaK
                                    kalina
                                    #46
                                    @RonnieMace said in 💬 MDMSGate:
                                    Hi @RonnieMace, sorry, but i will answer for your question some later, I want to draw a picture that explains the modes of operation and connection MDMSGate and i need some time. Right now I want to present my new device - MDMSNode "Power"....
                                    • R
                                      R
                                      RonnieMace
                                      Ok thanks. It's just that I wonder if it 's possible to have one sensor via wifi and and an other via 868MHz. I'Il wait for your drawing. TThe gateway looks very nice btw.
                                      • R RonnieMace
                                        kalinaK
                                        kalinaK
                                        kalina
                                        #48
                                        @RonnieMace
                                        USB, Wi-Fi and Ethernet are using only for connection to controller and you can't use it with different types of sensors. Instead this, you can build gateway which you need, just change jumpers position (and if you want to change radio network you have to change radios). I am drawing two examples of using gateway below.
                                        • P
                                          P
                                          pointbre
                                          Hi Kalina,
                                          Do you stocks now? I'd like to give a try with your RF gateway.
