  3. 💬 MDMSGate
💬 MDMSGate
atsha204amysensors gatewayesp8266ethernetmysensorsgatewaynrf24l01usbatmega328rfm69
82 Posts 22 Posters 42.5k Views 25 Watching
  • MiKaM
    MiKaM
    MiKa
    What is the type of enclosure? some order number?
    THX,
    MiKa
    kalinaK 1 Reply Last reply
    • MiKaM MiKa
      THX,
      MiKa
      kalinaK
      kalinaK
      kalina
      This type
      • kalinaK kalina
        Hi everyone!
        Today i have completed the development of new design of the enclosure. The sticker is printed on Oracal film.0_1474132068564_New_enclosure.jpg
        @kalina the box is really beautiful. Perfect for getting a high spouse acceptance factor. Do you print the film yourself? What kind of printer is required?
          kalinaK
          kalinaK
          kalina
          No, I don't. This sticker is printed by an advertising company.
          • R
            R
            RonnieMace
            Hello Kalina, I'm new to the whole gateway and sensors world. Can I connect this gateway to a raspberry pi and then use the wifi and 868MHz at the same time? So I can use different types of sensors. Thanks in advance.
            • P
              P
              pointbre
              Hi Kalina,
              I've been searching RF gateway with enclosure for Raspberry Pi and your one seems to fit my needs but I'd like to know what kind of library is used for RFM69.
              Thanks in advance.
              mfalkviddM kalinaK 2 Replies Last reply
              • P pointbre
                Hi Kalina,
                Thanks in advance.
                #42
                Hi @pointbre, welcome to the MySensors community!
                The library used, well, is MySensors :) https://www.mysensors.org/about/iot is a good place to start
                P 1 Reply Last reply
                  P
                  P
                  pointbre
                  Hi @mfalkvidd , thanks for your reply. Does that mean that I can plug this MDMSGate into USB port of Raspberry Pi? I would like to use MDMSGate as a RF gateway(based on RFLink firmware, see http://www.nemcon.nl/blog2/), which can commuciate with Node-Red on Raspberry PI via USB serial connection(see https://nodered.org/docs/hardware/arduino).
                  • P pointbre
                    @pointbre no. It does not use the rflink protocol. It uses the MySensors protocol.
                    • P pointbre
                      Hi Kalina,
                      Thanks in advance.
                      kalinaK
                      kalinaK
                      kalina
                      #45
                      Hi @pointbre, @mfalkvidd is right, MDMSGate uses firmware based on MySensors library by default, but if you look at MDMSGate as a hardware device - you can develop you own firmware. Оf course, you can connect MDMSGate to Raspberry via USB (linux already has drivers for CP2102 chip) or Ethernet.
                      • R RonnieMace
                        kalinaK
                        kalinaK
                        kalina
                        #46
                        @RonnieMace said in 💬 MDMSGate:
                        Hi @RonnieMace, sorry, but i will answer for your question some later, I want to draw a picture that explains the modes of operation and connection MDMSGate and i need some time. Right now I want to present my new device - MDMSNode "Power"....
                        • R
                          R
                          RonnieMace
                          Ok thanks. It's just that I wonder if it 's possible to have one sensor via wifi and and an other via 868MHz. I'Il wait for your drawing. TThe gateway looks very nice btw.
                          • R RonnieMace
                            kalinaK
                            kalinaK
                            kalina
                            #48
                            @RonnieMace
                            USB, Wi-Fi and Ethernet are using only for connection to controller and you can't use it with different types of sensors. Instead this, you can build gateway which you need, just change jumpers position (and if you want to change radio network you have to change radios). I am drawing two examples of using gateway below.
                            • P
                              P
                              pointbre
                              Hi Kalina,
                              Do you stocks now? I'd like to give a try with your RF gateway.
                              • P pointbre
                                Hi Kalina,
                                kalinaK
                                kalinaK
                                kalina
                                #50
                                @pointbre Yes, you can buy MDMSGate by this link. But keep in mind, that NRF24 radio soldered in MDMSGate. If you need RFM69 you have to inform about this and pay additional 2.5$ (because RFM69 more expensive).
                                • R
                                  R
                                  RonnieMace
                                  Thanks for the drawing. I understand that the gateway uses or wifi or 868MHz. If I want both I need 2 gateways and connect them to the raspberry controller. Is my assumption correct?
                                  • R RonnieMace
                                    kalinaK
                                    kalinaK
                                    kalina
                                    You can use Wi-Fi and 868MHz at the same time, but Wi-Fi is intended for connection to controller only!!! 868MHz is intended for connection to different types of sensors or actuators. You can't establish a connection to any types of sensors via Wi-Fi.
                                    No.
                                    • P
                                      P
                                      pointbre
                                      HI Kalina, Would you please let me know how I could pay the extra $2.5 for RFM69 module? I'd like to make a purchase today.
                                      • P pointbre
                                        kalinaK
                                        kalinaK
                                        kalina
                                        @pointbre Hi, i am sending to you a PM. Check it pls in a few minutes...
                                        • fisherF
                                          fisherF
                                          fisher
                                          Hi @kalina:
                                          Is it possible to buy board only without plastic enclosure?
