  3. NRF24L01+PA+LNA distance problem
25 Posts 6 Posters 12.7k Views 6 Watching
  • F flopp
    @yd-kim
    Check that you have correct antenna.
    I was using female antenna and the nRF was also female which resulted in very bad connection.
    Nodes are not battery powered?
    yd kimY
    yd kimY
    yd kim
    @flopp
    At the first time I use default antenna but it was same issue so I bought exactly same long antenna. It make a little bit better but not perfect..
    I knew what you are talking about. It wasn't normal so a little bit expensive compare to normal wifi antenna.
    Thank for your concern.
    • F flopp
      @yd-kim
      yd kimY
      yd kimY
      yd kim
      @flopp
      Whole system is Li-Ion battery powered system with solar.
      Gateway has 3S2P Li-Ion battery with proper solar panel. Battery voltage never go under 11V.
      Node has 1x18650 Li-Ion battery with small solar panel.
      Node goes sleep mode for 10 minutes then wake up and send data within 10 second.
      F 1 Reply Last reply
      • MiKaM MiKa
        Also check with RF scanner if its not a "jamming" from other RF device, or simply try to change channel to different one.
        yd kimY
        yd kimY
        yd kim
        @MiKa
        Device is installed in rural area. There is only one wifi. I don't think there is jamming or interference..
        I don't have RF scanner. If I couldn't find any other solution , probably I need to build RF scanner to check it..
        • yd kimY yd kim
          @MiKa
          @yd-kim https://www.mysensors.org/controller/sniffer might be an easy way if you want to scan.
          • F
            F
            fleinze
            Sometimes we get shitty modules from china:
            https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
            I made good experiance with these rather expensive ones:
            https://de.aliexpress.com/item/2pcs-RF2401F20-2-4G-high-integrated-RF-module-with-Nordic-s-RF-chip-nRF24L01-For-Free/32302870943.html
            But even with these I had to be very careful about antenna placement
            yd kimY 1 Reply Last reply
            • MiKaM
              MiKaM
              MiKa
              Another RF scanner with mini OLED 0.96 display
              https://www.rcgroups.com/forums/showthread.php?2777178-Very-cheap-Arduino-based-2-4-GHz-band-monitor
              • yd kimY yd kim
                @flopp
                F
                F
                flopp
                @yd-kim said:
                @flopp
                What kind of Arduino do you use?
                • F flopp
                  @yd-kim said:
                  @flopp
                  yd kimY
                  yd kimY
                  yd kim
                  @flopp
                  Gateway : ESP8266 ( use 3A switching step down power module)
                  Node : Arduino pro mini 3V ( Arduino use battery power directly and nRF24L01 use 3.3V LDO 800mA one with 0.3V drop down )
                  • G
                    G
                    gloob
                    Why don't you connect the NRF also directly to the battery?
                    • G gloob
                      yd kimY
                      yd kimY
                      yd kim
                      @gloob
                      nRF module should not use over 3.6V and Li-Ion battery is 4.2V when it is full charged.
                      G 1 Reply Last reply
                      • F
                        F
                        flopp
                        Quick fix may be to add resend if Failed.
                        See here
                        https://forum.mysensors.org/topic/3355/count-car-starts/19
                        • yd kimY yd kim
                          @gloob
                          G
                          G
                          gloob
                          @yd-kim said:
                          @gloob
                          I thought you are also powering the Arduino directly from the battery over the 3.3V pin.
                          • F fleinze
                            yd kimY
                            yd kimY
                            yd kim
                            @fleinze
                            I keep reading the article.. interesting
                            The module which on the link is too expensive for my project;;
                            • G gloob
                              @yd-kim said:
                              @gloob
                              yd kimY
                              yd kimY
                              yd kim
                              @gloob
                              Arduino doesn't matter up to 5V so I don't mind for arduino.
                              If I feed same power to arduino, I need bigger LDO and also less efficiency.
