  3. NRF24L01+PA+LNA distance problem
25 Posts 6 Posters 12.7k Views 6 Watching
  • MiKaM MiKa
    Also check with RF scanner if its not a "jamming" from other RF device, or simply try to change channel to different one.
    yd kimY
    yd kimY
    yd kim
    @MiKa
    Device is installed in rural area. There is only one wifi. I don't think there is jamming or interference..
    I don't have RF scanner. If I couldn't find any other solution , probably I need to build RF scanner to check it..
    • yd kimY yd kim
      @MiKa
      @yd-kim https://www.mysensors.org/controller/sniffer might be an easy way if you want to scan.
      • F
        F
        fleinze
        Sometimes we get shitty modules from china:
        https://forum.mysensors.org/topic/1153/we-are-mostly-using-fake-nrf24l01-s-but-worse-fakes-are-emerging
        I made good experiance with these rather expensive ones:
        https://de.aliexpress.com/item/2pcs-RF2401F20-2-4G-high-integrated-RF-module-with-Nordic-s-RF-chip-nRF24L01-For-Free/32302870943.html
        But even with these I had to be very careful about antenna placement
        yd kimY 1 Reply Last reply
        • MiKaM
          MiKaM
          MiKa
          Another RF scanner with mini OLED 0.96 display
          https://www.rcgroups.com/forums/showthread.php?2777178-Very-cheap-Arduino-based-2-4-GHz-band-monitor
          • yd kimY yd kim
            @flopp
            Whole system is Li-Ion battery powered system with solar.
            Gateway has 3S2P Li-Ion battery with proper solar panel. Battery voltage never go under 11V.
            Node has 1x18650 Li-Ion battery with small solar panel.
            Node goes sleep mode for 10 minutes then wake up and send data within 10 second.
            F
            F
            flopp
            @yd-kim said:
            @flopp
            What kind of Arduino do you use?
            • F flopp
              @yd-kim said:
              @flopp
              yd kimY
              yd kimY
              yd kim
              @flopp
              Gateway : ESP8266 ( use 3A switching step down power module)
              Node : Arduino pro mini 3V ( Arduino use battery power directly and nRF24L01 use 3.3V LDO 800mA one with 0.3V drop down )
              • G
                G
                gloob
                Why don't you connect the NRF also directly to the battery?
                • G gloob
                  yd kimY
                  yd kimY
                  yd kim
                  @gloob
                  nRF module should not use over 3.6V and Li-Ion battery is 4.2V when it is full charged.
                  G 1 Reply Last reply
                  • F
                    F
                    flopp
                    Quick fix may be to add resend if Failed.
                    See here
                    https://forum.mysensors.org/topic/3355/count-car-starts/19
                    • yd kimY yd kim
                      @gloob
                      G
                      G
                      gloob
                      @yd-kim said:
                      @gloob
                      I thought you are also powering the Arduino directly from the battery over the 3.3V pin.
                      • F fleinze
                        yd kimY
                        yd kimY
                        yd kim
                        @fleinze
                        I keep reading the article.. interesting
                        The module which on the link is too expensive for my project;;
                        • G gloob
                          @yd-kim said:
                          @gloob
                          yd kimY
                          yd kimY
                          yd kim
                          @gloob
                          Arduino doesn't matter up to 5V so I don't mind for arduino.
                          If I feed same power to arduino, I need bigger LDO and also less efficiency.
