  2. Bug Reports
  3. Compile error for Pro Mini 5,5v 168
11 Posts 5 Posters 6.3k Views 4 Watching
  • xelnahaX
    xelnahaX
    xelnaha
    I recently updated from 2.0.0 to 2.1.0 and ever since I can no longer compile the same sketch, and I see a stack trace.
    I tried compiling the exact same sketch for another board (nano) and I don't have the problem. In fact, when I select the pro mini but with the Atmega328, it also compiles, just not with the atmega168
    • xelnahaX xelnaha
      @xelnaha the information in the stack trace will be the key to figuring out what is wrong. Please read it / post it.
      • xelnahaX
        xelnahaX
        xelnaha
        I tested it with 2.0.0 and no errors, same sketch with 2.1.0 gives me this:
        Arduino: 1.8.0 (Mac OS X), Board: "Arduino Pro or Pro Mini, ATmega168 (5V, 16 MHz)"
        In file included from sketch/BinarySwitchSleepSensor.ino.cpp:1:0:
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp: In function 'void RF24_csn(bool)':
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:152: error: '__digitalPinToPortReg' was not declared in this scope
        #define digitalWriteFast(__pin, __value) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__value)) { bitWrite(__digitalPinToPortReg(__pin), (uint8_t)__digitalPinToBit(__pin), (__value)); } else { digitalWrite((__pin), (__value)); } } while (0)
        /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:112:30: note: in definition of macro 'bitSet'
        #define bitSet(value, bit) ((value) |= (1UL << (bit)))
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:115: note: in expansion of macro 'bitWrite'
        /Users/user/Documents/Arduino/libraries/MySensors/core/MyHwATMega328.h:62:40: note: in expansion of macro 'digitalWriteFast'
        #define hwDigitalWrite(__pin, __value) digitalWriteFast(__pin, __value)
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp:39:2: note: in expansion of macro 'hwDigitalWrite'
        hwDigitalWrite(MY_RF24_CS_PIN, level);
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:88:187: error: '__digitalPinToBit' was not declared in this scope
        /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/Arduino.h:112:49: note: in definition of macro 'bitSet'
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp: In function 'void RF24_ce(bool)':
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp:44:2: note: in expansion of macro 'hwDigitalWrite'
        hwDigitalWrite(MY_RF24_CE_PIN, level);
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp: In function 'bool RF24_initialize()':
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:170: error: '__digitalPinToDDRReg' was not declared in this scope
        #define pinModeFast(__pin, __mode) do { if (__builtin_constant_p(__pin) && __builtin_constant_p(__mode) && (__mode!=INPUT_PULLUP)) { bitWrite(__digitalPinToDDRReg(__pin), (uint8_t)__digitalPinToBit(__pin), (__mode)); } else { pinMode((__pin), (__mode)); } } while (0)
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:134: note: in expansion of macro 'bitWrite'
        /Users/user/Documents/Arduino/libraries/MySensors/core/MyHwATMega328.h:64:35: note: in expansion of macro 'pinModeFast'
        #define hwPinMode(__pin, __value) pinModeFast(__pin, __value)
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp:388:2: note: in expansion of macro 'hwPinMode'
        hwPinMode(MY_RF24_CE_PIN,OUTPUT);
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/AVR/DigitalWriteFast/digitalWriteFast.h:91:205: error: '__digitalPinToBit' was not declared in this scope
        /Users/user/Documents/Arduino/libraries/MySensors/drivers/RF24/RF24.cpp:389:2: note: in expansion of macro 'hwPinMode'
        hwPinMode(MY_RF24_CS_PIN,OUTPUT);
        exit status 1
        Error compiling for board Arduino Pro or Pro Mini.
        • xelnahaX xelnaha
          exit status 1
          @xelnaha thanks.
          Seems like same problem as in https://forum.mysensors.org/topic/5426/cant-compile-2-01-for-atmega168
          • xelnahaX
            xelnahaX
            xelnaha
            Ah,
            correct. What might be good to post on the my sensors page is that the 168 isn't supported, as a "noob" i didn't see / realist this information, it just says buy nano / pro mini or whatever but not that it's specifically the 328 which is supported and not the 168 :)
            • xelnahaX xelnaha
              Ah,
              tboha
              @xelnaha
              Lazy sunday afternoon -got time to "fix" some problems.
              Not being capable of reading EBAY item descriptions properly, I got some Pro Mini 168 waiting for some work to do.
              Please be aware what the boss says:
              The atmega168 is not officially supported, due to the low flash / ram size, compared to atmega328 (tbowmo, ADMIN, 2 months ago)
              So far I remember are the Pro mini 168 essentially clones based upon Arduino Duemilanove just without power supply and USB.
              Within file "digitalWriteFast.h" in "<whatever>/Mysensors/drivers/avr/DigitalWriteFast/" at line 69
              #elif defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_DUEMILANOVE) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328PB__)
              I added
              #elif defined(ARDUINO_AVR_UNO) || defined(ARDUINO_AVR_DUEMILANOVE) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega328PB__) || defined (__AVR_ATmega168__)
              because it is not fair to mention DUEMILANOVE and not to give credits to ATmega168.
              With this modification compiling and uploading work well.
              Please remember:
              • Changes will be lost with every MySensors update
              • I don´t know about side effects to other processor choices (e.g. Nano V2.3)
              tbowmo was (is) right about memory capacity. The "BinarySwitchSensor" example sketch uses 14258 bytes from 14336 maximal Bytes. This is a really tight fit. Stripping debug information results in 7604 bytes.
              mfalkviddM tekkaT 2 Replies Last reply
              • T tboha
                @xelnaha
                I added
                Please remember:
                @tboha nice that you got it working! Maybe this change can be included in next MySensors release, unless it breaks something else.
                • T tboha
                  @xelnaha
                  I added
                  Please remember:
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @tboha
                  Thanks for reporting, use of digitalFastWrite modified / restricted, ATmega168 should be ok now:
                  https://github.com/mysensors/MySensors/pull/739
                    tboha
                    @mfalkvidd
                    I am quite happy that this little trick has no hidden side effects.
                    Would it be a good idea to give a crosslink to @Matt from https://forum.mysensors.org/topic/5426/cant-compile-2-01-for-atmega168/5 ?
                    I could not figure out how to do this, and cross posting is bad behavior I think.
                    • T tboha
                      @mfalkvidd
                      @tboha thanks. I added a note in the other thread.
                      cross-posting is generally bad yes, but since the other thread has the same problem and the solution is documented here cross-posting is actually useful.
                        Matt
                        @mfalkvidd woohoo! Time to resurrect some old nodes =)
                        Thanks for this...
