  3. Monitoring a wood boiler heating system
23 Posts 9 Posters 12.8k Views 10 Watching
  • tkarlssonT Offline
    tkarlssonT Offline
    tkarlsson
    Hello!
    About a year ago I found out about Mysensors and it has become kind of a hobby since then.
    I ordered some stuff from China and started buildning a gateway and a couple of sensors.
    I must say it seemed a bit "too good to be true" in the beginning, being able to build my own sensors and monitor/log them through a computer network. All at a very limited budget. I had my doubts but I gave it a chance.
    Now I am deeply impressed and thankful for the work that has been done with Mysensors, it helps me and surely many others to overcome lots of communication barriers and instead focus on "the fun of it".
    Now to a description of my little "project".
    To heat my house up, since I live in a forest-rich part of Sweden, I use a wood boiler that is connected to accumulator tanks with a total volume of 2000 liters. Hot tap water is produced in a small tank inside one of the accumulator tanks.
    With the help of the accumulators, I only have to fire up once a day even if it's -20 degreesC (OK, the boiler has to be refilled with more firewood once at that temperature). In the summer, firing up about once a week is enough to provide hot water for the household.
    It takes some hard work to prepare firewood for a whole year (about 20 stacked m^3), but I find it good for the body and I also think I can save some money on it.
    Before my little project it happened now and then that I forgot to fire the boiler up when I should have. Sometimes someone else in the house simultaneously had (her) own plans on taking a shower or tapping up a bath for a kid and as I heard the shouting from the 2nd floor I then had to run down to the basement, fire the boiler up and make sure to stay there for at least 30 mins☺ (the time it takes to get hot tap water, worst case). I had sometimes been thinking of putting some temperature sensors on the heating system and maybe placing some fancy display in the kitchen, but somehow I never really liked that plan.
    Giving Mysensors a shot, I built myself a gateway and a node and installed some temperature sensors. 5 on the tanks, but also one in the wood boiler. Later I also got a type K thermo element to measure the smoke gas temperature.
    I am running Domoticz on a Raspberry Pi and apart from the temperatures I have also learnt some LUA scripting and can now also read the momentary accumulator charge/discharge power (W), accumulated energy (kWh) and energy level as a percentage.
    What I find most useful, however, is that I am now getting push messages to my phone when It's about time to fire the boiler up and also when to put in more wood!
    Thanks again for Mysensors and keep up the good work!
    Best Regards,
    Tobias Karlsson
    mfalkviddM K 2 Replies Last reply
    • hekH Offline
      hekH Offline
      Welcome @tkarlsson, and keep up building the the fun stuff!
      • tkarlssonT tkarlsson
        Hello!
        Best Regards,
        Tobias Karlsson
        Very nice @tkarlsson, thanks for sharing!
        Would you mind posting what your graphs look like?
        tkarlssonT 1 Reply Last reply
          Hello!
          Best Regards,
          Tobias Karlsson
          K Offline
          K Offline
          korttoma
          Thanks for sharing @tkarlsson .
          I have a similar heating system in my house and have also installed some sensors in my accumulator tank to let me know when we are running out of hot water.
          I'm interested in hearing more details about the type K thermoelement that you use to measure the smoke gas temperature. I assume you use this to let you know when it is time to add more wood to the fire? I see how this would be useful since I sometimes forget about the fire and when I get to it the fire is dead and I need to start over.
          I have ordered some type K thermoelement myself along with some SPI interface adapters so I could implement this but I would love to hear more about your solution.
          • Tomas
          • K korttoma
            tkarlssonT Offline
            tkarlssonT Offline
            tkarlsson
            Hi @korttoma ,
            I am using a MAX6675 to measure the temperature of the smoke. I simply trig a flag at a falling smoke temperature under a certain level while the boiler is still warm. Then I reset it as the smoke temperature reaches a higher temperature again.
            It was a bit tricky to combine the example sketches to be able to connect both the DS18B20's and the MAX6675 to the same node, but I finally managed somehow. Perhaps there is still some bug in my sketch making it hard to restart after a power outage, I sometimes have to disconnect/connect the power a couple of times before the nodes starts to work again as intended. In the beginning the temperature sensors could get mixed up after a power outage, but then I implemented some kind of static addressing for the DS18B20's (mentioned somewhere else in this forum) and the mix up stopped.
            Tobias
            S K 2 Replies Last reply
              Hi @korttoma ,
              Tobias
              @tkarlsson - great work!! Nice to read!
              Any pictures of your masterpiece?
                Hi @korttoma ,
                Tobias
                K Offline
                K Offline
                korttoma
                @tkarlsson I have an MAX6675 and a MAX31865 (for PT100/PT1000 type sensors) on the way. Don't know yet which one I will be using.
                At the moment I have also a DS18B20 node with 3 sensors attached monitoring the tank (with static addressing).
                Have had no problems with this node so I think I will not touch it and make a separate node for the smoke temp.
                I also have a thermostat node controlling the pump between the heater and the tank (The Danfoss I was using before was unreliable and would cause my heater to boil from time to time).
                I would love it if you could at some point also share the sketch for your node and pictures are always nice.
                • Tomas
                tkarlssonT 2 Replies Last reply
                  tkarlssonT Offline
                  tkarlssonT Offline
                  tkarlsson
                  wrote on last edited by tkarlsson
                  @mfalkvidd,
                  Sure I can share some graphs. Unfortunately they are in Swedish though.
                  This is a graph showing 7 out of 10 temperatures from this node.
                  The graph is showing about 24 hrs and the wood boiler is fired up in the beginning.
                  I guess you can see which curve is the smoke gas temp :)
                  That one is the first to rise, then the boiler itself, later the sensors in the top-middle-bottom of the first accumulator tank and at last the top-bottom of the second tank. The tanks are connected in series (in the winter).
                  As I wrote, I also try to calculate charge/discharge power, the accumulated energy in kWh and % in the accumulator tanks as good as I can using my 5 temp sensors. I consider room temp (22degreesC) as my zero kWh level and then I calculate the energy using temperatures and a certain water volume corresponding to each temperature sensor. This is a "kWh graph" from about the same period:
                  All calculations are made in Domoticz and not in the Mysensor nodes.
                  I happen to have copies of the sketches at another location so cannot share them at the moment. I am sure they are even a bit outdated by now (definitely pre 2.0).
                  Perhaps, another day, I will click some photos of my installation. Nothing much to see, really. Part of it is behind a layer of insulation. But it is working great!
                  /Tobias
                  • K korttoma
                    tkarlssonT Offline
                    tkarlssonT Offline
                    tkarlsson
                    @korttoma ,
                    Nice pictures you shared! Looks good.
                    Now I get a bit reluctant about bringing the camera down there next time...
                    I have no fancy display and all the DS18B20's are individually wired to the box housing the node..
                    /Tobias
                    • K korttoma
                      tkarlssonT Offline
                      tkarlssonT Offline
                      tkarlsson
                      I have two more pictures to share.
                      First my Mysensors node. As I wrote, it was one of my first nodes but it is has been working for at least a year:
                      Further on, my overview in Domoticz looks like this:
                      Keep on Mysensing,
                      Tobias
                        @mfalkvidd,
                        /Tobias
                        @tkarlsson very nice, great work! Thanks a lot for sharing.
                        • R Offline
                          R Offline
                          RWoerz
                          Great work how do you send error messages from a MySensors node. I'm building a solar hot water heater for my shop with temp sensors inside, outside, solar panel, storage tank, and the attic, I also have flow and pressures sensors in the tank pump solar panel and another tank pump and inside heat exchanger. Besides the pumps I also control attic, ceiling and roof louvers and fans. Needless to say there's lots that could go wrong. If you've got a way to send alarms I would love to see the Sketches. Thanks.
                          I would also like to see pictures of setup I think many other would also.
                          • K Offline
                            K Offline
                            korttoma
                            Finally got a MAX31865 + PT100 on a breadboard set up and measuring the smoke temperature.
                            But I seem to have an issue, either there is something wrong with the library I'm using or the sensor just cant handle the heat. If it gets hot enough I get negative values.
                            The boileroom is not quite fit for debugging, would be nice to have a wireless serial port of some kind.
                            EDIT: Maybe I can use a 470ohm potentiometer to debug this instead of the PT100?
                            • Tomas
                            B enloE 2 Replies Last reply
                            • K korttoma
                              B Offline
                              B Offline
                              bjacobse
                              @korttoma said in Monitoring a wood boiler heating system:
                              Could it be something that you store your read value in a too small variable, so that you get variable rollover?
                              • K Offline
                                K Offline
                                korttoma
                                @bjacobse I hope so, I got it on my desk now. Just need to get the variable resistor today so I can start debugging.
                                 * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                                 * http://www.mysensors.org/build/temp
                                //#define MY_RFM69_FREQUENCY RF69_433MHZ
                                // Define a static node address, remove if you want auto address assignment
                                #define MY_NODE_ID 23
                                #include <Adafruit_MAX31865.h>
                                #define CHILD_ID 1
                                // Use software SPI: CS, DI, DO, CLK
                                //Adafruit_MAX31865 max = Adafruit_MAX31865(10, 11, 12, 13);
                                // use hardware SPI, just pass in the CS pin
                                Adafruit_MAX31865 max = Adafruit_MAX31865(8);
                                // The value of the Rref resistor. Use 430.0!
                                #define RREF 430.0
                                #define TEMP_TRANSMIT_THRESHOLD 2
                                float temperature;
                                float lastTemperature = 10;
                                float diffTemp = 1;
                                unsigned long SLEEP_TIME = 20000; // Sleep time between reads (in milliseconds)
                                bool receivedConfig = false;
                                bool metric = true;
                                MyMessage msg(CHILD_ID,V_TEMP);
                                void before()
                                  max.begin(MAX31865_3WIRE);  // set to 2WIRE or 4WIRE as necessary
                                  sendSketchInfo("PT100 Temp", "1.0");
                                     present(CHILD_ID, S_TEMP);
                                  uint16_t rtd = max.readRTD();
                                  Serial.print("RTD value: "); Serial.println(rtd);
                                  float ratio = rtd;
                                  ratio /= 32768;
                                  Serial.print("Ratio = "); Serial.println(ratio,8);
                                  Serial.print("Resistance = "); Serial.println(RREF*ratio,8);
                                  // Fetch temperature
                                  temperature = max.temperature(100, RREF);
                                  Serial.print("Temperature = "); Serial.println(temperature);
                                  diffTemp = abs(lastTemperature - temperature);
                                  Serial.print("DiffTemp = "); Serial.println(diffTemp);
                                    if (diffTemp > TEMP_TRANSMIT_THRESHOLD) {
                                      send(msg.set(temperature,1));
                                  sleep(SLEEP_TIME);
                                In the meantime I replaced it with a node that uses a K-Type thermocouple and this one works just fine.
                                • Tomas
                                • K Offline
                                  K Offline
                                  korttoma
                                  I can now confirm that the problem is in fact the PT100 sensor because if I "simulate" the sensor with a variable resistor everything works fine all the way up to 988.8 degrees and down to -241.3.
                                  Seems like I will have to use the K-Type sensor after all.
                                  • Tomas
                                  B 1 Reply Last reply
                                  • K korttoma
                                    B Offline
                                    B Offline
                                    bjacobse
                                    @korttoma
                                    Glad that you found the rootcause + published your analysis
                                    • K korttoma
                                      enloE Offline
                                      enloE Offline
                                      enlo
                                      @korttoma just being curious: how did you install that smoke sensor? drill an hole into the chimney?
                                      K B 2 Replies Last reply
                                      • enloE enlo
                                        K Offline
                                        K Offline
                                        korttoma
                                        @enlo there was a hole on the back of the wood boiler where the pipe goes to the chimney.
                                        It looked like a bolt and when I unscrewed it with a 14mm wrench I found that it had 12mm (or 1/2") threading so the hole was quite big and I can fit most sensors in it..
                                        Because the sensor is so close to the boiler it gets quite hot so it is actually not a surprise that the sensor could not handle it but the behaviour was quite strange. I thought that if it would fail it would also destroy the sensor but it just malfunctions and goes back to normal when it cools down.
                                        The sensor claimed to have a measurement range of -200~500 Degrees like most of the sensors for sale.
                                        The K-Type thermocouple I'm using now has "Operating Temperature: 0 – 800 °C" but the item on Ali is nolonger available. I looks like this one though ->
                                        https://www.aliexpress.com/item/K-Type-2M-EGT-Thermocouple-WRNK-191-Probe-type-Exhaust-Probe-High-Temperature-Sensors-Threads-Stainless/32754224250.html
                                        • Tomas
                                        enloE 1 Reply Last reply
                                        • enloE enlo
                                          B Offline
                                          B Offline
                                          bjacobse
                                          @enlo
                                          I would assume to drill a hole in the metal chimney that is between the wood boiler and the brick chimney.
                                          then depending of the K-type thermocouple
                                          then there is a nut so you can secure this like this:
                                          https://www.aliexpress.com/item/Newest-High-Temperature-100-To-1250-Degree-Thermocouple-K-Type-100mm-Stainless-Steel-Probe-Sensors/32786956791.html?spm=2114.40010308.4.1.LxioyK
                                          Or else you can sealed with special heat resistant seal:
                                          https://www.amazon.co.uk/Heat-Resistant-Sealant-1250-300ml/dp/B0046450C4
