  3. Ethernet gateway troubleshooting advice
w5100nrf24l01+ethernetveragateway
69 Posts 14 Posters 50.4k Views 6 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Alright, my findings so far:
    I have had some success in getting my ethernet GW to work. I had to make some minor changes to the sketch.
    Most importantly, I had to bring in the SOFTSPI support in the RF24 lib (how to do this is described here.
    I also had to disable the debug feature (in MyConfig.h).
    And I had to move gw.begin in setup() to be done after the delay(1000).
    Now I have a ethernet GW executing which is self-powered from my Vera (using USB) and running with a PA enhanced RF module on maximum PA level.
    I will now move on to picking up where I originally left off; checking if it is possible to manipulate SPI_EN signal in the sketch to allow RF module to share bus with W5100 which would be ideal. It should be easier to confirm this now, when I have a known good setup.
    • Z
      Z
      Zeph
      wrote on last edited by Zeph
      Brainstorming.
      There would seem to be a number of solutions to the issue of the W5100 not releasing the MISO line when the slave is deselected and thus being incompatible with other SPI devices.
      1. Use SoftSPI for one (or more) of the devices
      2. Use the USART SPI master mode for one device
      3. Use a host with more than 1 SPI interface
      4. Modify a shield or module to allow SPI_EN to be controlled by another uC pin & change libs to use it
      5. Use a shield or module designed to drive SPI_EN as the inverse of NSS (slave select)
      6. Modify a shield or module to do so
      The SoftSPI (for nRF) seems to work for some people. For the low-bandwidth usage of MySensors that may be adequate.
      The Wiz811 and Wiz812 modules appear to be in category 5, as are a few shields. The Wiz810 breaks out SPI_EN so it could be controlled by another uC pin.
      I haven't seen nRF or W5100 libs modified to use the USART in SPI mode but it should be possible (one would need to NOT use the hardware serial port for debugging or program loading while using it for SPI of course).
      I do not know if the W5200 or W5500 chips have the same problem.
      Note: since the W5100 does not tristate the MISO line when deselected but SPI_EN is still high, that means it's output will be fighting with whatever other slave is trying to drive MISO. Sometimes the other device may win, sufficiently. Thus the possibility of using both W5100 and nRF without any of the compensations -sometimes working for some people. Not good practice and not reliable!
      hekH 1 Reply Last reply
      • AnticimexA
        AnticimexA
        Anticimex
        I am going for option 4. I tried it once and failed, but I have since made a small change to the sketch which allowed me to use the W5100 using softSPI (changing order of some calls during setup()).
        Once I have confirmed if this will be possible without totally tearing up the libs I'll post it here.
        Someone else is of course welcome to investigate alternative options but my options are limited. I really would like to make it work with what I have, which rules out option 3 and 5-6. I prefer option 1 before option 2 as 1 is more flexible.
        Option 4 actually needs little to no hw modification. The MySensors building description does not mention it but W5100 does have SPI_EN on a pin, and this pin should also be connected to the host (I have connected it to D4).
        So with that small adjustment to the build instructions, and some appropriate changes to the sketch and possible the libraries, <should> get the ethernet GW back on track.
        • Z Zeph
          Brainstorming.
          @TMRh20Projects actually also incorporated the option to use USART as SPI in the latest commit (see defines in RF24_config). But you'll lose the debug-print possibility when using this option.
          • AnticimexA
            AnticimexA
            Anticimex
            My "option 4" attempt is progressing well.
            True-to-the-topic a good troubleshooting advice is to lower the speed of the SPI bus. When working on a breadboard, and having multiple devices on the SPI bus, the capacitive load starts to affect the clock and data lines.
            Patching
              SPI.setClockDivider(SPI_CLOCK_DIV2);
            to
              SPI.setClockDivider(SPI_CLOCK_DIV4);
            lowers the clock speed and provides a more reliable signalling (confirmed with logic analyzer).
            I do not think the change is needed on "sharp" boards, but it seem indeed to help when having a bread-board that resembles something from greek mythology :)
            • AnticimexA
              AnticimexA
              Anticimex
              My fix for W5100 is now available on the development branch.
              • daulagariD
                daulagariD
                daulagari
                @Zeph:
                Checked the W5500 datasheet and read:
                TCHZ - SCSn High to Output Hi-Z - 2.1 ns
                So it looks like the W5500 does not have this problem.
                If this is true then even using SPI_EN instead or in combination with /SCS does not really enable using another SPI slave in combination with the W5100 ...
                AnticimexA 1 Reply Last reply
                • daulagariD daulagari
                  @Zeph:
                  AnticimexA
                  AnticimexA
                  Anticimex
                  Yes it does, since driving SPI_EN low makes W5100 release MISO.
                  SPI_EN is not a signal to be used "instead of" SCS. It is a completly independent signal that enables or disables the use of the SPI bus on the W5100. SCS is used "in" the SPI bus for selecting W5100 as sender/receiver.
                  So a solution to the problem is to make sure SPI_EN is driven low, every time another SPI slave is being used.
                  • Z
                    Z
                    Zeph
                    Some designs fix this issue for the W5100 by driving SPI_EN from SCS via an inverter - I've seen circuits with a nand gate and with a FET and resistor. I believe the WizNet folks suggested that option. It could also be handled with a modified library by driving SPI_EN from another uC pin and disabling SPI_EN (low) whenever driving SCS high.(say if you were using a WIZ810 which has both W5100 pins exposed). Most shield tie SPI_EN to Vcc tho, so you'd have to cut a trace to fix them.
                    • N
                      N
                      niccodemi
                      Anticimex, thanks, your fix works. I am using uno R3 with Wiznet5100 shield. I am able to control relays and receive sensors data. I can also ping ethernet gateway.
                      There seems to be just a minor glitch. though. When I connect uno via usb cable to computer to monitor serial messages I never get "0;0;4;11;Arduino startup complete" message.
                      Has this been removed? It doesn't seem to affect functionality anyway.
                      • N niccodemi
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @niccodemi nice to hear. DEBUG might be switched of in MyConfig.h
                        • karenbobivK
                          karenbobivK
                          karenbobiv
                          • karenbobivK
                            karenbobivK
                            karenbobiv
                            Howdy. Been trying to follow/implement the Soft SPI fix for this. I appreciate everything so far. I'm not a coder, so try to follow instructions closely, but seem to have messed this up. I'm using a R3 Uno with Ethernet Shield. There seems to be several parts to this fix, but I'm getting error messages now. Did get the original to work, but it would freeze up as described.
                            First what I did to fix, perhaps I missed something. This is all I did, so please don't assume I would know to do something:
                            1. Installed Arduino 1.5.8 IDE
                            2. Installed Anticimex's "fix for W5100" from the "development branch" into my Arduino folder on computer
                            3. Opened RF24_config.h in a text editor. Uncommented the line #define SOFTSPI
                            4. In Gateway sketch, added #include <DigitalIO.h>
                            5. Disabled the debug feature in MyConfig.h
                            6. Moved the gw.begin after the delay(1000) (not sure if I got this right since I don't code. Here is snippet of what I have now in sketch:
                            // give the Ethernet interface a second to initialize
                            delay(1000);
                            w5100_spi_en(true);
                            However, I now get the following errors:
                            Arduino: 1.5.8 (Windows 7), Board: "Arduino Uno"
                            In file included from C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:12:0:
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.h:39:28: error: 'DEFAULT_CE_PIN' was not declared in this scope
                            MyGateway(uint8_t _cepin=DEFAULT_CE_PIN, uint8_t _cspin=DEFAULT_CS_PIN, uint8_t _inclusion_time = 1, uint8_t _inclusion_pin = 3, uint8_t _rx=6, uint8_t _tx=5, uint8_t _er=4);
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.h:39:59: error: 'DEFAULT_CS_PIN' was not declared in this scope
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.h:42:36: error: 'RF24_PA_LEVEL_GW' was not declared in this scope
                            void begin(rf24_pa_dbm_e paLevel=RF24_PA_LEVEL_GW, uint8_t channel=RF24_CHANNEL, rf24_datarate_e dataRate=RF24_DATARATE, void (dataCallback)(char )=NULL);
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp: In constructor 'MyGateway::MyGateway(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:27:167: error: no matching function for call to 'MySensor::MySensor(uint8_t&, uint8_t&)'
                            MyGateway::MyGateway(uint8_t _cepin, uint8_t _cspin, uint8_t _inclusion_time, uint8_t _inclusion_pin, uint8_t _rx, uint8_t _tx, uint8_t _er) : MySensor(_cepin, _cspin) {
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:27:167: note: candidates are:
                            In file included from C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.h:15:0,
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:79:2: note: MySensor::MySensor()
                            MySensor();
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:79:2: note: candidate expects 0 arguments, 2 provided
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:70:7: note: MySensor::MySensor(const MySensor&)
                            class MySensor
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:70:7: note: candidate expects 1 argument, 2 provided
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp: In member function 'void MyGateway::begin(rf24_pa_dbm_e, uint8_t, rf24_datarate_e, void (
                            )(char
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:76:39: error: no matching function for call to 'MyGateway::setupRadio(rf24_pa_dbm_e&, uint8_t&, rf24_datarate_e&)'
                            setupRadio(paLevel, channel, dataRate);
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:76:39: note: candidate is:
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:238:7: note: void MySensor::setupRadio()
                            void setupRadio();
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MySensor.h:238:7: note: candidate expects 0 arguments, 3 provided
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:77:36: error: 'BASE_RADIO_ID' was not declared in this scope
                            RF24::openReadingPipe(WRITE_PIPE, BASE_RADIO_ID);
                            C:\Users\Robert\Documents\Arduino\libraries\MySensors\MyGateway.cpp:79:23: error: cannot call member function 'void RF24::startListening()' without object
                            RF24::startListening();
                            Error compiling.
                            Welcome any help. Thanks much.
                            Dan S.D 1 Reply Last reply
                            • karenbobivK karenbobiv
                              delay(1000);
                              w5100_spi_en(true);
                              MySensor();
                              class MySensor
                              )(char
                              void setupRadio();
                              Error compiling.
                              Dan S.D
                              Dan S.D
                              Dan S.
                              @karenbobiv When I redid my gateway, I just downloaded the latest version of the regular my sensors library which already includes all that is need for soft spi and used the ehternet gateway sketch from the library. Did not use the "fix for W5100." Did not move the gw.begin. Need to include Digital.IO in gateway sketch as you did. Also make sure you define the include statement for using the W5100 version of the ethernet (if I remember right the other one is the default). Also note that the some of the wiring of the radio to the UNO is different in soft spi--see anticmex's directions which include some numbers that need to be changed in the radio file plus defining soft spi as you did.
                              • Dan S.D
                                Dan S.D
                                Dan S.
                                At any rate, those are library errors so that's why suggested you download and use the latest basic library.
                                • karenbobivK
                                  karenbobivK
                                  karenbobiv
                                  Thanks for the help Dan. I've been at this for almost 12 solid hrs. I reloaded the IDE environment and the mysensors library, so all that is fresh. I've got the sketch loading without error, but don't think I'm getting the wiring of the radio and the radio file right at all. Can't get to ping either. I'm using the Uno R3 and the shield. Could you provide more detail please on how you did it? Thanks.
                                  • Dan S.D
                                    Dan S.D
                                    Dan S.
                                    I used these instructions from anticimex:
                                    Patch RF24_config.h to enable softspi, uncomment
                                    //#define SOFTSPI
                                    and select pins to use with
                                    const uint8_t SOFT_SPI_MISO_PIN = 15;
                                    const uint8_t SOFT_SPI_MOSI_PIN = 14;
                                    const uint8_t SOFT_SPI_SCK_PIN = 16;
                                    The setting above mean MOSI on A0, MISO on A1 and SCK on A2 on an Arduino Nano.
                                    So when you use soft spi and and change the statements in RF24_config.h as above, the wires for mosi, miso and sck as shown in the ethernet radio diagram are changed and go to A0, A1 and A2 respectively on the UNO (be careful not getting miso and mosi mixed). you need to get the gateway started message from the serial monitor rather than the check wires message to proceed. Recommend you take a break and hit it tomorrow--I know how I got when going though this. Mine is still working going on over 3 days now without a hitch. Also make sure you have the ip and port address entered in the advanced tab of the plugin on the vera when you are ready to finally hook it up, otherwise vera will give you a luup error.
                                    karenbobivK 1 Reply Last reply
                                    • N
                                      N
                                      niccodemi
                                      Dan, which mysensors library did you use. Master or development?
                                        The SOftSPI enable RF24 and DigitalIO library has been added to master a few days ago. You should probably not use "development" at the moment.
                                        • N
                                          N
                                          niccodemi
                                          I noticed something was different. About 8 days ago I was able to get Uno r3 and w5100 shield work using development library, which has just been updated by anticimex. gateway ran for a week without issues except i was not able to control relay nodes. Yesterday I downloaded master and development libraries. With Master i can get gateway to communicate with vera but when I press include button radio comms stop. i also tried development library. modified as per dan and anticimex instructions and not modified. in both cases i can upload sketch but then i do not get any serial communication and also pinging gateway does not work.
