  3. 💬 MDMSNode "Lighting"
nrf24l01rfm69arduinomysensorslight switchlightacdc
37 Posts 11 Posters 15.0k Views 10 Watching
    @kalina
    Can we buy it preassembled soon?
    kalinaK
    kalinaK
    kalina
    @Cliff-Karlsson Yes, i have made 10 pcs. But if necessary i can solder more. Price for model with RFM69 is 23$ and with NRF24L01 is 20$...
    • Cliff KarlssonC
      Cliff KarlssonC
      Cliff Karlsson
      Ok, great. Are there any progress on the MDMSensor "Multisensor" and gateway?
      kalinaK 1 Reply Last reply
        kalinaK
        kalinaK
        kalina
        @Cliff-Karlsson Yes, gateway is ready, but MDMSensor "Multisensor" is still in progress...
        • tonnerre33T
          tonnerre33T
          tonnerre33
          Hello
          Why do you use a triac instead a relay for command the light ? What is the point ?
          • tonnerre33T tonnerre33
            Hello
            kalinaK
            kalinaK
            kalina
            Hi @tonnerre33. MOC3043 triac includes the function of Zero Voltage Crossing, this mean that triac can trigger only when AC voltage close to 0 V. SSR doesn't use this feature. If you use just one device with ordinary relay or SSR, it is not appreciably, but if the number of switching devices increases and they all switch on at the moment of maximum value AC voltage, this will produce a lot of impulse spikes of voltage, which is not desirable. Ordinary relay also makes a not comfortable sound...
            • tonnerre33T
              tonnerre33T
              tonnerre33
              @kalina thx for your answer ;)
              • kalinaK
                kalinaK
                kalina
                Hi, I want to share good news in the my project. Lighting has become more safer.
                Instead the enclosure, I use a heat shrink tubing 3M MDT-A-32/7.5.
                Here's result.
                • jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  Your system works with phase and neutral wires? Will you make it compatible without neutral as well? In my house installation no neutral behind the wall switch only phase. And o the lamp side only neutral and the return wire from the wall switch.
                  • jeremushkaJ jeremushka
                    kalinaK
                    kalinaK
                    kalina
                    #23
                    Yes.
                    Actually, no. Why do you plan put this into the wall switch area? As for me, i am going to put "Lighting" near the lamp. Wall switch must be as a push button (normally closed). When you press button circuit opens (on short time) and Atmega328 resets and toggles lamp state. It means that "Lighting" always is conneted to the AC line. You can also change lamp state directly from your controller at any time. See picture below.
                    jeremushkaJ 1 Reply Last reply
                    • tonnerre33T
                      tonnerre33T
                      tonnerre33
                      #24
                      I didn't know this method ;)
                      Do we have a limite time for circuit open ?
                      How do you do this in the sketch ?
                      Where can we find the sketch ?
                      What are the consequences for the components life ?
                      With this use, the reboot time will impact the response time bewtween the command and the lamp power , isn't it ?
                        kalinaK
                        kalinaK
                        kalina
                        #25
                        Yes, of course. In my opinion, this time we can determine in practice, i don't know how can it be calculated. I haven't done it yet, I will try to do it on weekend.
                        I have no answers on this questions, it is certainly disadvantages of this method, but i wont use wall switch very often, i prefer to operate via controller. No need reboot uC in this case.
                        • kalinaK kalina
                          Yes.
                          jeremushkaJ
                          jeremushkaJ
                          jeremushka
                          @kalina : your solution is quite interesting when push button are installed. Yes, i would like to put the system in the wall switch. For the moment, i connect the switch of the house on the arduino. The system is powered by phase and neutral in the garage as behind the switch i had the neutral wire. However, in the house no neutral like on your picture. So, im checking about using leakage current which should be enough to power on the system.... Not sure.
                            kalinaK
                            kalinaK
                            kalina
                            @jeremushka said:
                            So, im checking about using leakage current which should be enough to power on the >system.... Not sure.
                            I would be interested to hear about your results
                            • B
                              B
                              bilbolodz
                              How about dimming? Due to lack of "zero crossing detection" it could be a problem!
                              • B bilbolodz
                                #29
                                @bilbolodz see earlier posts in this thread. The node does not support dimming, but it does support zero crossing.
                                • jeremushkaJ
                                  jeremushkaJ
                                  jeremushka
                                  @Kalina, does your project still alive? do you still have some samples for sales ?
                                    kalinaK
                                    kalinaK
                                    kalina
                                    #31
                                    @jeremushka This project has some shortcomings. For this reason I have released a new, more advanced version - MDMSNode "Lighting" Rev 1.1. If you are interested, I have more than 10 pcs in stock.
                                    • kalinaK kalina
                                      @kalina would you mind adding a link to the new version in the description of the old one?
                                        kalinaK
                                        kalinaK
                                        kalina
                                        @mfalkvidd Easy)) Already done.
                                        • jeremushkaJ
                                          jeremushkaJ
                                          jeremushka
                                          @ Kalina: Thanks :) Which kind of shortcomings did you get? load switch issue ? safety issue ?
