  3. Vera
  4. Vera edge and Serial Gateway
18 Posts 5 Posters 7.7k Views 5 Watching
  • dylan.ballooD Offline
    dylan.balloo
    Thanks for the advise. Can you please tell me how to connect the
    USB to Serial:
    http://www.ebay.com/sch/i.html?_nkw=ftdi+usb+to+serial
    to my arduino nano. On which pin shall I connect it?
      dylan.balloo
      Shall I disconnect the serial gateway afterwards?
      • K Offline
        K Offline
        korttoma
        There should already be a USB serial chip on your Nano. Check the other side of it. If it says FTDI on the chip there is still a chance to get it to work with what you already have.
        Sometimes the Vera just has difficulty finding it. You just need to keep trying reboot restart loop.
        If it is not a FTDI chip there is no use trying.
        • Tomas
          dylan.balloo
          I have check on my nano, nowhere seems to write FTDI. 0_1477477958326_IMAG0932.jpg 0_1477477995860_IMAG0933.jpg
          Can I buy this one:
          http://www.ebay.com/itm/Nano-V3-0-with-ATMEGA328P-FT232RL-FTDI-Micro-controller-Module-for-Arduino-/281145520990?hash=item417594335e:g:qzAAAOxy9ERSR-Wc
          How are the connection done, shall the usb cable I used to connect to my PC be connect to the VERA via USB port?
          If I want to connect
          http://www.ebay.com/itm/FT232RL-3-3V-5-5V-FTDI-USB-to-TTL-Serial-Adapter-Module-for-Arduino-Mini-Port-/381374421597?hash=item58cbafda5d:g:jk8AAOSwrklVMjIp
          with my actual Nano, how shall I connect it?
            dylan.balloo
            Hello all,
            Please help me out on above.
            Thank you
            • hekH Offline
              hekH Offline
              It is hard to know if ebay/aliexpress chips is genuine. You better ask for a guarantee from the seller before making the purchase.
                dylan.balloo
                Hello NITRO BURN,
                Can you please advise if you tested this one :
                http://www.ebay.com/sch/i.html?_nkw=ftdi+arduino+nano
                and if it is working?
                  dylan.balloo
                  hello hek,
                    dylan.balloo
                    Hello there,
                    I have bought the new FTDI Nano. But still not working.
                    I have the following error on my vera:
                    MySensors plugin : Cannot send command - communications error
                    Thanks to advise.
                    • D Offline
                      If you look at the FTDI chip, it should say PL2303 on it. Those are the only ones that I have gotten to work with my Vera. I do kind of wish that Vera would add support for the CH340s as those are another common USB to serial chip.
