π¬ Building a WiFi Gateway using ESP8266
What part is confusing? Did you follow the steps outlined here:
https://www.mysensors.org/controller/vera -
https://www.mysensors.org/controller/vera@hek I got it already, I was confused on the Vera Plugin vs the Arduino Plugin not realizing they were both the same, but now I get the following message on Vera
"MySensors plugin : Choose the Serial Port"
"MySensors Plugin[105] : Running Lua Startup"I have yet to assemble the Serial Gateway though, so I'm assuming the messages will go away once the Gateway is installed??????
Thanks so much!!
This thing's Amazing!!!!!!
Hi all,
I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpgAnd here is the error I get:
TSM:INIT
!TSM:RADIO:FAIL
!TSM:FAILURE
TSM:PDTthanks,
I used the same link (pins and sketches!). Checked it 10 times!
I think my Radios are not functional.... -
Good idea,
Here is the side by side image from front and back of the PCB.
The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
However, I have rotated it by 180 degree and tried that as well. same result!
Guys, just an update for my issue regarding Radio and my circuit.
The Radio was faulty, I received the new one, swapped it and all worked fine.I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
The wiring all are correct.Thanks
Hello, i have build a wifi gateway and use it in jeedom.
My gateway wifi as connection problem.
In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
If I restart the node the communication is re-established.
Is this a problem with nrf24l01? -
why esp8266 gateway shows only debug info?
when i comment //#define MY_DEBUG
where is no any serial output. -
If put in client mode
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
I get an error. How to win.**
Arduino: 1.8.2 (Windows 7), ΠΠ»Π°ΡΠ°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None""C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
size_t left = source.available(); ^C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
source.read(buffer.get(), will_send); ^ΠΡΠΏΠΎΠ»ΡΠ·ΡΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡΠ΅ΠΊΡ ESP8266WiFi Π²Π΅ΡΡΠΈΠΈ 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
ΠΡΠΏΠΎΠ»ΡΠ·ΡΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡΠ΅ΠΊΡ MySensors Π²Π΅ΡΡΠΈΠΈ 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
ΠΡΠΏΠΎΠ»ΡΠ·ΡΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡΠ΅ΠΊΡ EEPROM Π²Π΅ΡΡΠΈΠΈ 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
ΠΡΠΏΠΎΠ»ΡΠ·ΡΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡΠ΅ΠΊΡ SPI Π²Π΅ΡΡΠΈΠΈ 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
exit status 1
ΠΡΠΈΠ±ΠΊΠ° ΠΊΠΎΠΌΠΏΠΈΠ»ΡΡΠΈΠΈ Π΄Π»Ρ ΠΏΠ»Π°ΡΡ Generic ESP8266 Module.* -
Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)? -
@joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
Any help in figuring this out would be appreaciated!
With your input, this post could be even better π
