  2. Announcements
  3. πŸ’¬ Building a WiFi Gateway using ESP8266
109 Posts 52 Posters 73.8k Views 51 Watching
    @ramoncarranza
    What part is confusing? Did you follow the steps outlined here:
    https://www.mysensors.org/controller/vera
    ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    @hek I got it already, I was confused on the Vera Plugin vs the Arduino Plugin not realizing they were both the same, but now I get the following message on Vera
    "MySensors plugin : Choose the Serial Port"
    "MySensors Plugin[105] : Running Lua Startup"
    I have yet to assemble the Serial Gateway though, so I'm assuming the messages will go away once the Gateway is installed??????
      Yes, once you insert the usb gateway you just have to follow the instructions here:
      https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
      • ramoncarranzaR
        ramoncarranzaR
        ramoncarranza
        Thanks so much!!
        This thing's Amazing!!!!!!
        • sghazaghS
          sghazaghS
          sghazagh
          Hi all,
          I try to connect the Radio to Wemos D1 mini Pro and it's not working? I used both ESP8266Gateway and RelayActuator sketches and both Radio Fails...
          Are the pins here work fine with Wemos D1Mini?here is the pinout: http://escapequotes.net/wp-content/uploads/2016/02/d1-mini-esp8266-board-sh_fixled.jpg
          And here is the error I get:
          TSM:INIT
          !TSM:RADIO:FAIL
          !TSM:FAILURE
          TSM:PDT
          thanks,
          • korttomaK
            korttomaK
            korttoma
            If you are using the NRF24L01+ you should wire it according to the instructions here
            And use the sketch from the same page.
            So check your wiring of the radio module.
            • Tomas
            • sghazaghS
              sghazaghS
              sghazagh
              I used the same link (pins and sketches!). Checked it 10 times!
              I think my Radios are not functional....
              korttomaK 1 Reply Last reply
              • sghazaghS sghazagh
                korttomaK
                korttomaK
                korttoma
                @sghazagh maybe you can take a picture of the setup. Maybe someone else can see something that you don't.
                • Tomas
                • sghazaghS
                  sghazaghS
                  sghazagh
                  wrote on last edited by sghazagh
                  #31
                  Good idea,
                  Here is the side by side image from front and back of the PCB.
                  The 'j1' marked on wrong pin ,that's why I think my radio is not working at all as it seems it's very bad replicate.
                  However, I have rotated it by 180 degree and tried that as well. same result!
                  • sghazaghS
                    sghazaghS
                    sghazagh
                    Guys, just an update for my issue regarding Radio and my circuit.
                    The Radio was faulty, I received the new one, swapped it and all worked fine.
                    I just posted that here if someone want to use my last post image as a reference for connecting the Radio.
                    The wiring all are correct.
                    • jakesJ
                      jakesJ
                      jakes
                      Hi Hek,
                      Thanks for this guide... I have added an additional 433 RF receiver to my ESP8266 gateway. How can I send the data received from 433 RF to the my Home Assistant controller?
                      • denisvdbD
                        denisvdbD
                        denisvdb
                        Hello, i have build a wifi gateway and use it in jeedom.
                        My gateway wifi as connection problem.
                        In jeedom, in the log of my sensors node I have almost every 2 days the message: diconnected from network gateway.
                        If I restart the node the communication is re-established.
                        Is this a problem with nrf24l01?
                        • D
                          derrij
                          why esp8266 gateway shows only debug info?
                          when i comment //#define MY_DEBUG
                          where is no any serial output.
                          • D derrij
                            @derrij because it is a wifi gateway?
                            • A
                              AndreD
                              If put in client mode
                              #define MY_CONTROLLER_IP_ADDRESS 192, 168, 2, 9
                              I get an error. How to win.
                              Arduino: 1.8.2 (Windows 7), ΠŸΠ»Π°Ρ‚Π°:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
                              "C:\Users\DedHP\AppData\Local\Temp\arduino_build_364162\sketch\GatewayESP8266.ino.cpp.o"
                              In file included from C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                                           from C:\Users\DedHP\AppData\Local\Temp\arduino_modified_sketch_313960\GatewayESP8266.ino:132:
                              C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
                              C:\Documents\Arduino\ams\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58: required from here
                              C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
                               size_t left = source.available();
                              C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
                               source.read(buffer.get(), will_send);
                              Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ ESP8266WiFi вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
                              Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ MySensors вСрсии 2.1.1 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Documents\Arduino\ams\Arduino\libraries\MySensors
                              Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ EEPROM вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
                              Π˜ΡΠΏΠΎΠ»ΡŒΠ·ΡƒΠ΅ΠΌ Π±ΠΈΠ±Π»ΠΈΠΎΡ‚Π΅ΠΊΡƒ SPI вСрсии 1.0 ΠΈΠ· ΠΏΠ°ΠΏΠΊΠΈ: C:\Users\DedHP\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
                              exit status 1
                              Ошибка компиляции для ΠΏΠ»Π°Ρ‚Ρ‹ Generic ESP8266 Module.*
                              • Jonathan CaesJ
                                Jonathan CaesJ
                                Jonathan Caes
                                Is it possible to use this setup without the nrf24l01 atached, so that i can use the esp8266 just as a sensor (not as a gateway)?
                                • Jonathan CaesJ Jonathan Caes
                                  #39
                                  @Jonathan-Caes yes. Don't define MY_RADIO_NRF24 and you're good to go. It will still be a gateway, but a gateway with local sensors and no radio.
                                  • J
                                    J
                                    joseyapor
                                    Hi how many Gateways Can i have on a network?
                                    • J joseyapor
                                      #41
                                      @joseyapor On one MySensors network there can only be one MySensors gateway. But on one IP network, there can be many MySensors gateways. Exactly how many depends on geography and chosen transports but at the very least a few hundred. Thousands if you really need and plan accordingly.
                                      I 1 Reply Last reply
                                      • A
                                        alexalex
                                        Help! After connecting to the WIFI, I'm getting disconnected. Here's a log : https://goo.gl/fyr7ku
                                        Any help in figuring this out would be appreaciated!
                                        • A alexalex
                                          #43
                                          Welcome to the MySensors community @alexalex
                                          The log is missing the first lines, but it looks like the microcontroller is unable to communicate with the radio. Which radio are you using?
                                          See https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details for more details about the log messages and https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to fix them.
                                          With your input, this post could be even better πŸ’—
