  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • asgardroA asgardro
    @flopp
    lm393
    F
    F
    flopp
    @asgardro said:
    @flopp
    lm393
    Have you trimmed the pot so the LED turns on when your power meter flash?
    • F flopp
      @asgardro said:
      @flopp
      i have connected the digital out from the sensor
      Do you mean LM393?
      Can you put a flash light in front of the sensor so trigger it. You shall now see some text in serial monitor
      asgardroA
      asgardroA
      asgardro
      @flopp
      i have done that and calibrated the lm393 , i have a blinking light that triggers the sensor. thats how i am testing...but after initializing sends the value first time and thats it
      sorry to reply so late but have to wait 120seconds between posts lol
      • asgardroA
        asgardroA
        asgardro
         * Version 1.0 - Henrik EKblad
         * This sketch provides an example how to implement a distance sensor using HC-SR04
         * Use this sensor to measure KWH and Watt of your house meeter
         * You need to set the correct pulsefactor of your meeter (blinks per KWH).
         * The sensor starts by fetching current KWH value from gateway.
         * Reports both KWH and Watt back to gateway.
         * Unfortunately millis() won't increment when the Arduino is in
         * sleepmode. So we cannot make this sensor sleep if we also want
         * to calculate/report watt-number.
         * http://www.mysensors.org/build/pulse_power
        // Enable debug prints
        //#define MY_RF24_CHANNEL 74
        #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
        #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
        unsigned long SEND_FREQUENCY = 5000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
        double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
        bool pcReceived = false;
        unsigned long oldPulseCount = 0;
        unsigned long oldWatt = 0;
        double oldKwh;
        unsigned long lastSend;
        MyMessage wattMsg(CHILD_ID,V_WATT);
        MyMessage kwhMsg(CHILD_ID,V_KWH);
        MyMessage pcMsg(CHILD_ID,V_VAR1);
          request(CHILD_ID, V_VAR1);
          pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
          attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
          lastSend=millis();
          Serial.println("7");
          present(CHILD_ID, S_POWER);
        //Serial.println("6");
          unsigned long now = millis();
          if (pcReceived && (SLEEP_MODE || sendTime)) {
            if (!SLEEP_MODE && watt != oldWatt) {
              if (watt<((unsigned long)MAX_WATT)) {
              Serial.print("Watt:");
              Serial.println(watt);
              oldWatt = watt;
        Serial.println("5");
            // Pulse cout has changed
            if (pulseCount != oldPulseCount) {
              send(pcMsg.set(pulseCount));  // Send pulse count value to gw
              double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
              oldPulseCount = pulseCount;
              if (kwh != oldKwh) {
                send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                oldKwh = kwh;
              Serial.println("4");
            lastSend = now;
          } else if (sendTime && !pcReceived) {
            // No count received. Try requesting it again
            lastSend=now;
        Serial.println("3");
          if (SLEEP_MODE) {
            sleep(SEND_FREQUENCY);
          Serial.println("2");
        if (message.type==V_VAR1) {
        Serial.println("rece");
        pulseCount = oldPulseCount = message.getLong();
        Serial.print("Received last pulse count from gw:");
        Serial.println(pulseCount);
        pcReceived = true;
        Serial.println("not_rece");
        void onPulse()
          if (!SLEEP_MODE) {
            unsigned long interval = newBlink-lastBlink;
            if (interval<10000L) { // Sometimes we get interrupt on RISING
              return;
            watt = (3600000000.0 /interval) / ppwh;
            lastBlink = newBlink;
          pulseCount++;
          Serial.println("1");
        this
        • maghacM
          maghacM
          maghac
          As the sketch starts by requesting the latest pulse count (e.g starting kWh value) and does not send anything without having received it, how do I "seed" this value to my GW? I am using a MQTT GW, can I construct a MQTT special message containing the value, or how is it supposed to work?
          F 1 Reply Last reply
          • maghacM maghac
            F
            F
            flopp
            @maghac
            I am using Domoticz ans MyS 1.5.1
            You don't have to create VAR1, it will be created when you ask for it or it always exists for each Child.
            If you want VAR1 to be exactly the same as your meter you need to open domoticz.db and set the value or in your sketch.
            maghacM 1 Reply Last reply
            • sundberg84S
              sundberg84S
              #50
              Anyone knows why I dont get the sleep() function (time) to work properly.
              My hardware is EasyPCB, Pro Mini 3.3v 8mhz, Booster 2xAA and NRF24 radio.
              My software is: standard sketch 2.0.1, with sleep function.
              The problem is the sleep time is 5 times less than declared so maybe timing?
              When i enter sleep(10000) for example the nodes sleeps for 2 sec and wakes up.
              The interupt works fine.
              My sollution was adding *5 to get the correct sleep time - but why doesnt it work?
              • F flopp
                @maghac
                maghacM
                maghacM
                maghac
                @flopp I had to set pcReceived to true, upload the sketch, run it and then change back to false again and recompile/reupload. I can understand why it does it, since you don't want the pulse counter to reset to 0 if the sensor happens to restart (because you killed the power or whatever).
                What I don't understand is how I can seed the value with the correct initial value.
                Is it the controller (in my case HomeAssistant) or the gateway that is supplying the value?
                • maghacM maghac
                  maghacM
                  maghacM
                  maghac
                  It appears to be the controller that stores the value. I deleted the sensor from HomeAssistant and restarted, when it came back in again it started from zero.
                  • maghacM maghac
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @maghac
                    This is a hack, but if using json persistence, you can set the count in the JSON file and restart home assistant, with the node turned off. Then turn on the node.
                      @maghac
                      maghacM
                      maghacM
                      maghac
                      @martinhjelmare Yep, I figured I could do that. The absolute value is not so important actually, I'm more interested in the daily/weekly delta, which I hope Grafana can tell me.
                        wrote on last edited by gohan
                        #55
                        is this the same sensor than the one in the guide?
                        http://uk.farnell.com/ams/tsl250r-lf/photodiode-sensor-l-volts/dp/1182346
                        Can I also use also photoresistor? (Since I already have one)
                          sundberg84S
                          sundberg84S
                          #56
                          @gohan - nope its not the same, and yes you can use a photoresistor (i have just made one) but I needed a transistor for it to work and also it had to be completley dark. Using this on batteries its much better using just a photoresistor because the sensor in the guide draws about 1mA which will drain the batteris very quickly.
                          I will post my sensor later.
                          Edit: this is the sensor i build:
                          The node (including pro mini) draws about 50uA sleeping and 170uA not sleeping.
                          The photoresistor was 5M ohm in complete dark.
                            The guide specifies LM393 Light Sensor or the tsl250r-lf so I thought it was the same since the same name.
                            Since the node will be powered with it's power supply, I don't have any battery drain problem in this case. But why did you use a transistor? Can't you just check for a threshold value in the analog input to count as a pulse?
                              sundberg84S
                              sundberg84S
                              #58
                              Ok, all I can see is that it doesnt look the same at all.
                              @gohan - I tried, and I thought that should work - but for some reason I could not get it to trigger the interupt on the atmega :(
                              Looking the the voltage thresholds it was supposed to work but it didnt. I was thinking it was to low uA but i dont know really.
                              gohanG 1 Reply Last reply
                              • F
                                F
                                flopp
                                This is what I use togeheter with LM393
                                https://www.kjell.com/se/sortiment/el-verktyg/elektronik/optokomponenter/ir-dioder-fototransistorer/fototransistor-p90042
                                • sundberg84S sundberg84
                                  #60
                                  @sundberg84
                                  Instead of the 10k resistor, do you think I could use a potentiometer to "adjust" sensitivity? I would like to avoid messing up the readings with lights entering when opening the cabinet door where the meter is located
                                  @flopp
                                  Do you mind sharing your wiring? 940nm, isn't it infrared?
                                  sundberg84S F 2 Replies Last reply
                                    @sundberg84
                                    @flopp
                                    sundberg84S
                                    sundberg84S
                                    @gohan - a potentiometer is just a variable resistor so why not? Good idea if you have one laying around.
                                    As i said before though, the try with the transistor is just a try - im not that good with transistors yet and dont know how they work exactly. After this i read somewhere that the base resistor should be bigger to protect the transistor... dont know how to calculate that.
                                      @sundberg84
                                      @flopp
                                      F
                                      F
                                      flopp
                                      wrote on last edited by flopp
                                      #62
                                      @gohan said in 💬 Power Meter Pulse Sensor:
                                      @sundberg84
                                      @flopp
                                      I connected the photo resistor directly to the LM393.
                                      I don't know if that is IR.
                                      • moumout31M
                                        moumout31M
                                        moumout31
                                        First, thanks for this tutorial !
                                        I used the code defined in tutorial but I have the following message for "void receive(const MyMessage &message)" :
                                        'MyMessage' does not name a type
                                        Do you know what can be the cause of this error please ?
                                        Thanks in advance for your help
                                        • moumout31M moumout31
                                          #64
                                          @moumout31 do you have void receive(const MyMessage &message) somewhere in your code or where does it come from?
                                          Could you post the full error message?
                                          Have you installed the MySensors library?
                                          moumout31M 1 Reply Last reply
