  3. My Slim 2AA Battery Node
498 Posts 71 Posters 600.4k Views 69 Watching
  • rollercontainerR rollercontainer
    I only come down to 12µA with one reed switch, 1MOhm pullup, 1Mhz bootloader and the binarySwitchSleepSketch. Measured with two different multimeters. This is nearly ten times higher than in the first posting. Changing all internal pullups to LOW doesn't change anything.
    Is there a way to optimize the power consumption or is it "good enough" ?
    sundberg84S
    sundberg84S
    #377
    @rollercontainer - I just build a slimnode and 13uA is without anything connected what i can reach as well.
    For comparison i aim below 100uA when i do this with pro mini and they last around a year with 2xAA so my guess is 13uA is good enough.
    • AWIA AWI
      @rollercontainer For sub 8uA consumption you need to go to "deep sleep" where the internal timers of the processor are disabled. Only wake up on interrupt. sleep( interrupt1, FALLING, 0);
      rollercontainerR
      rollercontainerR
      rollercontainer
      @sundberg84: Thanks, so I will stick to my 12µA :-)
      @AWI: I am using sleep with Interrupt as in this example:
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
      https://github.com/mysensors/MySensors/blob/development/examples/BinarySwitchSleepSensor/BinarySwitchSleepSensor.ino#L120
      AWIA 1 Reply Last reply
        AWIA
        AWIA
        AWI
        @rollercontainer Your sleep looks good. Did you remove this piece of code?
        // Activate internal pull-ups
        Take a look at this thread for a < 1 uA consumption...
        rollercontainerR Tim AbelsT 2 Replies Last reply
        • A
          aneco
          wrote on last edited by aneco
          #380
          Since a few months I am very interested in Mysensors and this PCB. I have ordered the PCB and components to build some sensors as for a home security system. For experimental purpose I build one on a breadboard and that is working fine.
          A few days ago I started to solder the components on the PCB. The firs one is working fine, but the next sensors have an issue with the transceiver. After 3 boards failing I soldered one without the transceiver. Then I tested it by holding the transceiver at the board and it was working fine. After soldering the transceiver again a not working board.
          I tested one board by pressing another transceiver on top of the soldered one and I saw some communication in MYSController. The ATMega is still working on the breadboard. The PCB and Breadboard are powered by the same batterypack.
          Before soldering I tested all the transceivers with my breadboard and they are working fine. I am also using an anti-static bracelet.
          What am I doing wrong??
          • m26872M
            m26872M
            m26872
            Have you desoldered one radio to see if it's back alive again? What's your distance to Gateway? Maybe some filtering or antenna effect by your fingers and breadboard? What if you leave a working radio on the breadboard then just connect it with wires to PCB?
            • m26872M m26872
              aneco
              @m26872
              Distance is about 50cm. They are both on my desk. If testing then I do not tough the sensor. Just when trien pressing a radio an a non function radio.
              I tried to de-solder the radio but did not succeed. Cut the pins, removed them and soldered wires to it. Connected to a new radio. Strange part is that the on very irregular basis message are received in MYSController. Also with a radio which is functioning well on the breadboard
              • A aneco
                @m26872
                sundberg84S
                sundberg84S
                @aneco - 50cm is a big problem for me! Its to close and the node - gw is having a hard time communicating for some reason. I wish I didnt set my gw up in the workplace where i build because every time im testing some node I have to go to the next room. Maybe you could try this?
                • sundberg84S
                  sundberg84S
                  @m26872 - I made this (but with the big motiondec, because my small ones didnt work so well due to clone/copy). Thanks for PCB, instructions and tutorials. Great work!
                  Node is running at 13uA without motiondetector attached and 90-95uA with the motion dec attached. Im happy with that and ill see how long the batteries last. When my small motion dec arrive I can just switch over.
                  • sundberg84S sundberg84
                    aneco
                    @sundberg84
                    The node on the breadboard is on the same desk and same distance to gateway. The same for my first sensor. And both are working well. Only issue with 4 sensors a soldered afterwords.
                    Just remember now that I used for the first sensor other solder. But do not think that this is causing the issue or .....
                    • E
                      E
                      Eawo
                      Hello i wonder how you do then you put sensors outside mine stop work after a few hours i guess its becouse its cold here and maybe humitiy? then i take them inside for while it start working again. i think i need a waterprofe case or something
                        Well, batteries and components have working temperatures so it depends how cold it gets over there
                        • E
                          E
                          Eawo
                          Its one in the garage it is never below 0- C this one was alive the longest the other one was dead in 2-3days and maybe as coldest it was 10- C. I'm starting to think it's something wrong with the gateway
                            If you reset either node or gateway, does it go back to work or what?
                            • E
                              E
                              Eawo
                              No it doesn't only sometimes
                                If it was the gateway you should stop receiving data from other sensors too, right?
                                • AWIA AWI
                                  rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  @AWI said in My Slim 2AA Battery Node:
                                  Hmm, I noticed, that I have to disable the internal pullups. But instead of removing the lines, I set them to LOW. I will test it without the lines and come back. Thank you @AWI.
                                  • siodS
                                    siodS
                                    siod
                                    wrote on last edited by siod
                                    #393
                                    Ok, just want to give you an update:
                                    I have 3 sensors running in the moment, initially I planned to run a lot more, but I still have problems with freezing of the sensors. The Sensors ran 2 months now until they were not coummunicating anymore, 1 is still working. I restarted 1 of the freezed sensors and it just came back up and works fine again, I leave the other one "freezed" just to see if it would come up again...
                                    It´s sad that they are not very reliable but I don´t get what makes them freeze after working quiet good for such a long time (they are reporting every 15 minutes 24/7 and whenever a window is opened/closed).
                                    I don´t think it´s a temp thing, also power should be no problem, batteries are still about 80 % loaded...
                                    still learning...
                                    • rollercontainerR
                                      rollercontainerR
                                      rollercontainer
                                      Maybe there is something like a counter (variable++) which causes a overflow after two month?
                                      • siodS
                                        siodS
                                        siod
                                        No, not really, but if you want to you can check my code:
                                        // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                                        // Define Node ID
                                        #define MY_NODE_ID 1
                                        #define MY_PARENT_NODE_ID 0
                                        //Batterysensor
                                        int oldBatteryPcnt = 0;
                                        #define CHILD_ID_BATT 7
                                        //Kontaktschalter
                                        //#include <Bounce2.h>
                                        int oldValueReed1=-1;
                                        int oldValueReed2=-1;
                                        //Tempsensor
                                        #include <SparkFunHTU21D.h>
                                        #define CHILD_ID_HUM 3
                                        #define CHILD_ID_TEMP 4
                                        //tempsensor
                                        HTU21D myHumidity;
                                        float lastTemp;
                                        float lastHum;
                                        //boolean metric = true;
                                        //Messages
                                        //Battery
                                        // Kontaktschalter
                                        //TempMessage
                                        void presentation(){
                                          sendSketchInfo("Schlafzimmer Messstation", "2.0");
                                          present(CHILD1_ID, S_DOOR);
                                          present(CHILD2_ID, S_DOOR);
                                          //Tempsensor
                                          present(CHILD_ID_HUM, S_HUM);
                                          //Battery
                                        //Setup
                                          //Serial.begin(9600);
                                          Serial.println("Hello!");
                                          //Batterysensor
                                           analogReference(INTERNAL1V1);
                                           analogReference(INTERNAL);
                                        //Tempsensor
                                          myHumidity.begin();
                                          Serial.println("...done!");
                                        // Setup Kontaktschalter 1
                                          pinMode(BUTTON1_PIN,INPUT);
                                        // Setup Kontaktschalter 2
                                          pinMode(BUTTON2_PIN,INPUT);
                                        //Starte den Loop
                                          //Batterysensor
                                          // get the battery Voltage
                                          delay(1000);
                                           #ifdef DEBUG
                                           #ifdef DEBUG
                                           Serial.print(batteryV);
                                           Serial.println(" V");
                                           Serial.print(batteryPcnt);
                                           Serial.println(" %");
                                             // Power up radio after sleep
                                             send(msgbatt.set(batteryPcnt));
                                             oldBatteryPcnt = batteryPcnt;
                                          //Kontakstschalter 1
                                          wait(10);
                                          // Get the update value
                                             // Send in the new value
                                             send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                                             oldValueReed1 = valueReed1;
                                          //Kontakstschalter 2
                                             send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                                             oldValueReed2 = valueReed2;
                                         //Tempsensor
                                          if (isnan(temp)) {
                                            lastTemp = temp;
                                            send(msgTemp.set(temp, 1));
                                            Serial.print("T: ");
                                            Serial.println(temp);
                                          if (isnan(humd)) {
                                          } else if (humd != lastHum) {
                                              lastHum = humd;
                                              send(msgHum.set(humd, 1));
                                              Serial.print("H: ");
                                              Serial.println(humd);
                                         Serial.println("Sleep...");
                                        still learning...
                                        m26872M 1 Reply Last reply
                                        • AWIA AWI
                                          Tim AbelsT
                                          Tim AbelsT
                                          Tim Abels
                                          @AWI: I am down to 1,3 µA :+1:
                                          my code:
                                          #define MY_NODE_ID 66
                                          #include "Vcc.h"
                                          #define SKETCH_NAME "MySlim2aaBatteryNode"
                                          #define PRIMARY_CHILD_ID 3
                                          #define PRIMARY_BUTTON_PIN 3
                                          const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
                                          const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
                                          const float VccCorrection = 3.496 / 3.572;  // Measured Vcc by multimeter divided by reported Vcc
                                          const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
                                          Vcc vcc(VccCorrection);
                                          #ifdef MY_DEBUG
                                          void before(){
                                              Serial.begin(9600);
                                              sendSketchInfo(SKETCH_NAME, __DATE__);
                                              present(PRIMARY_CHILD_ID, S_DOOR, "Reed Contact");
                                              int32_t timestamp = millis();
                                              uint8_t reedState;
                                              static uint8_t lastReedState = 2;
                                              static int32_t lastBatteryReport = -report_interval; // for inital report
                                              sleep(5); // Short delay to allow buttons to properly settle
                                              reedState = digitalRead(PRIMARY_BUTTON_PIN);
                                              if ( (timestamp-lastBatteryReport) >= report_interval ) {
                                                uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
                                                lastBatteryReport = timestamp;
                                              if (reedState != lastReedState) {
                                                  // Value has changed from last transmission, send the updated reedState
                                                  send(msg.set(reedState==HIGH));
                                                  lastReedState = reedState;
                                              sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                                          AWIA m26872M 2 Replies Last reply
