  3. My Slim 2AA Battery Node
498 Posts 71 Posters 600.4k Views 69 Watching
  • E
    E
    Eawo
    Hello i wonder how you do then you put sensors outside mine stop work after a few hours i guess its becouse its cold here and maybe humitiy? then i take them inside for while it start working again. i think i need a waterprofe case or something
      Well, batteries and components have working temperatures so it depends how cold it gets over there
      • E
        E
        Eawo
        Its one in the garage it is never below 0- C this one was alive the longest the other one was dead in 2-3days and maybe as coldest it was 10- C. I'm starting to think it's something wrong with the gateway
          If you reset either node or gateway, does it go back to work or what?
          • E
            E
            Eawo
            No it doesn't only sometimes
              If it was the gateway you should stop receiving data from other sensors too, right?
              • AWIA AWI
                @rollercontainer Your sleep looks good. Did you remove this piece of code?
                // Activate internal pull-ups
                Take a look at this thread for a < 1 uA consumption...
                rollercontainerR
                rollercontainerR
                rollercontainer
                @AWI said in My Slim 2AA Battery Node:
                Hmm, I noticed, that I have to disable the internal pullups. But instead of removing the lines, I set them to LOW. I will test it without the lines and come back. Thank you @AWI.
                • siodS
                  siodS
                  siod
                  wrote on last edited by siod
                  #393
                  Ok, just want to give you an update:
                  I have 3 sensors running in the moment, initially I planned to run a lot more, but I still have problems with freezing of the sensors. The Sensors ran 2 months now until they were not coummunicating anymore, 1 is still working. I restarted 1 of the freezed sensors and it just came back up and works fine again, I leave the other one "freezed" just to see if it would come up again...
                  It´s sad that they are not very reliable but I don´t get what makes them freeze after working quiet good for such a long time (they are reporting every 15 minutes 24/7 and whenever a window is opened/closed).
                  I don´t think it´s a temp thing, also power should be no problem, batteries are still about 80 % loaded...
                  still learning...
                  • rollercontainerR
                    rollercontainerR
                    rollercontainer
                    Maybe there is something like a counter (variable++) which causes a overflow after two month?
                    • siodS
                      siodS
                      siod
                      No, not really, but if you want to you can check my code:
                      // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                      // Define Node ID
                      #define MY_NODE_ID 1
                      #define MY_PARENT_NODE_ID 0
                      //Batterysensor
                      int oldBatteryPcnt = 0;
                      #define CHILD_ID_BATT 7
                      //Kontaktschalter
                      //#include <Bounce2.h>
                      int oldValueReed1=-1;
                      int oldValueReed2=-1;
                      //Tempsensor
                      #include <SparkFunHTU21D.h>
                      #define CHILD_ID_HUM 3
                      #define CHILD_ID_TEMP 4
                      //tempsensor
                      HTU21D myHumidity;
                      float lastTemp;
                      float lastHum;
                      //boolean metric = true;
                      //Messages
                      //Battery
                      // Kontaktschalter
                      //TempMessage
                      void presentation(){
                        sendSketchInfo("Schlafzimmer Messstation", "2.0");
                        present(CHILD1_ID, S_DOOR);
                        present(CHILD2_ID, S_DOOR);
                        //Tempsensor
                        present(CHILD_ID_HUM, S_HUM);
                        //Battery
                      //Setup
                        //Serial.begin(9600);
                        Serial.println("Hello!");
                        //Batterysensor
                         analogReference(INTERNAL1V1);
                         analogReference(INTERNAL);
                      //Tempsensor
                        myHumidity.begin();
                        Serial.println("...done!");
                      // Setup Kontaktschalter 1
                        pinMode(BUTTON1_PIN,INPUT);
                      // Setup Kontaktschalter 2
                        pinMode(BUTTON2_PIN,INPUT);
                      //Starte den Loop
                        //Batterysensor
                        // get the battery Voltage
                        delay(1000);
                         #ifdef DEBUG
                         #ifdef DEBUG
                         Serial.print(batteryV);
                         Serial.println(" V");
                         Serial.print(batteryPcnt);
                         Serial.println(" %");
                           // Power up radio after sleep
                           send(msgbatt.set(batteryPcnt));
                           oldBatteryPcnt = batteryPcnt;
                        //Kontakstschalter 1
                        wait(10);
                        // Get the update value
                           // Send in the new value
                           send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                           oldValueReed1 = valueReed1;
                        //Kontakstschalter 2
                           send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                           oldValueReed2 = valueReed2;
                       //Tempsensor
                        if (isnan(temp)) {
                          lastTemp = temp;
                          send(msgTemp.set(temp, 1));
                          Serial.print("T: ");
                          Serial.println(temp);
                        if (isnan(humd)) {
                        } else if (humd != lastHum) {
                            lastHum = humd;
                            send(msgHum.set(humd, 1));
                            Serial.print("H: ");
                            Serial.println(humd);
                       Serial.println("Sleep...");
                      still learning...
                      m26872M 1 Reply Last reply
                      • AWIA AWI
                        Tim AbelsT
                        Tim AbelsT
                        Tim Abels
                        @AWI: I am down to 1,3 µA :+1:
                        my code:
                        #define MY_NODE_ID 66
                        #include "Vcc.h"
                        #define SKETCH_NAME "MySlim2aaBatteryNode"
                        #define PRIMARY_CHILD_ID 3
                        #define PRIMARY_BUTTON_PIN 3
                        const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
                        const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
                        const float VccCorrection = 3.496 / 3.572;  // Measured Vcc by multimeter divided by reported Vcc
                        const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
                        Vcc vcc(VccCorrection);
                        #ifdef MY_DEBUG
                        void before(){
                            Serial.begin(9600);
                            sendSketchInfo(SKETCH_NAME, __DATE__);
                            present(PRIMARY_CHILD_ID, S_DOOR, "Reed Contact");
                            int32_t timestamp = millis();
                            uint8_t reedState;
                            static uint8_t lastReedState = 2;
                            static int32_t lastBatteryReport = -report_interval; // for inital report
                            sleep(5); // Short delay to allow buttons to properly settle
                            reedState = digitalRead(PRIMARY_BUTTON_PIN);
                            if ( (timestamp-lastBatteryReport) >= report_interval ) {
                              uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
                              lastBatteryReport = timestamp;
                            if (reedState != lastReedState) {
                                // Value has changed from last transmission, send the updated reedState
                                send(msg.set(reedState==HIGH));
                                lastReedState = reedState;
                            sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                        AWIA m26872M 2 Replies Last reply
                        • siodS siod
                          // Define Node ID
                          //Batterysensor
                          //Kontaktschalter
                          //Tempsensor
                          //tempsensor
                          HTU21D myHumidity;
                          float lastTemp;
                          float lastHum;
                          //Messages
                          //Battery
                          // Kontaktschalter
                          //TempMessage
                            //Tempsensor
                            //Battery
                          //Setup
                            //Batterysensor
                          //Tempsensor
                            myHumidity.begin();
                          //Starte den Loop
                            //Batterysensor
                            delay(1000);
                             #ifdef DEBUG
                             #ifdef DEBUG
                            wait(10);
                           //Tempsensor
                            if (isnan(temp)) {
                              lastTemp = temp;
                            if (isnan(humd)) {
                                lastHum = humd;
                          m26872M
                          m26872M
                          m26872
                          @siod
                          Gateway issue? Other sensors working or all down at same time? Do you have a sniffer or listen-only gateway, or heartbeat LED attached to each sensor?
                          What's the purpose of the delay(1000)? It usually safer to use wait() or sleep() and perhaps also to deal with the interrupt results first. You could also try level interrupt instead of "change". You're not using indefinite sleep so it shouldn't be a problem, but try anyway..
                          siodS 1 Reply Last reply
                          • Tim AbelsT Tim Abels
                            my code:
                            #include "Vcc.h"
                            #ifdef MY_DEBUG
                            void before(){
                                Serial.begin(9600);
                                uint8_t reedState;
                            AWIA
                            AWIA
                            AWI
                            wrote on last edited by AWI
                            #398
                            @Tim-Abels :+1: that is how you do it
                            Be aware that the timer (millis()) is not running during sleep.
                            rollercontainerR 1 Reply Last reply
                              my code:
                              #include "Vcc.h"
                              #ifdef MY_DEBUG
                              void before(){
                                  Serial.begin(9600);
                                  uint8_t reedState;
                              m26872M
                              m26872M
                              m26872
                              wrote on last edited by m26872
                              #399
                              @Tim-Abels
                              1.3uA is nice!
                              A question about your sketch: Is millis() working because it's an interrupt-only sleep() or have I missed something else? As I recall it millis() stops working when using sleep().
                              Edit: Haha. @AWI got it before me! :smile:
                              • AWIA AWI
                                rollercontainerR
                                rollercontainerR
                                rollercontainer
                                @AWI one step forward, two steps back... Thanks for the hint.
                                I guess, I should send battery percentage every 10 interrupts or so. Even if the contact doesn't trigger for a while, I can force it by showing my neighbours my ocd on doors ^^ (knock, knock, knock - Penny!)
                                What do you think?
                                AWIA 1 Reply Last reply
                                • rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  Just noticed, that I use another login at home. So, the Tim-Abels is the rollercontainer... Sorry for that.
                                  • rollercontainerR rollercontainer
                                    What do you think?
                                    AWIA
                                    AWIA
                                    AWI
                                    @rollercontainer alias @Tim-Abels ;-) Sounds good, although with 1.3uA the battery won't show much variation..
                                    This is a similar on running on a coin cell (not calibrated). The voltage drop is caused mainly by the bad radio connection (many retries for sending > 10 mA)
                                    0_1487319381911_upload-02a06ce9-126d-49f2-bbcb-dd01c3cea3d4
                                    • rollercontainerR
                                      rollercontainerR
                                      rollercontainer
                                      wrote on last edited by rollercontainer
                                      #403
                                      Maybe its better to measure the voltage every 10 or 100 loops and only send one custom message/alert when its dropped below a threshold. I am using the MQTTClientGateway and Node-Red. In case of a battery-low message, node-red could send me an email with the node name. I will give it a try...
                                      From https://www.mysensors.org/download/serial_api_20:
                                      V_TEXT          47 	Text message to display on LCD or controller device 	S_INFO
                                      V_CUSTOM 	48 	Custom messages used for controller/inter node specific commands, preferably using S_CUSTOM device type. 	S_CUSTOM```
                                      • rollercontainerR
                                        rollercontainerR
                                        rollercontainer
                                        Did you considered a tiny solar cell like enocean does?
                                        https://www.enocean.com/en/enocean_modules/stm-320/
                                        That would be perfect...
                                        • rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          searched a bit and found that @ceech already made a harvester with a coin cell.
                                          http://www.ebay.de/itm/BQ25570-thermal-solar-energy-harvester-/332071662285
                                          still too big and too expensive in comparison with dozens of alkaline batteries which will run for years, but that is the way to go sometime.
