  3. My Slim 2AA Battery Node
498 Posts 71 Posters 598.5k Views 69 Watching
  • m26872M m26872
    Have you desoldered one radio to see if it's back alive again? What's your distance to Gateway? Maybe some filtering or antenna effect by your fingers and breadboard? What if you leave a working radio on the breadboard then just connect it with wires to PCB?
    aneco
    @m26872
    Distance is about 50cm. They are both on my desk. If testing then I do not tough the sensor. Just when trien pressing a radio an a non function radio.
    I tried to de-solder the radio but did not succeed. Cut the pins, removed them and soldered wires to it. Connected to a new radio. Strange part is that the on very irregular basis message are received in MYSController. Also with a radio which is functioning well on the breadboard
    • A aneco
      @m26872
      sundberg84S
      sundberg84S
      @aneco - 50cm is a big problem for me! Its to close and the node - gw is having a hard time communicating for some reason. I wish I didnt set my gw up in the workplace where i build because every time im testing some node I have to go to the next room. Maybe you could try this?
      A 1 Reply Last reply
      • sundberg84S
        sundberg84S
        @m26872 - I made this (but with the big motiondec, because my small ones didnt work so well due to clone/copy). Thanks for PCB, instructions and tutorials. Great work!
        Node is running at 13uA without motiondetector attached and 90-95uA with the motion dec attached. Im happy with that and ill see how long the batteries last. When my small motion dec arrive I can just switch over.
        • sundberg84S sundberg84
          aneco
          @sundberg84
          The node on the breadboard is on the same desk and same distance to gateway. The same for my first sensor. And both are working well. Only issue with 4 sensors a soldered afterwords.
          Just remember now that I used for the first sensor other solder. But do not think that this is causing the issue or .....
          • E
            E
            Eawo
            Hello i wonder how you do then you put sensors outside mine stop work after a few hours i guess its becouse its cold here and maybe humitiy? then i take them inside for while it start working again. i think i need a waterprofe case or something
              Well, batteries and components have working temperatures so it depends how cold it gets over there
              • E
                E
                Eawo
                Its one in the garage it is never below 0- C this one was alive the longest the other one was dead in 2-3days and maybe as coldest it was 10- C. I'm starting to think it's something wrong with the gateway
                  If you reset either node or gateway, does it go back to work or what?
                  • E
                    E
                    Eawo
                    No it doesn't only sometimes
                      If it was the gateway you should stop receiving data from other sensors too, right?
                      • AWIA AWI
                        @rollercontainer Your sleep looks good. Did you remove this piece of code?
                        // Activate internal pull-ups
                        Take a look at this thread for a < 1 uA consumption...
                        rollercontainerR
                        rollercontainerR
                        rollercontainer
                        @AWI said in My Slim 2AA Battery Node:
                        Hmm, I noticed, that I have to disable the internal pullups. But instead of removing the lines, I set them to LOW. I will test it without the lines and come back. Thank you @AWI.
                        • siodS
                          siodS
                          siod
                          wrote on last edited by siod
                          #393
                          Ok, just want to give you an update:
                          I have 3 sensors running in the moment, initially I planned to run a lot more, but I still have problems with freezing of the sensors. The Sensors ran 2 months now until they were not coummunicating anymore, 1 is still working. I restarted 1 of the freezed sensors and it just came back up and works fine again, I leave the other one "freezed" just to see if it would come up again...
                          It´s sad that they are not very reliable but I don´t get what makes them freeze after working quiet good for such a long time (they are reporting every 15 minutes 24/7 and whenever a window is opened/closed).
                          I don´t think it´s a temp thing, also power should be no problem, batteries are still about 80 % loaded...
                          still learning...
                          • rollercontainerR
                            rollercontainerR
                            rollercontainer
                            Maybe there is something like a counter (variable++) which causes a overflow after two month?
                            • siodS
                              siodS
                              siod
                              No, not really, but if you want to you can check my code:
                              // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
                              // Define Node ID
                              #define MY_NODE_ID 1
                              #define MY_PARENT_NODE_ID 0
                              //Batterysensor
                              int oldBatteryPcnt = 0;
                              #define CHILD_ID_BATT 7
                              //Kontaktschalter
                              //#include <Bounce2.h>
                              int oldValueReed1=-1;
                              int oldValueReed2=-1;
                              //Tempsensor
                              #include <SparkFunHTU21D.h>
                              #define CHILD_ID_HUM 3
                              #define CHILD_ID_TEMP 4
                              //tempsensor
                              HTU21D myHumidity;
                              float lastTemp;
                              float lastHum;
                              //boolean metric = true;
                              //Messages
                              //Battery
                              // Kontaktschalter
                              //TempMessage
                              void presentation(){
                                sendSketchInfo("Schlafzimmer Messstation", "2.0");
                                present(CHILD1_ID, S_DOOR);
                                present(CHILD2_ID, S_DOOR);
                                //Tempsensor
                                present(CHILD_ID_HUM, S_HUM);
                                //Battery
                              //Setup
                                //Serial.begin(9600);
                                Serial.println("Hello!");
                                //Batterysensor
                                 analogReference(INTERNAL1V1);
                                 analogReference(INTERNAL);
                              //Tempsensor
                                myHumidity.begin();
                                Serial.println("...done!");
                              // Setup Kontaktschalter 1
                                pinMode(BUTTON1_PIN,INPUT);
                              // Setup Kontaktschalter 2
                                pinMode(BUTTON2_PIN,INPUT);
                              //Starte den Loop
                                //Batterysensor
                                // get the battery Voltage
                                delay(1000);
                                 #ifdef DEBUG
                                 #ifdef DEBUG
                                 Serial.print(batteryV);
                                 Serial.println(" V");
                                 Serial.print(batteryPcnt);
                                 Serial.println(" %");
                                   // Power up radio after sleep
                                   send(msgbatt.set(batteryPcnt));
                                   oldBatteryPcnt = batteryPcnt;
                                //Kontakstschalter 1
                                wait(10);
                                // Get the update value
                                   // Send in the new value
                                   send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                                   oldValueReed1 = valueReed1;
                                //Kontakstschalter 2
                                   send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                                   oldValueReed2 = valueReed2;
                               //Tempsensor
                                if (isnan(temp)) {
                                  lastTemp = temp;
                                  send(msgTemp.set(temp, 1));
                                  Serial.print("T: ");
                                  Serial.println(temp);
                                if (isnan(humd)) {
                                } else if (humd != lastHum) {
                                    lastHum = humd;
                                    send(msgHum.set(humd, 1));
                                    Serial.print("H: ");
                                    Serial.println(humd);
                               Serial.println("Sleep...");
                              still learning...
                              m26872M 1 Reply Last reply
                              • AWIA AWI
                                Tim AbelsT
                                Tim AbelsT
                                Tim Abels
                                @AWI: I am down to 1,3 µA :+1:
                                my code:
                                #define MY_NODE_ID 66
                                #include "Vcc.h"
                                #define SKETCH_NAME "MySlim2aaBatteryNode"
                                #define PRIMARY_CHILD_ID 3
                                #define PRIMARY_BUTTON_PIN 3
                                const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
                                const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
                                const float VccCorrection = 3.496 / 3.572;  // Measured Vcc by multimeter divided by reported Vcc
                                const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
                                Vcc vcc(VccCorrection);
                                #ifdef MY_DEBUG
                                void before(){
                                    Serial.begin(9600);
                                    sendSketchInfo(SKETCH_NAME, __DATE__);
                                    present(PRIMARY_CHILD_ID, S_DOOR, "Reed Contact");
                                    int32_t timestamp = millis();
                                    uint8_t reedState;
                                    static uint8_t lastReedState = 2;
                                    static int32_t lastBatteryReport = -report_interval; // for inital report
                                    sleep(5); // Short delay to allow buttons to properly settle
                                    reedState = digitalRead(PRIMARY_BUTTON_PIN);
                                    if ( (timestamp-lastBatteryReport) >= report_interval ) {
                                      uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
                                      lastBatteryReport = timestamp;
                                    if (reedState != lastReedState) {
                                        // Value has changed from last transmission, send the updated reedState
                                        send(msg.set(reedState==HIGH));
                                        lastReedState = reedState;
                                    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                                AWIA m26872M 2 Replies Last reply
                                • siodS siod
                                  // Define Node ID
                                  //Batterysensor
                                  //Kontaktschalter
                                  //Tempsensor
                                  //tempsensor
                                  HTU21D myHumidity;
                                  float lastTemp;
                                  float lastHum;
                                  //Messages
                                  //Battery
                                  // Kontaktschalter
                                  //TempMessage
                                    //Tempsensor
                                    //Battery
                                  //Setup
                                    //Batterysensor
                                  //Tempsensor
                                    myHumidity.begin();
                                  //Starte den Loop
                                    //Batterysensor
                                    delay(1000);
                                     #ifdef DEBUG
                                     #ifdef DEBUG
                                    wait(10);
                                   //Tempsensor
                                    if (isnan(temp)) {
                                      lastTemp = temp;
                                    if (isnan(humd)) {
                                        lastHum = humd;
                                  m26872M
                                  m26872M
                                  m26872
                                  @siod
                                  Gateway issue? Other sensors working or all down at same time? Do you have a sniffer or listen-only gateway, or heartbeat LED attached to each sensor?
                                  What's the purpose of the delay(1000)? It usually safer to use wait() or sleep() and perhaps also to deal with the interrupt results first. You could also try level interrupt instead of "change". You're not using indefinite sleep so it shouldn't be a problem, but try anyway..
                                  siodS 1 Reply Last reply
                                  • Tim AbelsT Tim Abels
                                    my code:
                                    #include "Vcc.h"
                                    #ifdef MY_DEBUG
                                    void before(){
                                        Serial.begin(9600);
                                        uint8_t reedState;
                                    AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    #398
                                    @Tim-Abels :+1: that is how you do it
                                    Be aware that the timer (millis()) is not running during sleep.
                                    rollercontainerR 1 Reply Last reply
                                      my code:
                                      #include "Vcc.h"
                                      #ifdef MY_DEBUG
                                      void before(){
                                          Serial.begin(9600);
                                          uint8_t reedState;
                                      m26872M
                                      m26872M
                                      m26872
                                      wrote on last edited by m26872
                                      #399
                                      @Tim-Abels
                                      1.3uA is nice!
                                      A question about your sketch: Is millis() working because it's an interrupt-only sleep() or have I missed something else? As I recall it millis() stops working when using sleep().
                                      Edit: Haha. @AWI got it before me! :smile:
                                      • AWIA AWI
                                        rollercontainerR
                                        rollercontainerR
                                        rollercontainer
                                        @AWI one step forward, two steps back... Thanks for the hint.
                                        I guess, I should send battery percentage every 10 interrupts or so. Even if the contact doesn't trigger for a while, I can force it by showing my neighbours my ocd on doors ^^ (knock, knock, knock - Penny!)
                                        What do you think?
                                        AWIA 1 Reply Last reply
                                        • rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          Just noticed, that I use another login at home. So, the Tim-Abels is the rollercontainer... Sorry for that.
