  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
    On the raw file?
    https://raw.githubusercontent.com/mysensors/ArduinoHwSAMD/master/driver/mysensors-samd.inf
      On the raw file?
      MLs
      @hek
      https://github.com/mysensors/ArduinoHwSAMD/tree/master/driver
      I click on the link below the folder drivers
      //Mattias
        No, that will download a github html page.
        Use the link I posted (and save as). It will be the raw content.
        M 2 Replies Last reply
          MLs
          @hek
          I'll try it tomorrow is not so strange that it did not work for me then.
          //Mattias
            MLs
            @hek
            Now, I also got the computer to recognize the card. Thanks for all help.
            The problem was that even when I used save as, the computer renaming the file as a .txt file "mysensors-samd.inf.txt" and not a "mysensors-samd.inf"
            Again, thanks for all the help.
            //Mattias
              meddie
              Hi together,
              i have some questions to you! I bought a sensebender gateway and a w5100 Ethernet Modul, but i cant get it to work. When i upload the Gateway5100 Sketch and put my yip address in it, then the GW is booting up i get some Data on the serial port but i cant ping the configured ip address. Then i tried to config via DHCP and see that the GW dont get an IP Address.
              And when i connect the NRF24 Modul then it seems that the GW is not bootin up anymore because i dont get any data on serial port.
              i need your help. Thanks a lot in advance
              • tbowmoT
                tbowmoT
                tbowmo
                @meddie
                Could you please post the logs that you get on the serial port, when the W5100 is attached?
                Do you get anything on the serial port if you configure the sensebender to be a serial gateway, and only add a NRF24 module to it?
                  meddie
                  Hi tbowmo,
                  with the gatewayw5100 Sketch i get every 10 seconds 5 lines output on serial monitor:
                  The sketch is default i changed only the ip adress
                  0;255;3;0;9;TSM:FAIL:RE-INIT
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:FAIL:CNT=3
                  0;255;3;0;9;TSM:FAIL:PDT
                  0;255;3;0;9;TSM:FAIL:CNT=4
                  0;255;3;0;9;TSM:FAIL:CNT=5
                  0;255;3;0;9;
                  i dont know why, but i just uploaded the sensebenderserialgateway sketch and now i get this output:
                  0;255;3;0;9;TSF:LRT:OK
                  0;255;3;0;9;TSF:WUR:MS=0
                  0;255;3;0;9;TSM:INIT:TSP OK
                  0;255;3;0;9;TSM:INIT:GW MODE
                  0;255;0;0;18;2.1.1
                  0;255;3;0;9;MCO:BGN:STP
                  0;255;3;0;9;
                  the NRF Module is connected! Now i need to get the w5100 module to work.
                    meddie
                    wrote on last edited by meddie
                    #177
                    Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                    The orange, green and red led are lighting.
                    When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                    alexsh1A 1 Reply Last reply
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @meddie
                      Is it the standard GatewayW5100 sketch, without modifications, from the mysensors examples?
                      If you have done any modifications to the sketch, then please post your modified sketch here.
                        meddie
                        i have only changed the ip adress
                        here is the sketch:
                         * Version 1.0 - Henrik EKblad
                         * LED purposes:
                        #define MY_GATEWAY_W5100
                        //#define MY_W5100_SPI_EN 4
                        // radio on the same spi bus.
                        #define MY_SOFTSPI
                        #ifndef MY_RF24_CE_PIN
                        #define MY_RF24_CE_PIN 5
                        #ifndef MY_RF24_CS_PIN
                        #define MY_RF24_CS_PIN 6
                        // Enable to UDP
                        //#define MY_USE_UDP
                        #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
                        #define MY_PORT 5003
                        // Enable inclusion mode
                        // Set blinking period
                        // Flash leds on rx/tx/err
                        #if defined(MY_USE_UDP)
                        #include <EthernetUdp.h>
                        #include <Ethernet.h>
                        J 1 Reply Last reply
                        • M meddie
                          here is the sketch:
                           * LED purposes:
                          #define MY_SOFTSPI
                          // Enable to UDP
                          J
                          J
                          jeti
                          So I think i have a maybe already solved issue, but I can not get int working...
                          In Arduino IDE 1.8.1 this is the error during compiling:
                          "Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory"
                          • I have the MySensors SAMD boards installed, so Sensbender Gateway is availabe
                          • Arduino SAMD boards are also installed
                          • I have installed the "M0" boards
                          • Running windows 10 so no need for the inf file, is this correct?
                          what am I missing?
                          thanks in advance!
                          tekkaT 1 Reply Last reply
                          • J jeti
                            what am I missing?
                            thanks in advance!
                            tekkaT
                            tekkaT
                            tekka
                            wrote on last edited by tekka
                            #181
                            @jeti SAMD board defs 1.6.12 are currently not supported (PR filed) - you need to downgrade to 1.6.11 until the PR is merged.
                            • tekkaT tekka
                              J
                              J
                              jeti
                              @tekka thanks! that did the trick!
                              • J jeti
                                tekkaT
                                tekkaT
                                tekka
                                @jeti MySensors SAMD board defs updated to 1.0.5, supporting SAMD board defs 1.6.12
                                • TheoLT
                                  TheoLT
                                  TheoL
                                  It's has been a long time since I've posted on this forum.Today I received a note form the postal service that a package from a foreign country has arrived at my local postal office. Can't wait until tomorrow, just to see this beauty.
                                  Now I have to find some time to get it running ;-(
                                  • TheoLT TheoL
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @TheoL yeah, almost 4mo ago - good to have you back 👍
                                    TheoLT 1 Reply Last reply
                                    • tekkaT tekka
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @tekka life is really busy. But I'm working on some new MySensors idea's I'd like to try out. But for now on my way to the postal office. Can't wait.
                                      • tmn103T
                                        tmn103T
                                        tmn103
                                        Is there any way of getting the MQTT Ethernet gateway working on this yet?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @tmn103
                                          I haven't tried myself, but it should be the standard GatewayW5100MQTTClient sketch, without modifications. (the GatewayW5100 sketch is running without modifications already)
