  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
    meddie
    Hi together,
    i have some questions to you! I bought a sensebender gateway and a w5100 Ethernet Modul, but i cant get it to work. When i upload the Gateway5100 Sketch and put my yip address in it, then the GW is booting up i get some Data on the serial port but i cant ping the configured ip address. Then i tried to config via DHCP and see that the GW dont get an IP Address.
    And when i connect the NRF24 Modul then it seems that the GW is not bootin up anymore because i dont get any data on serial port.
    i need your help. Thanks a lot in advance
    • tbowmoT
      tbowmoT
      tbowmo
      @meddie
      Could you please post the logs that you get on the serial port, when the W5100 is attached?
      Do you get anything on the serial port if you configure the sensebender to be a serial gateway, and only add a NRF24 module to it?
        meddie
        Hi tbowmo,
        with the gatewayw5100 Sketch i get every 10 seconds 5 lines output on serial monitor:
        The sketch is default i changed only the ip adress
        0;255;3;0;9;TSM:FAIL:RE-INIT
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:FAIL:CNT=3
        0;255;3;0;9;TSM:FAIL:PDT
        0;255;3;0;9;TSM:FAIL:CNT=4
        0;255;3;0;9;TSM:FAIL:CNT=5
        0;255;3;0;9;
        i dont know why, but i just uploaded the sensebenderserialgateway sketch and now i get this output:
        0;255;3;0;9;TSF:LRT:OK
        0;255;3;0;9;TSF:WUR:MS=0
        0;255;3;0;9;TSM:INIT:TSP OK
        0;255;3;0;9;TSM:INIT:GW MODE
        0;255;0;0;18;2.1.1
        0;255;3;0;9;MCO:BGN:STP
        0;255;3;0;9;
        the NRF Module is connected! Now i need to get the w5100 module to work.
          meddie
          wrote on last edited by meddie
          #177
          Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
          The orange, green and red led are lighting.
          When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
          alexsh1A 1 Reply Last reply
          • tbowmoT
            tbowmoT
            tbowmo
            @meddie
            Is it the standard GatewayW5100 sketch, without modifications, from the mysensors examples?
            If you have done any modifications to the sketch, then please post your modified sketch here.
              meddie
              i have only changed the ip adress
              here is the sketch:
               * Version 1.0 - Henrik EKblad
               * LED purposes:
              #define MY_GATEWAY_W5100
              //#define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
              #define MY_SOFTSPI
              #ifndef MY_RF24_CE_PIN
              #define MY_RF24_CE_PIN 5
              #ifndef MY_RF24_CS_PIN
              #define MY_RF24_CS_PIN 6
              // Enable to UDP
              //#define MY_USE_UDP
              #define MY_IP_ADDRESS 10,0,0,253   // If this is disabled, DHCP is used to retrieve address
              #define MY_PORT 5003
              // Enable inclusion mode
              // Set blinking period
              // Flash leds on rx/tx/err
              #if defined(MY_USE_UDP)
              #include <EthernetUdp.h>
              #include <Ethernet.h>
              J 1 Reply Last reply
              • M meddie
                here is the sketch:
                 * LED purposes:
                #define MY_SOFTSPI
                // Enable to UDP
                J
                J
                jeti
                So I think i have a maybe already solved issue, but I can not get int working...
                In Arduino IDE 1.8.1 this is the error during compiling:
                "Local\Arduino15\packages\arduino\hardware\samd\1.6.12\cores\arduino/Arduino.h:48:17: fatal error: sam.h: No such file or directory"
                • I have the MySensors SAMD boards installed, so Sensbender Gateway is availabe
                • Arduino SAMD boards are also installed
                • I have installed the "M0" boards
                • Running windows 10 so no need for the inf file, is this correct?
                what am I missing?
                thanks in advance!
                tekkaT 1 Reply Last reply
                • J jeti
                  what am I missing?
                  thanks in advance!
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #181
                  @jeti SAMD board defs 1.6.12 are currently not supported (PR filed) - you need to downgrade to 1.6.11 until the PR is merged.
                  • tekkaT tekka
                    J
                    J
                    jeti
                    @tekka thanks! that did the trick!
                    • J jeti
                      tekkaT
                      tekkaT
                      tekka
                      @jeti MySensors SAMD board defs updated to 1.0.5, supporting SAMD board defs 1.6.12
                      • TheoLT
                        TheoLT
                        TheoL
                        It's has been a long time since I've posted on this forum.Today I received a note form the postal service that a package from a foreign country has arrived at my local postal office. Can't wait until tomorrow, just to see this beauty.
                        Now I have to find some time to get it running ;-(
                        • TheoLT TheoL
                          tekkaT
                          tekkaT
                          tekka
                          @TheoL yeah, almost 4mo ago - good to have you back 👍
                          TheoLT 1 Reply Last reply
                          • tekkaT tekka
                            TheoLT
                            TheoLT
                            TheoL
                            @tekka life is really busy. But I'm working on some new MySensors idea's I'd like to try out. But for now on my way to the postal office. Can't wait.
                            • tmn103T
                              tmn103T
                              tmn103
                              Is there any way of getting the MQTT Ethernet gateway working on this yet?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @tmn103
                                I haven't tried myself, but it should be the standard GatewayW5100MQTTClient sketch, without modifications. (the GatewayW5100 sketch is running without modifications already)
                                • tmn103T
                                  tmn103T
                                  tmn103
                                  Just tried the MQTT gateway sketch and got some strange behaviour.
                                  Seems to pick up one of the nodes, but can't get an ip address or mqtt connection.
                                  Any ideas on what to try?
                                  IP: 0.0.0.0
                                  0;255;3;0;9;TSF:MSG:READ,113-113-0,s=0,c=1,t=0,pt=7,l=5,sg=0:20.8
                                  IP: 255.255.255.255
                                  IP: 0.0.0.0
                                  IP: 255.255.255.255
                                  IP: 0.0.0.0
                                  IP: 255.255.255.255
                                  IP: 0.0.0.0
                                  blaceyB 1 Reply Last reply
                                  • tmn103T
                                    tmn103T
                                    tmn103
                                    Still can't get the mqtt gateway to work. Has anybody managed to?
                                    • F
                                      F
                                      Fabien
                                      Just try standard GatewayW5100MQTTClient sketch. It works fine with RFM69HW
                                      On your log you seems to have issue with your IP. Just my log :
                                      IP: 192.168.1.47
                                      0;255;3;0;9;MQTT connected
                                      0;255;3;0;9;TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSF:MSG:BC
                                      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=15
                                      0;255;3;0;9;TSF:PNG:SEND,TO=0
                                      0;255;3;0;9;TSF:CKU:OK
                                      0;255;3;0;9;TSF:MSG:GWL OK
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      0;255;3;0;9;TSF:MSG:READ,15-15-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                      0;255;3;0;9;TSF:MSG:PINGED,ID=15,HP=1
                                      0;255;3;0;9;TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      0;255;3;0;9;Sending message on topic: mygateway1-out/15/3/1/0/16
                                      • tmn103T tmn103
                                        IP: 0.0.0.0
                                        IP: 255.255.255.255
                                        IP: 0.0.0.0
                                        IP: 255.255.255.255
                                        IP: 0.0.0.0
                                        IP: 255.255.255.255
                                        IP: 0.0.0.0
                                        blaceyB
                                        blaceyB
                                        blacey
                                        @tmn103 said in 💬 Sensebender Gateway:
                                        IP: 255.255.255.255
                                        IP: 0.0.0.0
                                        I would triple-check the IP addresses that you are using...
                                          meddie
                                          i have uploaded this securitypersonalizer.ino sketch:
                                           * @ingroup MySigninggrp
                                           * @file SecurityPersonalizer.ino
                                           * @brief Security personalization sketch
                                           *  - See git log (git log libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino)
                                           * @example SecurityPersonalizer.ino
                                           * This sketch will personalize either none-volatile memory or ATSHA204A for security functions
                                           * available in the MySensors library.
                                           * For ATSHA204A:
                                           * It will write factory default settings to the configuration zone
                                           * and then lock it.<br>
                                           * It will then either<br>
                                           * -# Generate a random value to use as a key which will be stored in
                                           * slot 0. The key is printed on UART (115200) in clear text for the user to be
                                           * able to use it as a user-supplied key in other personalization executions
                                           * where the same key is needed.
                                           * -# Use a user-supplied value to use as a key which will be stored in
                                           * slot 0.
                                           * Finally it will lock the data zone.
                                           * By default, no locking is performed. User have to manually enable the flags that
                                           * turn on the locking. Furthermore, user have to send a SPACE character on serial
                                           * console when prompted to do any locking. On boards that does not provide UART
                                           * input it is possible to configure the sketch to skip this confirmation.
                                           * Default settings use ATSHA204A on @ref MY_SIGNING_ATSHA204_PIN.
                                           * For Soft signing:
                                           * It will<br>
                                           * -# Generate a random value to use as a key which will be stored in EEPROM.
                                           * The key is printed on UART (115200) in clear text for the user to be ablle to
                                           * use it as a user-supplied key in other personalization executions where the same
                                           * key is needed.
                                           * -# Use a user-supplied value to use as a key which will be stored in EEPROM.
                                           * -# Generate a random value to use as a serial number which will be stored in EEPROM.
                                           * The serial number is printed on UART (115200) in clear text for the user to be ablle to
                                           * use it as a user-supplied serial number in other personalization executions where the
                                           * serial is needed (typically for a whitelist).
                                           * -# Use a user-supplied value to use as a serial which will be stored in EEPROM.
                                           * For Encryption support:
                                           * -# Generate a random value to use as a AES key which will be stored in EEPROM.
                                           * The AES key is printed on UART (115200) in clear text for the user to be ablle to
                                           * use it as a user-supplied AES key in other personalization executions where the
                                           * AES key is needed (typically for RF encryption).
                                           * -# Use a user-supplied value to use as a AES key which will be stored in EEPROM.
                                           * Personalizing EEPROM or ATSHA204A still require the appropriate configuration of the
                                           * library to actually have an effect. There is no problem personalizing EEPROM and
                                           * ATSHA204A at the same time. There is however a security risk with using the same
                                           * data for EEPROM and ATSHA204A so it is recommended to use different serial and HMAC
                                           * keys on the same device for ATSHA204A vs soft signing settings.
                                           * Details on personalization procedure is given in @ref personalization.
                                          #include "sha204_library.h"
                                          #define MY_CORE_ONLY
                                          #if DOXYGEN
                                          #define LOCK_CONFIGURATION
                                          #define LOCK_DATA
                                          #define SKIP_KEY_STORAGE
                                          #define USER_KEY
                                          #define SKIP_UART_CONFIRMATION
                                          #define USE_SOFT_SIGNING
                                          #define STORE_SOFT_KEY
                                          #define USER_SOFT_KEY
                                          #define STORE_SOFT_SERIAL
                                          #define USER_SOFT_SERIAL
                                          #define STORE_AES_KEY
                                          #define USER_AES_KEY
                                           * @def LOCK_CONFIGURATION
                                           * @brief Uncomment this to enable locking the configuration zone.
                                           * It is still possible to change the key, and this also enable random key generation.
                                           * @warning BE AWARE THAT THIS PREVENTS ANY FUTURE CONFIGURATION CHANGE TO THE CHIP
                                           * @def LOCK_DATA
                                           * @brief Uncomment this to enable locking the data zone.
                                           * It is not required to lock data, key cannot be retrieved anyway, but by locking
                                           * data, it can be guaranteed that nobody even with physical access to the chip,
                                           * will be able to change the key.
                                           * @warning BE AWARE THAT THIS PREVENTS THE KEY TO BE CHANGED
                                          //#define LOCK_DATA
                                           * @def SKIP_KEY_STORAGE
                                           * @brief Uncomment this to skip key storage (typically once key has been written once)
                                           * @def USER_KEY
                                           * @brief Uncomment this to skip key generation and use @ref user_key_data as key instead.
                                          //#define USER_KEY
                                           * @def SKIP_UART_CONFIRMATION
                                           * @brief Uncomment this for boards that lack UART
                                           * @b Important<br> No confirmation will be required for locking any zones with this configuration!
                                           * Also, key generation is not permitted in this mode as there is no way of presenting the generated key.
                                           * @def USE_SOFT_SIGNING
                                           * @brief Uncomment this to store data to EEPROM instead of ATSHA204A
                                          //#define USE_SOFT_SIGNING
                                           * @def STORE_SOFT_KEY
                                           * @brief Uncomment this to store soft HMAC key to EEPROM
                                          //#define STORE_SOFT_KEY
                                           * @def USER_SOFT_KEY
                                           * @brief Uncomment this to skip soft HMAC key generation and use @ref user_soft_key_data as HMAC key instead.
                                          //#define USER_SOFT_KEY
                                           * @def STORE_SOFT_SERIAL
                                           * @brief Uncomment this to store soft serial to EEPROM
                                          //#define STORE_SOFT_SERIAL
                                           * @def USER_SOFT_SERIAL
                                           * @brief Uncomment this to skip soft serial generation and use @ref user_soft_serial as serial instead.
                                          //#define USER_SOFT_SERIAL
                                           * @def STORE_AES_KEY
                                           * @brief Uncomment this to store AES key to EEPROM
                                          //#define STORE_AES_KEY
                                           * @def USER_AES_KEY
                                           * @brief Uncomment this to skip AES key generation and use @ref user_aes_key as key instead.
                                          //#define USER_AES_KEY
                                          #ifdef USER_KEY
                                          #ifdef USER_SOFT_KEY
                                          #ifdef USER_SOFT_SERIAL
                                          #ifdef USER_AES_KEY
                                          #ifndef USE_SOFT_SIGNING
                                          void halt()
                                          	while(1);
                                           * @brief Write default configuration and return CRC of the configuration bits
                                           * @returns CRC over the configuration bits
                                          	uint16_t crc = 0;
                                          	uint8_t config_word[4];
                                          	uint8_t ret_code;
                                          	bool do_write;
                                          	// We will set default settings from datasheet on all slots. This means that we can use slot 0 for the key
                                          	// as that slot will not be readable (key will therefore be secure) and slot 8 for the payload digest
                                          	// calculationon as that slot can be written in clear text even when the datazone is locked.
                                          	// Other settings which are not relevant are kept as is.
                                          		do_write = true;
                                          		if (i == 20) {
                                          			config_word[0] = 0x8F;
                                          			config_word[1] = 0x80;
                                          			config_word[2] = 0x80;
                                          			config_word[3] = 0xA1;
                                          		} else if (i == 24) {
                                          			config_word[0] = 0x82;
                                          			config_word[1] = 0xE0;
                                          			config_word[2] = 0xA3;
                                          			config_word[3] = 0x60;
                                          		} else if (i == 28) {
                                          			config_word[0] = 0x94;
                                          			config_word[1] = 0x40;
                                          			config_word[2] = 0xA0;
                                          			config_word[3] = 0x85;
                                          		} else if (i == 32) {
                                          			config_word[0] = 0x86;
                                          			config_word[2] = 0x87;
                                          			config_word[3] = 0x07;
                                          		} else if (i == 36) {
                                          			config_word[0] = 0x0F;
                                          			config_word[1] = 0x00;
                                          			config_word[2] = 0x89;
                                          			config_word[3] = 0xF2;
                                          		} else if (i == 40) {
                                          			config_word[0] = 0x8A;
                                          			config_word[1] = 0x7A;
                                          			config_word[2] = 0x0B;
                                          			config_word[3] = 0x8B;
                                          		} else if (i == 44) {
                                          			config_word[0] = 0x0C;
                                          			config_word[1] = 0x4C;
                                          			config_word[2] = 0xDD;
                                          			config_word[3] = 0x4D;
                                          		} else if (i == 48) {
                                          			config_word[0] = 0xC2;
                                          			config_word[1] = 0x42;
                                          			config_word[2] = 0xAF;
                                          			config_word[3] = 0x8F;
                                          			config_word[0] = 0xFF;
                                          			config_word[2] = 0xFF;
                                          			config_word[3] = 0x00;
                                          			config_word[1] = 0xFF;
                                          			config_word[3] = 0xFF;
                                          				halt();
                                          			do_write = false;
                                          		// Write config word
                                          		if (do_write) {
                                          				Serial.print(i);
                                          				halt();
                                          	return crc;
                                          void write_key(uint8_t* key)
                                          	uint8_t ret_code;
                                          	// Write key to slot 0
                                          		halt();
                                          void dump_configuration()
                                          	uint8_t buffer[32];
                                          	for (int j=0; j<32; j++) {
                                          		if (buffer[j] < 0x10) {
                                          		Serial.print(buffer[j], HEX);
                                          	Serial.println();
                                          	for (int j=0; j<9; j++) {
                                          	Serial.println();
                                          	for (int j=0; j<16; j++) {
                                          	Serial.println();
                                          	uint8_t ret_code;
                                          			halt();
                                          		if (i == 0x00) {
                                          			for (int j=0; j<4; j++) {
                                          				if (j == 1) {
                                          					Serial.print(F(" | "));
                                          					Serial.print(F("   "));
                                          			Serial.println();
                                          		} else if (i == 0x04) {
                                          			Serial.println();
                                          		} else if (i == 0x08) {
                                          			Serial.println();
                                          		} else if (i == 0x0C) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x10) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x14) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x18) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x1C) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x20) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x24) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x28) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x2C) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x30) {
                                          				if (j == 1) {
                                          			Serial.println();
                                          		} else if (i == 0x34) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x38) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x3C) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x40) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          		} else if (i == 0x44) {
                                          			Serial.println();
                                          		} else if (i == 0x48) {
                                          			Serial.println();
                                          		} else if (i == 0x4C) {
                                          			Serial.println();
                                          		} else if (i == 0x50) {
                                          			Serial.println();
                                          		} else if (i == 0x54) {
                                          				if (j < 3) {
                                          			Serial.println();
                                          	uint8_t ret_code;
                                          	uint8_t lockConfig = 0;
                                          	uint8_t lockValue = 0;
                                          	uint16_t crc;
                                          	(void)crc;
                                          	// initialize pseudo-RNG
                                          	uint8_t key[32];
                                          	(void)key;
                                          	hwInit();
                                          		halt();
                                          		halt();
                                          #ifdef STORE_SOFT_KEY
                                          #ifdef USE_SOFT_SIGNING
                                          		halt();
                                          	if (lockConfig == 0x00) {
                                          #endif // not USER_SOFT_KEY
                                          	for (int i=0; i<32; i++) {
                                          		Serial.print("0x");
                                          		if (key[i] < 0x10) {
                                          		Serial.print(key[i], HEX);
                                          		if (i < 31) {
                                          			Serial.print(',');
                                          	Serial.println();
                                          #endif // STORE_SOFT_KEY
                                          #ifdef STORE_SOFT_SERIAL
                                          	for (int i = 0; i < 9; i++) {
                                          		halt();
                                          	for (int i=0; i<9; i++) {
                                          		Serial.print("0x");
                                          		if (i < 8) {
                                          			Serial.print(',');
                                          	Serial.println();
                                          #endif // STORE_SOFT_SERIAL
                                          #ifdef STORE_AES_KEY
                                          #ifdef USER_AES_KEY
                                          		halt();
                                          .... i have cut the rest of code because its to long to post here complete ...
                                          but i dont get any output on serial monitor. Do you know whaat is went wrong?
                                          thanks
                                          AnticimexA 1 Reply Last reply
