  3. My Slim 2AA Battery Node
498 Posts 71 Posters 597.7k Views 69 Watching
  • E
    E
    Eawo
    No it doesn't only sometimes
      If it was the gateway you should stop receiving data from other sensors too, right?
      • AWIA AWI
        @rollercontainer Your sleep looks good. Did you remove this piece of code?
        // Activate internal pull-ups
        Take a look at this thread for a < 1 uA consumption...
        rollercontainerR
        rollercontainerR
        rollercontainer
        @AWI said in My Slim 2AA Battery Node:
        Hmm, I noticed, that I have to disable the internal pullups. But instead of removing the lines, I set them to LOW. I will test it without the lines and come back. Thank you @AWI.
        • siodS
          siodS
          siod
          wrote on last edited by siod
          #393
          Ok, just want to give you an update:
          I have 3 sensors running in the moment, initially I planned to run a lot more, but I still have problems with freezing of the sensors. The Sensors ran 2 months now until they were not coummunicating anymore, 1 is still working. I restarted 1 of the freezed sensors and it just came back up and works fine again, I leave the other one "freezed" just to see if it would come up again...
          It´s sad that they are not very reliable but I don´t get what makes them freeze after working quiet good for such a long time (they are reporting every 15 minutes 24/7 and whenever a window is opened/closed).
          I don´t think it´s a temp thing, also power should be no problem, batteries are still about 80 % loaded...
          still learning...
          • rollercontainerR
            rollercontainerR
            rollercontainer
            Maybe there is something like a counter (variable++) which causes a overflow after two month?
            • siodS
              siodS
              siod
              No, not really, but if you want to you can check my code:
              // Sensor Node Schlafzimmer mit HTU21D Temp/Hum Sensor, Fensterkontakte an Interrupt PINS Digital 5&6. Sleep Time 15 Minutwn, wake up wenn Fenster geöffnet/geschlossen wird.
              // Define Node ID
              #define MY_NODE_ID 1
              #define MY_PARENT_NODE_ID 0
              //Batterysensor
              int oldBatteryPcnt = 0;
              #define CHILD_ID_BATT 7
              //Kontaktschalter
              //#include <Bounce2.h>
              int oldValueReed1=-1;
              int oldValueReed2=-1;
              //Tempsensor
              #include <SparkFunHTU21D.h>
              #define CHILD_ID_HUM 3
              #define CHILD_ID_TEMP 4
              //tempsensor
              HTU21D myHumidity;
              float lastTemp;
              float lastHum;
              //boolean metric = true;
              //Messages
              //Battery
              // Kontaktschalter
              //TempMessage
              void presentation(){
                sendSketchInfo("Schlafzimmer Messstation", "2.0");
                present(CHILD1_ID, S_DOOR);
                present(CHILD2_ID, S_DOOR);
                //Tempsensor
                present(CHILD_ID_HUM, S_HUM);
                //Battery
              //Setup
                //Serial.begin(9600);
                Serial.println("Hello!");
                //Batterysensor
                 analogReference(INTERNAL1V1);
                 analogReference(INTERNAL);
              //Tempsensor
                myHumidity.begin();
                Serial.println("...done!");
              // Setup Kontaktschalter 1
                pinMode(BUTTON1_PIN,INPUT);
              // Setup Kontaktschalter 2
                pinMode(BUTTON2_PIN,INPUT);
              //Starte den Loop
                //Batterysensor
                // get the battery Voltage
                delay(1000);
                 #ifdef DEBUG
                 #ifdef DEBUG
                 Serial.print(batteryV);
                 Serial.println(" V");
                 Serial.print(batteryPcnt);
                 Serial.println(" %");
                   // Power up radio after sleep
                   send(msgbatt.set(batteryPcnt));
                   oldBatteryPcnt = batteryPcnt;
                //Kontakstschalter 1
                wait(10);
                // Get the update value
                   // Send in the new value
                   send(msgReed1.set(valueReed1==HIGH ? 1 : 0));
                   oldValueReed1 = valueReed1;
                //Kontakstschalter 2
                   send(msgReed2.set(valueReed2==HIGH ? 1 : 0));
                   oldValueReed2 = valueReed2;
               //Tempsensor
                if (isnan(temp)) {
                  lastTemp = temp;
                  send(msgTemp.set(temp, 1));
                  Serial.print("T: ");
                  Serial.println(temp);
                if (isnan(humd)) {
                } else if (humd != lastHum) {
                    lastHum = humd;
                    send(msgHum.set(humd, 1));
                    Serial.print("H: ");
                    Serial.println(humd);
               Serial.println("Sleep...");
              still learning...
              m26872M 1 Reply Last reply
              • AWIA AWI
                Tim AbelsT
                Tim AbelsT
                Tim Abels
                @AWI: I am down to 1,3 µA :+1:
                my code:
                #define MY_NODE_ID 66
                #include "Vcc.h"
                #define SKETCH_NAME "MySlim2aaBatteryNode"
                #define PRIMARY_CHILD_ID 3
                #define PRIMARY_BUTTON_PIN 3
                const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
                const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
                const float VccCorrection = 3.496 / 3.572;  // Measured Vcc by multimeter divided by reported Vcc
                const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
                Vcc vcc(VccCorrection);
                #ifdef MY_DEBUG
                void before(){
                    Serial.begin(9600);
                    sendSketchInfo(SKETCH_NAME, __DATE__);
                    present(PRIMARY_CHILD_ID, S_DOOR, "Reed Contact");
                    int32_t timestamp = millis();
                    uint8_t reedState;
                    static uint8_t lastReedState = 2;
                    static int32_t lastBatteryReport = -report_interval; // for inital report
                    sleep(5); // Short delay to allow buttons to properly settle
                    reedState = digitalRead(PRIMARY_BUTTON_PIN);
                    if ( (timestamp-lastBatteryReport) >= report_interval ) {
                      uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
                      lastBatteryReport = timestamp;
                    if (reedState != lastReedState) {
                        // Value has changed from last transmission, send the updated reedState
                        send(msg.set(reedState==HIGH));
                        lastReedState = reedState;
                    sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
                AWIA m26872M 2 Replies Last reply
                • siodS siod
                  // Define Node ID
                  //Batterysensor
                  //Kontaktschalter
                  //Tempsensor
                  //tempsensor
                  HTU21D myHumidity;
                  float lastTemp;
                  float lastHum;
                  //Messages
                  //Battery
                  // Kontaktschalter
                  //TempMessage
                    //Tempsensor
                    //Battery
                  //Setup
                    //Batterysensor
                  //Tempsensor
                    myHumidity.begin();
                  //Starte den Loop
                    //Batterysensor
                    delay(1000);
                     #ifdef DEBUG
                     #ifdef DEBUG
                    wait(10);
                   //Tempsensor
                    if (isnan(temp)) {
                      lastTemp = temp;
                    if (isnan(humd)) {
                        lastHum = humd;
                  m26872M
                  m26872M
                  m26872
                  @siod
                  Gateway issue? Other sensors working or all down at same time? Do you have a sniffer or listen-only gateway, or heartbeat LED attached to each sensor?
                  What's the purpose of the delay(1000)? It usually safer to use wait() or sleep() and perhaps also to deal with the interrupt results first. You could also try level interrupt instead of "change". You're not using indefinite sleep so it shouldn't be a problem, but try anyway..
                  siodS 1 Reply Last reply
                  • Tim AbelsT Tim Abels
                    my code:
                    #include "Vcc.h"
                    #ifdef MY_DEBUG
                    void before(){
                        Serial.begin(9600);
                        uint8_t reedState;
                    AWIA
                    AWIA
                    AWI
                    wrote on last edited by AWI
                    #398
                    @Tim-Abels :+1: that is how you do it
                    Be aware that the timer (millis()) is not running during sleep.
                    rollercontainerR 1 Reply Last reply
                      my code:
                      #include "Vcc.h"
                      #ifdef MY_DEBUG
                      void before(){
                          Serial.begin(9600);
                          uint8_t reedState;
                      m26872M
                      m26872M
                      m26872
                      wrote on last edited by m26872
                      #399
                      @Tim-Abels
                      1.3uA is nice!
                      A question about your sketch: Is millis() working because it's an interrupt-only sleep() or have I missed something else? As I recall it millis() stops working when using sleep().
                      Edit: Haha. @AWI got it before me! :smile:
                      • AWIA AWI
                        rollercontainerR
                        rollercontainerR
                        rollercontainer
                        @AWI one step forward, two steps back... Thanks for the hint.
                        I guess, I should send battery percentage every 10 interrupts or so. Even if the contact doesn't trigger for a while, I can force it by showing my neighbours my ocd on doors ^^ (knock, knock, knock - Penny!)
                        What do you think?
                        AWIA 1 Reply Last reply
                        • rollercontainerR
                          rollercontainerR
                          rollercontainer
                          Just noticed, that I use another login at home. So, the Tim-Abels is the rollercontainer... Sorry for that.
                          • rollercontainerR rollercontainer
                            What do you think?
                            AWIA
                            AWIA
                            AWI
                            @rollercontainer alias @Tim-Abels ;-) Sounds good, although with 1.3uA the battery won't show much variation..
                            This is a similar on running on a coin cell (not calibrated). The voltage drop is caused mainly by the bad radio connection (many retries for sending > 10 mA)
                            0_1487319381911_upload-02a06ce9-126d-49f2-bbcb-dd01c3cea3d4
                            • rollercontainerR
                              rollercontainerR
                              rollercontainer
                              wrote on last edited by rollercontainer
                              #403
                              Maybe its better to measure the voltage every 10 or 100 loops and only send one custom message/alert when its dropped below a threshold. I am using the MQTTClientGateway and Node-Red. In case of a battery-low message, node-red could send me an email with the node name. I will give it a try...
                              From https://www.mysensors.org/download/serial_api_20:
                              V_TEXT          47 	Text message to display on LCD or controller device 	S_INFO
                              V_CUSTOM 	48 	Custom messages used for controller/inter node specific commands, preferably using S_CUSTOM device type. 	S_CUSTOM```
                              • rollercontainerR
                                rollercontainerR
                                rollercontainer
                                Did you considered a tiny solar cell like enocean does?
                                https://www.enocean.com/en/enocean_modules/stm-320/
                                That would be perfect...
                                • rollercontainerR
                                  rollercontainerR
                                  rollercontainer
                                  searched a bit and found that @ceech already made a harvester with a coin cell.
                                  http://www.ebay.de/itm/BQ25570-thermal-solar-energy-harvester-/332071662285
                                  still too big and too expensive in comparison with dozens of alkaline batteries which will run for years, but that is the way to go sometime.
                                  • m26872M m26872
                                    @siod
                                    siodS
                                    siodS
                                    siod
                                    @m26872 said in My Slim 2AA Battery Node:
                                    @siod
                                    @m26872
                                    Gateway seems to work fine as the 3rd and still working sensor is still communicating. Also the freezed sensors start communicating after I restarted the sensor, not the GW. So I don´t see a problem with the GW.
                                    "Do you have a sniffer or listen-only gateway" -sorry, don´t know what this is o0 !?
                                    I have not attached a heartbeat LED yet, but that´s sth. I could do as a next step...
                                    The delay (1000) was initially planned to settle the sensors a bit and gie me abetter Battery reading, but as it is not working as it was intended I will delete it in a future update...
                                    You could also try level interrupt instead of "change" -again, I don´t know what you are talking about here, hope you can help me out.
                                    Thanks so far!!
                                    still learning...
                                    • siodS siod
                                      @siod
                                      @m26872
                                      Thanks so far!!
                                      m26872M
                                      m26872M
                                      m26872
                                      #407
                                      @siod said in My Slim 2AA Battery Node:
                                      I meant the https://www.mysensors.org/controller/sniffer, but I think it's easier to equip sensors with Radio Traffic LEDs and/or your own heartbeat/error LEDs.
                                      I suggest you start with deleting or replacing this delay. It could be it.
                                      I think you had pull-up inputs. Then it's just to replace the CHANGE with LOW in your call to sleep().
                                      Thanks so far!!
                                      My personal troubleshooting method in cases like these (and too many others) is just exhaustive use of the good old substitution method. Hw, Sw, entire systems or whatever you can do. :grimacing:
                                      • siodS
                                        siodS
                                        siod
                                        #408
                                        deleted - it´s working now, I must have made a mistake... :blush:
                                        edit:
                                        one strange thing: The sensor should report every 15 minutes (900000 milisecs), but it reports only every 18 minutes. Don´t know why.
                                        still learning...
                                        • K
                                          K
                                          Komaandy
                                          Hello everybody,
                                          I´m struggeling with getting the https://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor
                                          to work.
                                          The node registers with the GW, but doesnt submit the tripped reading.
                                          Not even a permanent on or something. Just nothing. So i dont know how to troubleshoot here.
                                          The PIR HC-SR505 is functional. I tested it with a testscript on a UNO.
                                          And the 2AA Slimnode is functional as well. When using the node as a binary switch it works perfectly fine,
                                          Just the combination 2AA Slimnode and HC-SR505 doesnt work.
                                          Anybody has an idea ?
                                          Thanks in advance Komaandy
