  3. Saving to EEPROM
Saving to EEPROM
11 Posts 4 Posters 2.4k Views 5 Watching
  • E Offline
    E Offline
    esawyja
    wrote on last edited by esawyja
    Hi all,
    Could someone please explain how to save a state to EEPROM, I have a hot water heater that I have to "dumb up", my problem is the saving off the last state, IE when there is a power interruption and the sensor reboots, how do I read the previous state and the previous LOW and HIGH temperature settings. For example I use these statements
    #define LowTempState 0
    #define HighTempState 0
    #define HeaterONOFF 0
    So the heater will not be switched on when you install it the 1st time, but then once the sensor is up and running, you would set the state and temperature from the controller and save that, but I want to prevent the heater from being ON and heating and causing damage when you install it for the 1st time. If I can explain more.. If this is a new installation, run the
    #define LowTempState 10
    #define HighTempState 20
    But once it is connected and running and the temperature and state is set from the controller, save those values and when there is a power failure and the sensor reboots, use the saved values to come up with.. I hope this makes sense?
    Is there some example code somewhere that I might check please...
    Regards
    • E esawyja
      Hi all,
      Regards
      @esawyja the relay example saves state. See if you can use that as template.
      • E Offline
        E Offline
        esawyja
        Hi
        I think the relay example get the previous state from the EEPROM, I need to get the state from the controller after it was set for the 1st time from the controller?
        void before()
        pinMode(pin, OUTPUT);
        An example with lots of comments that is being done will help a lot please
        Regards
        BartEB 1 Reply Last reply
        • E esawyja
          Hi
          void before()
          Regards
          BartEB Offline
          BartEB Offline
          BartE
          @esawyja for getting a value from the controller one can use "request()", i.e. in the relay example like this:
          request(CHILD_ID,V_LIGHT);
          The answer should be handled by the receive function
          • E Offline
            E Offline
            esawyja
            Thanks all, I'll try to get this to work
            • E Offline
              E Offline
              esawyja
              Hi
              I'm struggling to get my head around this, when I do this
              Does this define the position in EEPROM, as per the documentation, so what I'm doing here is completely incorrect? What I need to do it to give it a value where to save with the #define statements?
              The documentation states
              void saveState(uint8_t pos, uint8_t value);
              pos - The position to store value in (0-255)
              value - Value to store in position
              So if I do this
              #define LowTempState 10 //Naming the position LowTempState at position 10 in EEPROM
              #define HeaterONOFF 30
              I have to save the values to the EEPROM addresses with
              saveState(HighTempState, 40);
              saveState(LowTempState, 30);
              saveState(HeaterONOFF, 0);
              So the above with save the values 40, 30 and 0 to their positions 10, 20 and 30 in EEPROM?
              I have to read the state with
              int temHighTrigger=loadState(HighTempState);
              int temLowTrigger=loadState(LowTempState);
              int HeaterStatus=loadState(HeaterONOFF);
              So temHighTrigger will now contain 40? temLowTrigger will now contain 30 and the HeaterStatus will be 0?
              Retrieving a state (from local EEPROM).
              uint8_t loadState(uint8_t pos);
              Sorry for all the questions, my head is spinning....
              AWIA 1 Reply Last reply
              • E esawyja
                Hi
                So if I do this
                AWIA Offline
                AWIA Offline
                AWI
                @esawyja You are correct with the your explanation. The EEPROM consists of 256 "byte" (8 bit) positions , best defined by the type uint_8_t. Be aware that an "int" (int8_t) type in the Arduino C++ compilers is 16 bits. So if you want to store a full int you need two EEPROM positions.
                • E Offline
                  E Offline
                  esawyja
                  Thanks @AWI
                  So for
                  I need to do something like this if it is possible?
                  #define LowTempState 10, 11 //Naming the position LowTempState at position 10 in EEPROM
                  #define HighTempState 20, 21
                  Or do I just declare the trigger as 2 bytes with
                  uint_8_t temHighTrigger=loadState(HighTempState); //So this will read from position 10 for 16 bits?
                  uint_8_t temLowTrigger=loadState(LowTempState); //This one will start at 20 and read 21 as well?
                  int HeaterStatus=loadState(HeaterONOFF); //This one will read only position 30?
                  Regards
                  • E esawyja
                    Thanks @AWI
                    So for
                    Regards
                    AWIA Offline
                    AWIA Offline
                    AWI
                    @esawyja you are getting a little too creative here. I suggest you stick to using uint8_t (byte) types for all of your variables unless you need more range than 0..255. If you need more you need to split these types (int, long, float,... ) into bytes yourself and handle them separately.
                    If you need suggestions there are a few easy ways to accomplish this by means of using 'union'. Just let us know here.
                    • E Offline
                      E Offline
                      esawyja
                      Ok now I'm more confused, but thanks, I will figure it out
                      • E esawyja
                        AWIA Offline
                        AWIA Offline
                        AWI
                        @esawyja sorry... Also for the first sentence? Use byte (uint8_t) for all variables you need to store..
