716 Posts 111 Posters 714.1k Views 93 Watching
  • dbemowskD
    dbemowskD
    So a question I have always wondered about the voltage regulator is do you really need to desolder it if you connect your incoming power to the 3.3v pin and not the RAW pin? I would have thought the regulator would only drain power if it was converting the RAW power down to 3.3v.
    sundberg84S Nca78N 2 Replies Last reply
    • dbemowskD dbemowsk
      sundberg84S
      sundberg84S
      @dbemowsk - your logic sounds right, but i think it will draw power anyway... only way to figure out is to measure or google :)
      • P
        P
        popunonkok
        wrote on last edited by popunonkok
        #302
        I managed to change my PCB order, I saw that one of the updates to rev9 was the ability to use Pin 2 as GPIO instead of going to the Radio where it is unused. So now I have a order for Rev9 instead.
        I will try to desolder the led or resistor and the voltageregulator.
        Thanks for sharing your design.
        • P popunonkok
          sundberg84S
          sundberg84S
          @popunonkok Good luck - let me know if there is any other questions.
            @dbemowsk in fact current is leaking through the regulator when its input is floating, you can check the "reverse leakage current" value on the data sheet of the linear regulator used on your promini boards then decide if you can accept it or not, depending on your circuit.
            • ileneken3I
              ileneken3I
              ileneken3
              Hi -
              I wanted to know if this config is OK:
              Attach a LIPO battery to PWR and GND.
              Cut off the right side of the board.
              Use a 3.3V pro mini.
              Add a regulator (like a MCP1700) and necessary caps. (Spec says 1uF).
              The idea is that the board and sensors get 3.2V - 4.1 V (which should be OK).
              The radio gets 3.3V.
              • ileneken3I ileneken3
                Hi -
                sundberg84S
                sundberg84S
                #306
                @ileneken3 - sounds right, you should short the jumper REG which will feed everything the LIPO voltage. If this is higher than 3.3v I dont know what will happen but adding the voltage regulator for the radio will make sure that one is ok. I dont know about the pro mini, it it can handle up to 4.1v but I guess you will find out.
                  I'm curious too if will handle the 4 volts or not😀
                  • Nca78N
                    No problem with the promini. Limit is from atmega and it's 5.5V I think (at least 5V anyway :) )
                    You will just have HIGH level voltage at battery voltage at the outputs instead of 3.3V
                      So technically you can power a 3.3V pro mini with a LiPo battery, you only need a regulator for radio, correct? Can you still make reliable battery voltage measurement? I Have a NRF24 adapter with a AMS1117 onboard, will that still work or does it need 5v?
                      Nca78N 1 Reply Last reply
                        wrote on last edited by Nca78
                        #310
                        @gohan said in 💬 Easy/Newbie PCB for MySensors:
                        Correct.
                        Yes, check here :
                        https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
                        From the datasheet typical dropout voltage is 1.1V and it can be up to 1.3V.
                        So to get 3.3V at the output you need at least 3.3 + 1.1 = 4.4V. It won't work with your battery, you need to use another voltage regulator with a much lower dropout voltage.
                        ileneken3I 1 Reply Last reply
                        • Nca78N Nca78
                          Correct.
                          Yes, check here :
                          ileneken3I
                          ileneken3I
                          ileneken3
                          @Nca78
                          At least according to the specs, mcp1700 will do the trick (both in terms of drop out voltage and low power consumption for battery usage). I will try it.
                            I have seen these boost/buck converters https://www.aliexpress.com/store/product/5pcs-mini-1-8V-3V-3-7V-5V-to-3-3V-Boost-Buck-Low-Noise-Regulated/1525466_32365767349.html
                            https://www.aliexpress.com/store/product/2PCS-Auto-Buck-Boost-DC-DC-Converter-Voltage-regulator-module-0-9-6V-to-3-3V/1525466_32757272432.html
                            Would they make any sense to use with LiPo batteries or other solar power source to power a node? Or would they waste too much energy?
                              @Nca78
                              ileneken3I
                              ileneken3I
                              ileneken3
                              @ileneken3
                              Regarding the MCP1700 as a regulator (I ordered these: https://www.aliexpress.com/item/5-pcs-MCP1700-3302E-TO-MCP1700-Fixed-LDO-Voltage-Regulator/32781100568.html)
                              first connected the LIPO->TP4056->MCP1700 to the GND and PWR of the board. (I made a homemade little regulator board). From all appearances, it works great, and I end up with a nice compact sensor/battery. But I want to make use of the Easy/Newbie board. I tried hooking it up to the 3 pins marked regulator, but it didn't seem to do anything. Am I missing something? The orientation can be confusing, but I think I got it right. I measured 4.1 volts to the radio, which will fry it.
                                @ileneken3
                                sundberg84S
                                sundberg84S
                                @ileneken3 - the board is created for Le33a voltage regulator which has a different pinout than yours.
                                You have to adjust to that and not just put it in according to the pcb.
                                • sundberg84S sundberg84
                                  ileneken3I
                                  ileneken3I
                                  ileneken3
                                  @sundberg84
                                  I did adjust to the different pinout. I checked it multiple times, checked soldering - it always seems like the regulator is not regulating anything - the radio always gets 4.1 volts from the LIPO.
                                  From looking at the specs, the LE33 is pretty close - with the biggest difference that the MCP1700 can handle more current.
                                  Maybe I should just get the LE33 ones.
                                  Oh well...
                                  Nca78N dbemowskD 2 Replies Last reply
                                    @sundberg84
                                    Oh well...
                                    @ileneken3 your problem with le33 will be the quiescent current which is high, datasheet says "typ. 50 μA in OFF
                                    mode, 0.5 mA in ON mode, no load". 0.5mA will not give you a good battery life...
                                    Compared to a typical value of 1.6µA on the MCP1700 (max at 4µA), you should stick to it if you are using a battery.
                                    Did you test the MCP1700 on a breadboard ?
                                      @sundberg84
                                      Oh well...
                                      dbemowskD
                                      dbemowskD
                                      @ileneken3 Can you post a pic showing how you have this wired? preferably the side where your battery is connected. I would like to see where you have your battery connected and how you have the board wired.
                                      • Nca78N Nca78
                                        ileneken3I
                                        ileneken3I
                                        ileneken3
                                        @Nca78
                                        Yes, I agree. I didn't look closely enough at the currents for le33. The general rule of thumb seems to be:
                                        Current in "milli"amps -> only days or weeks for a battery
                                        Current in "micro"amps -> months on a battery
                                        So MCP1700 seems to be right for a LIPO here.
                                        I did test it on a breadboard. And then I built a little regulator board. It works great.. and I used a battery from an old cell phone that stills seems to work well.
                                          ileneken3I
                                          ileneken3I
                                          ileneken3
                                          @dbemowsk
                                          There's not much to the wiring (maybe that's my problem?).
                                          To attach the legs to be like a LE33, I swung the Vout of the MCP1700 all the way to the left.
                                          With a multimeter, I see 4.1 volts at the radio, and everywhere else.
                                          dbemowskD AWIA sundberg84S 3 Replies Last reply
