716 Posts 111 Posters 703.2k Views 93 Watching
  • ileneken3I ileneken3
    Hi -
    I wanted to know if this config is OK:
    Attach a LIPO battery to PWR and GND.
    Cut off the right side of the board.
    Use a 3.3V pro mini.
    Add a regulator (like a MCP1700) and necessary caps. (Spec says 1uF).
    The idea is that the board and sensors get 3.2V - 4.1 V (which should be OK).
    The radio gets 3.3V.
    sundberg84S
    sundberg84S
    #306
    @ileneken3 - sounds right, you should short the jumper REG which will feed everything the LIPO voltage. If this is higher than 3.3v I dont know what will happen but adding the voltage regulator for the radio will make sure that one is ok. I dont know about the pro mini, it it can handle up to 4.1v but I guess you will find out.
      I'm curious too if will handle the 4 volts or not😀
      • Nca78N
        No problem with the promini. Limit is from atmega and it's 5.5V I think (at least 5V anyway :) )
        You will just have HIGH level voltage at battery voltage at the outputs instead of 3.3V
          So technically you can power a 3.3V pro mini with a LiPo battery, you only need a regulator for radio, correct? Can you still make reliable battery voltage measurement? I Have a NRF24 adapter with a AMS1117 onboard, will that still work or does it need 5v?
          Nca78N 1 Reply Last reply
            wrote on last edited by Nca78
            #310
            @gohan said in 💬 Easy/Newbie PCB for MySensors:
            Correct.
            Yes, check here :
            https://forum.mysensors.org/topic/186/new-library-to-read-arduino-vcc-supply-level-without-resistors-for-battery-powered-sensor-nodes-that-do-not-use-a-voltage-regulator-but-connect-directly-to-the-batteries
            From the datasheet typical dropout voltage is 1.1V and it can be up to 1.3V.
            So to get 3.3V at the output you need at least 3.3 + 1.1 = 4.4V. It won't work with your battery, you need to use another voltage regulator with a much lower dropout voltage.
            ileneken3I 1 Reply Last reply
            • Nca78N Nca78
              Correct.
              Yes, check here :
              ileneken3I
              ileneken3I
              ileneken3
              @Nca78
              At least according to the specs, mcp1700 will do the trick (both in terms of drop out voltage and low power consumption for battery usage). I will try it.
                I have seen these boost/buck converters https://www.aliexpress.com/store/product/5pcs-mini-1-8V-3V-3-7V-5V-to-3-3V-Boost-Buck-Low-Noise-Regulated/1525466_32365767349.html
                https://www.aliexpress.com/store/product/2PCS-Auto-Buck-Boost-DC-DC-Converter-Voltage-regulator-module-0-9-6V-to-3-3V/1525466_32757272432.html
                Would they make any sense to use with LiPo batteries or other solar power source to power a node? Or would they waste too much energy?
                  @Nca78
                  ileneken3I
                  ileneken3I
                  ileneken3
                  @ileneken3
                  Regarding the MCP1700 as a regulator (I ordered these: https://www.aliexpress.com/item/5-pcs-MCP1700-3302E-TO-MCP1700-Fixed-LDO-Voltage-Regulator/32781100568.html)
                  first connected the LIPO->TP4056->MCP1700 to the GND and PWR of the board. (I made a homemade little regulator board). From all appearances, it works great, and I end up with a nice compact sensor/battery. But I want to make use of the Easy/Newbie board. I tried hooking it up to the 3 pins marked regulator, but it didn't seem to do anything. Am I missing something? The orientation can be confusing, but I think I got it right. I measured 4.1 volts to the radio, which will fry it.
                    @ileneken3
                    sundberg84S
                    sundberg84S
                    @ileneken3 - the board is created for Le33a voltage regulator which has a different pinout than yours.
                    You have to adjust to that and not just put it in according to the pcb.
                    • sundberg84S sundberg84
                      ileneken3I
                      ileneken3I
                      ileneken3
                      @sundberg84
                      I did adjust to the different pinout. I checked it multiple times, checked soldering - it always seems like the regulator is not regulating anything - the radio always gets 4.1 volts from the LIPO.
                      From looking at the specs, the LE33 is pretty close - with the biggest difference that the MCP1700 can handle more current.
                      Maybe I should just get the LE33 ones.
                      Oh well...
                      Nca78N dbemowskD 2 Replies Last reply
                        @sundberg84
                        Oh well...
                        @ileneken3 your problem with le33 will be the quiescent current which is high, datasheet says "typ. 50 μA in OFF
                        mode, 0.5 mA in ON mode, no load". 0.5mA will not give you a good battery life...
                        Compared to a typical value of 1.6µA on the MCP1700 (max at 4µA), you should stick to it if you are using a battery.
                        Did you test the MCP1700 on a breadboard ?
                          @sundberg84
                          Oh well...
                          dbemowskD
                          dbemowskD
                          @ileneken3 Can you post a pic showing how you have this wired? preferably the side where your battery is connected. I would like to see where you have your battery connected and how you have the board wired.
                          • Nca78N Nca78
                            ileneken3I
                            ileneken3I
                            ileneken3
                            @Nca78
                            Yes, I agree. I didn't look closely enough at the currents for le33. The general rule of thumb seems to be:
                            Current in "milli"amps -> only days or weeks for a battery
                            Current in "micro"amps -> months on a battery
                            So MCP1700 seems to be right for a LIPO here.
                            I did test it on a breadboard. And then I built a little regulator board. It works great.. and I used a battery from an old cell phone that stills seems to work well.
                            • dbemowskD dbemowsk
                              ileneken3I
                              ileneken3I
                              ileneken3
                              @dbemowsk
                              There's not much to the wiring (maybe that's my problem?).
                              To attach the legs to be like a LE33, I swung the Vout of the MCP1700 all the way to the left.
                              With a multimeter, I see 4.1 volts at the radio, and everywhere else.
                              dbemowskD AWIA sundberg84S 3 Replies Last reply
                                @dbemowsk
                                dbemowskD
                                dbemowskD
                                @ileneken3 OK, I think I see the issue. I think you need a jumper across the reg pads just to the right of the regulator. If you check with a volt meter between the regulator's V-In and the bottom reg pad, you should get continuity. Then if you check from the top reg pad to the positive lead of your battery, you should get continuity there also. you need to bridge that gap to get the power from your battery to the regulator.
                                You would also be wise to add the 0.1uf ceramic and 10uf electrolytic capacitors just above the regulator. The 0.1uf will filter the power coming in to the regulator, and the 10uf will filter the output of the regulator. The other capacitor not to forget is the 4.7uf electrolytic just below the nRF24 radio. If you forget that, you will surely have radio problems.
                                  @dbemowsk
                                  AWIA
                                  AWIA
                                  AWI
                                  @ileneken3 like @dbemowsk says you need capacitors (and probably a jumper) . The LDO will go into oscillation without capacitors.
                                    @dbemowsk
                                    sundberg84S
                                    sundberg84S
                                    #322
                                    @ileneken3 - as mentioned the PCB is made generic so to activate the voltage regulation part (Power -> Volt Reg -> Radio) you need to add a jumper for REG. If one want to bypass the voltage regulation part you jump BAT (and use the booster instead). Have a look at the instructions here and let me know if you think something is missing. The capacitors for the voltage regulator are also recommended as mentioned.
                                    In your case with 4.2 volts, BAT will give you 4.2 volts on the radio and nothing more (if you dont jump the booster as well) and REG will give you 4.2 volts to the arduino and sensors and the regulated voltage to the radio.
                                    It looks like you used BAT in the pictures? If you didnt solder any BAT/REG you should not get anything. Dont solder both!
                                    @AWI , @dbemowsk - thanks for helping out!
                                    • ileneken3I
                                      ileneken3I
                                      ileneken3
                                      @sundberg84
                                      OK, looks like I had multiple problems.
                                      I somehow missed the instructions about "don't solder both", and was also slightly confused about the directions because I am using a battery (LIPO), but following the "5V regulated" instructions. When the instructions mention battery, it always mean a 3.3V battery. I had the BAT jumpered, and then I tried with and without the REG jumpered.
                                      At the same time, I believe I damaged the MCP1700 regulator - I will have to take it off and test it.
                                      So in the interest of getting this resolved quickly, I started all over again with a new board, new regulator, and jumping only REG. It worked! Here is the picture:
                                      You can see that the radio will get 3.3V, and the rest of the board will get 4+ volts. (The TP4056 will cut it off as it goes down to around 3V).
                                      So I will continue the build, and if everything goes according to spec, the radio, arduino, and sensors should all be OK. (Assuming the sensor can handle 4+ volts).
                                      As far as the capacitors, it looks like the spec says 1uF on input and output. So I will put those where there are labels for .1 and 10uF. For the radio, I am well aware of its capacitor needs (learning the hard way). At this point, I always put the 4.7uF cap directly on the radio.
                                      If everything goes well, I would recommend putting some sort of reference to LIPO batteries in the instructions. I couldn't be the only one who wants to do this.
                                      Great support from everyone!
                                        I am also looking at using lipo batteries, but I've been told they have a tendency to self discharge over time, so normal AA batteries or cr123 provide longer battery life of course if the node is not power hungry
                                        S 1 Reply Last reply
                                          Samuel235
                                          @gohan - I can't and wont throw figures around here concerning how much they discharge per day, but they do indeed self-discharge and in my opinion wouldn't be suitable for a sleeping node.
                                          MySensors 2.1.1
