  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • T ted
    @Anticimex said in 💬 Sensebender Gateway:
    MY_CORE_ONLY
    AnticimexA
    AnticimexA
    Anticimex
      #209
      @alexsh1
      woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
      Enjoy :)
      alexsh1A zboblamontZ 2 Replies Last reply
      • scalzS scalz
        @alexsh1
        Enjoy :)
        alexsh1A
        alexsh1A
        alexsh1
        #210
        @scalz Thank you.
        Does anyone have the PA transceiver version with Sensebender Gateway?
        Any feedback please?
        • tbowmoT
          tbowmoT
          tbowmo
          @alexsh1
          If you mean using a nrf24 with lna/pa, with the gateway. Then yes.. I have had it running for some months now.
          Anything in particular that you want to know?
          alexsh1A 1 Reply Last reply
          • tbowmoT tbowmo
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            #212
            @tbowmo yes, that's what I meant
            I am thinking about installing either a normal nrf24l01+ or lna/pa version. I have had some issues with power in the past with the lna/pa transceiver.
            What's your experience? What kind of power supply do you use? How better is the coverage?
            • tbowmoT
              tbowmoT
              tbowmo
              I haven't checked if the coverage is any better with the lna/pa version, compared to standard modules.
              Currently the gateway is connected to a RPI2, which in turn is powered by a 2A powersupply from RS Components
              I haven't had any issues with it yet, but then again.. I mainly receive data from sensor nodes, and not that much sending data to distant nodes from the gateway
              • tbowmoT tbowmo
                alexsh1A
                alexsh1A
                alexsh1
                @tbowmo It is probably not Sensebender topic, but more lna+pa range one.
                I am not sure about my RPi3 as though it is powered by the 3A PSU, I have a USB z-wave stick, three transceivers, one UPS Plco (as HAT) and a 20x4 screen. I lot of power is consumed so not sure adding yet another one. (lna+pa is power hungry during peaks).
                I'll get the nrf24l01+ lna+pa ordered and test the range. In my view rfm69 range is probably better, but I have the rfm69 gateway on moteino with a trace antenna (very small footprint and it is based on ATMega1284P so 128KB sketch flash memory - more than I need).
                @hek - is it the intention to combine rfm69 and nrf24l01+ gateways in one in the future?
                I understand Sensebender GW is ready for it, but it is more a software limitation???
                I am really looking forward to combined GW.
                I also have a separate one for rfm95 so that I can use some remote sensors.
                  wrote on last edited by hek
                  #215
                  No, I haven't heard of any near plans in the core team about doing multi radio/sub-network support in 2.0.
                  This requires some extra thoughts and would probably only fit on SAMD/ESP nodes.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @hek Which is good as the Sensebender GW is based on SAMD! So it is ready to be the first 2-in-1 GW.
                    Anyway, keep on doing a great work! I'll patiently wait until the combined GW is there.
                    • NiklasON
                      NiklasON
                      NiklasO
                      wrote on last edited by NiklasO
                      #217
                      Ordered from ITEAD. Nice to get rid of this stuff:
                      Just nudging anything result in problems. ;-)
                      Time to fire up the 3D-printer.
                      • NiklasON
                        NiklasON
                        NiklasO
                        #218
                        Aaaand, it's up! Very good fit (the box).
                        The box on top is just me trying out different colors of the case. ;)
                        The one on top has better look. Different brands of PLA.
                        • nick van alstN
                          nick van alstN
                          nick van alst
                          @NiklasO that looks very good!
                          Are you willing to share your design files with us?
                          i just ordered my gateway to get rid of cables and lose components :D a case would really make it complete!
                            @NiklasO
                            great :+1:
                            @nick-van-alst
                            you can get enclosure design files here https://www.mysensors.org/hardware/sensebender-gateway (on page bottom)
                            I designed different variants so pick which one you need.
                            • M meddie
                              Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
                              The orange, green and red led are lighting.
                              When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @meddie said in 💬 Sensebender Gateway:
                              @meddie Did you figure out what the problem is? I have exactly the same issue
                              M tbowmoT 2 Replies Last reply
                              • alexsh1A alexsh1
                                meddie
                                @alexsh1
                                hi, yes it was very simple :-D the gateway has worked fine in this time, i thought that when nothing shown in serial monitor that the gateway dont work, but it did it, after i connected the gateway to FHEM (my controller) i saw that FHEM connects t mys Gateway.
                                So it worked all the time
                                Greets Eddie
                                • alexsh1A alexsh1
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @alexsh1
                                  Have you tried to enable the debug output in the GatewayW5100 example? I think it is disabled by default, due to the limited memory on the small atmega 328p
                                  • tbowmoT tbowmo
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo
                                    Yes, I did
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #225
                                      I am running Arduino IDE 1.8.1 on Windows 10
                                      Arduino AVR 1.6.18
                                      Arduino SAMD 1.6.12
                                      MySensors SAMD 1.0.5
                                      EDIT: I have tried to upload the default sketch on macbook with Arduino IDE 1.6.2
                                      It is still the same - no debug info in the terminal
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #226
                                        OK, I did manage to get debug working partially.
                                        The gateway reads messages, but does not work as the gateway
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:348
                                        0;255;3;0;9;TSF:MSG:READ,26-10-0,s=3,c=1,t=24,pt=5,l=4,sg=0:51219479
                                        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51219482
                                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1717.62
                                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:5338.44
                                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.75
                                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.76
                                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=4,c=1,t=37,pt=4,l=4,sg=0:880
                                        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:64.8
                                        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=4,pt=7,l=5,sg=0:1015
                                        I never had a message:
                                        Gateway startup complete.
                                        EDIT: Self-test with SensebenderSerial sketch gives me this:
                                        Sensebender GateWay test routine
                                        Mysensors core version : 2.1.1
                                        GateWay sketch version : 0.2
                                        - > SHA204 Failed to wakeup SHA204
                                        - > SD CARD SD CARD did not initialize!
                                         -> EEPROM PASSED
                                        -> analog : 38 Failed
                                        tbowmoT 1 Reply Last reply
                                        • alexsh1A alexsh1
                                           -> EEPROM PASSED
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @alexsh1
                                          Could you check the soldering of the samd?
                                          SD card fails, if you haven't inserted a card, when running the self test.
