  3. 💬 MDMSensor "Multisensor"
rfm69atmega328multi sensoratsha204ads18b20mysensornrf24l01
16 Posts 9 Posters 7.9k Views 9 Watching
  • R
    R
    robosensor
    Have you tried BME280 sensors? It seems for me that single BME280 sensor can substitute this sensors list:
    DS18B20 (temperature sensor)
    DHT11 (humidity sensor)
    Si7021 (humidity sensor)
    BMP180 (pressure sensor)
    • kalinaK
      kalinaK
      kalina
      No, I haven't.
      Of course it is possible. I use the most popular types of sensors in the community, for which there are many ready-made examples. Also, everyone can solder just necessary sensors for him to make its own device.
      But despite this, I am ready to discuss a set of sensors in my "Multisensor"..... and I don't have ordered pcb's , it means that something can be changed :smiley:
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Is it possibe to add any additional sensors to the build, like PIR?
        • kalinaK
          kalinaK
          kalina
          I have received the pcbs from PCBWAY. Quality as always on top + a small price (10$ - 10pcs). I am going to solder two versions with different radios ASAP. To be continued... :smile:
          • kalinaK
            kalinaK
            kalina
            The first MDMSensor board is assembled (NRF24 version). Now I'm going to test it and make enclosure.
            • TD22057T
              TD22057T
              TD22057
              Very cool. What kind of connector are you using to connect to the programming pads?
              kalinaK 1 Reply Last reply
              • TD22057T TD22057
                kalinaK
                kalinaK
                kalina
                @TD22057, This is Industrial Card Edge Slot Socket Connector
                I use my own handmade an adapter for programming.
                It has a lot wires, instead this i made the MDMSAccessory "Programming" few days ago.
                • MiKaM
                  MiKaM
                  MiKa
                  Possible to add also other battery holder like CR123 or CR2450 to the board?
                  • MiKaM MiKa
                    kalinaK
                    kalinaK
                    kalina
                    @MiKa Yes, i think it is possible. I already have some improvments for this device, but i have no free time to do this, because i am working on MDMSNode "Power" now.
                    G 1 Reply Last reply
                    • kalinaK kalina
                      G
                      G
                      gonzalonal
                      Hi @kalina. Sorry for rebumping this topic with an unrelated concern.
                      I am interested in the enclosures you've made for this design and for your gateway.
                      I have finished a design of my own and now I want to design the enclosure, but I have found that is very expensive to have a custom case built for this prototypes boards, specially when dealing with low volumes.
                      How do you deal with this issue? Have you found a cheap plastic case manufacturer?
                      • G gonzalonal
                        kalinaK
                        kalinaK
                        kalina
                        @gonzalonal said in 💬 MDMSensor "Multisensor":
                        I look for an enclosure on the Aliexpress site, but all these enclosures not ready for using, they require machining on CNC machines.
                        • kalinaK kalina
                          kalinaK
                          kalinaK
                          kalina
                          I have made the firtst device with enclosure already...
                          3_1492256705155_IMG_20170415_143315.jpg 2_1492256705155_IMG_20170415_143246.jpg 1_1492256705155_IMG_20170415_143216.jpg 0_1492256705154_IMG_20170415_143140.jpg
                            Is that 3d printed or did you do some injection moulding?
                            gohanG 1 Reply Last reply
                              @hek I hope he did some cnc work on it 😁
                                kalinaK
                                kalinaK
                                kalina
                                @gohan Yes, you are right, this is done by cnc router.
