  3. 💬 MDMSensor "Multisensor"
rfm69atmega328multi sensoratsha204ads18b20mysensornrf24l01
16 Posts 9 Posters 7.9k Views 9 Watching
  • kalinaK
    kalinaK
    kalina
    I have received the pcbs from PCBWAY. Quality as always on top + a small price (10$ - 10pcs). I am going to solder two versions with different radios ASAP. To be continued... :smile:
    • kalinaK
      kalinaK
      kalina
      The first MDMSensor board is assembled (NRF24 version). Now I'm going to test it and make enclosure.
      • TD22057T
        TD22057T
        TD22057
        Very cool. What kind of connector are you using to connect to the programming pads?
        kalinaK 1 Reply Last reply
        • TD22057T TD22057
          kalinaK
          kalinaK
          kalina
          @TD22057, This is Industrial Card Edge Slot Socket Connector
          I use my own handmade an adapter for programming.
          It has a lot wires, instead this i made the MDMSAccessory "Programming" few days ago.
          • MiKaM
            MiKaM
            MiKa
            Possible to add also other battery holder like CR123 or CR2450 to the board?
            • MiKaM MiKa
              kalinaK
              kalinaK
              kalina
              @MiKa Yes, i think it is possible. I already have some improvments for this device, but i have no free time to do this, because i am working on MDMSNode "Power" now.
              G 1 Reply Last reply
              • kalinaK kalina
                G
                G
                gonzalonal
                Hi @kalina. Sorry for rebumping this topic with an unrelated concern.
                I am interested in the enclosures you've made for this design and for your gateway.
                I have finished a design of my own and now I want to design the enclosure, but I have found that is very expensive to have a custom case built for this prototypes boards, specially when dealing with low volumes.
                How do you deal with this issue? Have you found a cheap plastic case manufacturer?
                • G gonzalonal
                  kalinaK
                  kalinaK
                  kalina
                  @gonzalonal said in 💬 MDMSensor "Multisensor":
                  I look for an enclosure on the Aliexpress site, but all these enclosures not ready for using, they require machining on CNC machines.
                  • kalinaK kalina
                    kalinaK
                    kalinaK
                    kalina
                    I have made the firtst device with enclosure already...
                    3_1492256705155_IMG_20170415_143315.jpg 2_1492256705155_IMG_20170415_143246.jpg 1_1492256705155_IMG_20170415_143216.jpg 0_1492256705154_IMG_20170415_143140.jpg
                      Is that 3d printed or did you do some injection moulding?
                      gohanG 1 Reply Last reply
                        @hek I hope he did some cnc work on it 😁
                          kalinaK
                          kalinaK
                          kalina
                          @gohan Yes, you are right, this is done by cnc router.
