  3. 💬 Ikea Molgan Hack
💬 Ikea Molgan Hack
motionmolganhackpirmysensorsikea
90 Posts 16 Posters 41.3k Views 15 Watching
  • L
    L
    LastSamurai
    I just spend an hour tracing the routes on the pcb. I am pretty sure I missed some (and there might be some errors) but here are my results for now. Ill redo them with KiCad later. Can someone measure the capacitors? They are unlabeled.
      #39
      @LastSamurai
      i already said it but you can try to solder a capa (100uf) to the Drain "Vcc" pin and the GND pin of the PIR sensor itself.
      Maybe you could tweak R9 on your schema, even if i don't think it's exactly connected like this in real.
      Why?
      Combined with the resistor, the capa does filtering and buffering/storing energy.
      You can find infos on google, this is about the capacitor RC time constant.
      So, increasing res&capacitor value, you will increase the time it takes for charging capacitor (so the time to settle the PIR at startup), and what you want, it will take more time to discharge, regarding for example power consumption spikes etc..
      Ideally, it gives better result by using the right resistor, but if you're not sure about the resistor and the schematic, easy route is to increase the capa like i said. At the right place, the sensor ic, also easier because it's through hole . Molgan board was not created for handling another circuit i think, so the hack.
      • L
        L
        LastSamurai
        @scalz Yes, I am pretty sure the part of my schematics around the pir isn't complete yet.
        I'll try the capacitor. Does it have to be the 100uF value? Atm I only have a 47uF cap that might be small enough to fit under the pcb.
          you can try, that could help, sure.
          • YveauxY Yveaux
            @GertSanders Awesome! Thanks for the tip man!
            Samuel235
            @Yveaux - Get yourself on the adafruit show and tell series dude! I for one, watch this series with intent to learn and discover new devices and how to recreate them for myself. I'm pretty sure that most of the audience that join into those are there for the same reason as me. Congrats on making it to their site full stop though :)
            MySensors 2.1.1
            • S Samuel235
              @Samuel235 said in 💬 Ikea Molgan Hack:
              Which episode? I normally don't watch them :satisfied:
              S 1 Reply Last reply
              • YveauxY Yveaux
                Samuel235
                #44
                @Yveaux - This is the series that i'm talking about https://www.youtube.com/watch?v=lrcNW2MaelM&list=PL7E1FAA9E63A32FDC
                They just have random people on video link talking about their products. Might even get some more interest into the MySensors movement let alone your own hardware. Its your choice on what product to get on there i suppose :)
                They normally give you a slot on their air time to just explain your product - not sure how you get on though, application maybe? Let us know if you decide to go for it!
                Check out their other series, something else may be more interest to your hardware or personal interest.
                MySensors 2.1.1
                • S Samuel235
                  @Samuel235 Ah, I misunderstood; thought it was featured on the series already :see_no_evil:
                  Anyway, today my outside sensor felt like proving I didn't fix its issues yet:
                  0_1488906648749_upload-1034c732-4ade-4bcf-9f17-9e1c79bec622
                  The yellow spikes is one continuous burst of roughly 4 hours in which it continuously triggers. After that it resumes normal operation...
                  Again, not a Molgan but an HC-SR501. However electronics are comparable.
                  • AWIA
                    AWIA
                    AWI
                    Thanks @Yveaux for the Molgan Hack board. I was my first experience in soldering an smd atmega ;-) Conclusion... need some more exercise. Finally got the thing working and now ready for the next steps. Some considerations:
                    • The PIR is very sensitive to power fluctuations. Voltages below 3.1V will certainly cause instability.
                    • I want to keep the light feature of the Molgan but make it accessible from MySensors. Same with the light sensor.
                    • Power the Molgan with low selfdischarge rechargeable batteries (The led's will drain the batteries faster)
                    • Maybe add a few other sensors (temp/ hum/ light effects)
                    With the help of the excellent analysis work of @LastSamurai I'm thinking of the following "Ikea Molgan Hack Hacks"
                    • add a 3.3V ldo (XC6206, 1uA ldd, 0.08V dropout) to power the Hack board and sensors.
                    • a voltage divider for measuring real battery voltage.
                    • drive the Led's from a pwm output on the base of transistor connected to R17
                    • Measure the photodiode voltage one way or another.
                    • breakout the SCL and SDA pins for more sensors.
                    Any suggestions? (for sure a breadboarding exercise)
                    • L
                      L
                      LastSamurai
                      @Yveaux did you find a fix for your spikes in the pir readings?
                      I now have the molgan with the 2 caps added in parallel to the existing one running for some weeks and it works reliably. It still triggers several times though when I only move once.
                      Some days ago I also added a small electrolytic cap of 10uF (biggest value I had for the small form factor) directly across the gnd/power pin of the pir on the second molgan and ... it seems to do exactly the same as the first one (perhaps even slightly worse with nearer to 4-5 triggers for every real trigger, where the other one produces ~3).
                      Has anyone tried something different? I mean this solution works reasonably well but its not really perfect... and just a hack imo.
                      @AWI welcome to the "molgan club" ;). How did you solder the smd atmega? I found out that using flux helps a lot but it still takes way too much time and effort to solder by hand :astonished:
                      Your ideas sound nice! Though it might be a little difficult to design the pcb to fit inside the case...
                      YveauxY 2 Replies Last reply
                      • L LastSamurai
                        @LastSamurai I just kept it running unmodified and it seems to behave better now.
                        I have a feeling it might be related to environmental humidity. I'll monitor it over a longer period and see if I can find a pattern.
                        • L LastSamurai
                          @LastSamurai I recently fixed a couple of bugs in the external interrupt handling for sleeping sensors.
                          In short, the sensor could wake within a few milliseconds after going to sleep, because of an interrupt that occurred in the past. For details see this thread.
                          I'm not completely sure, but this could be the cause of your Molgan triggering all the time.
                          Could you give the development branch a try and see if things improve?
                          L 1 Reply Last reply
                          • YveauxY Yveaux
                            L
                            L
                            LastSamurai
                            @Yveaux said in 💬 Ikea Molgan Hack:
                            Wow, great! Thanks for telling me. I'll try it out in the next days.
                            • L
                              L
                              LastSamurai
                              It seems to have helped! I have now upgraded the code one both molgans and both seem to work without a problem now! Thank you very much @Yveaux
                              Only thing I am still strugling with is getting signing to work with the molgans. Works on neither one yet.
                              • L LastSamurai
                                @LastSamurai well, that's great news!
                                Regarding signing, did you mount an atsha204 and does it give issues, or does it seem software related?
                                • L
                                  L
                                  LastSamurai
                                  wrote on last edited by LastSamurai
                                  #53
                                  I did not use a atsha204. I used the (new) personalizer to set the HMAC key (like I did with many other nodes) and activated signing:
                                  Log from gateway:
                                  0;255;3;0;9;422688514 TSF:MSG:READ,16-16-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;422688520 TSF:MSG:BC
                                  0;255;3;0;9;422688523 TSF:MSG:FPAR REQ,ID=16
                                  0;255;3;0;9;422688527 TSF:PNG:SEND,TO=0
                                  0;255;3;0;9;422688531 TSF:CKU:OK
                                  0;255;3;0;9;422688534 TSF:MSG:GWL OK
                                  0;255;3;0;9;422689331 Skipping security for command 3 type 8
                                  0;255;3;0;9;422689366 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=8,pt=1,l=1,sg=1,ft=0,st=OK:0
                                  0;255;3;0;9;422690740 TSF:MSG:READ,16-16-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  0;255;3;0;9;422690746 Skipping security for command 3 type 24
                                  0;255;3;0;9;422690752 TSF:MSG:PINGED,ID=16,HP=1
                                  0;255;3;0;9;422690756 Skipping security for command 3 type 25
                                  0;255;3;0;9;422690774 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=25,pt=1,l=1,sg=1,ft=0,st=OK:1
                                  0;255;3;0;9;422690965 TSF:MSG:READ,16-16-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                  0;255;3;0;9;422690972 Skipping security for command 3 type 15
                                  0;255;3;0;9;422690977 Mark node 16 as one that require signed messages
                                  0;255;3;0;9;422690984 Mark node 16 as one that do not require whitelisting
                                  0;255;3;0;9;422690991 Informing node 16 that we require signatures
                                  0;255;3;0;9;422690997 Informing node 16 that we do not require whitelisting
                                  0;255;3;0;9;422691004 Skipping security for command 3 type 15
                                  0;255;3;0;9;422691013 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                  0;255;3;0;9;422691115 TSF:MSG:READ,16-16-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                  0;255;3;0;9;422691121 Skipping security for command 3 type 16
                                  0;255;3;0;9;422691127 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422691145 Skipping security for command 3 type 17
                                  0;255;3;0;9;422691168 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:882ED3D3B94E6236CCB4FF241128DB984C93F39707EEAC6B7E
                                  0;255;3;0;9;422691180 Transmitted nonce
                                  0;255;3;0;9;422691464 TSF:MSG:READ,16-16-0,s=255,c=0,t=17,pt=0,l=10,sg=1:2.2.0-beta
                                  0;255;3;0;9;422691471 Current nonce: 882ED3D3B94E6236CCB4FF241128DB984C93F39707EEAC6B7EAAAAAAAAAAAAAA
                                  0;255;3;0;9;422691556 HMAC: AC275AA68FF2B3B3689F68DD285F1BFEF8D3F329CCF6E714EEF9E100967B1677
                                  0;255;3;0;9;422691564 Signature bad
                                  0;255;3;0;9;422691567 Signature verification failed!
                                  0;255;3;0;9;422691572 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422691577 TSF:MSG:READ,16-16-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422691584 Skipping security for command 3 type 16
                                  0;255;3;0;9;422691589 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422691608 Skipping security for command 3 type 17
                                  0;255;3;0;9;422691616 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:404FD7260F4410E17E0AD6C07A9A1D04306079F24F9F96CDA1
                                  0;255;3;0;9;422691629 Transmitted nonce
                                  0;255;3;0;9;422691902 TSF:MSG:READ,16-16-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                                  0;255;3;0;9;422691909 Current nonce: 404FD7260F4410E17E0AD6C07A9A1D04306079F24F9F96CDA1AAAAAAAAAAAAAA
                                  0;255;3;0;9;422691994 HMAC: 0A7E2867AD7650B15268AC1EF73D37394AC3499733CDD43838D762BA69295B5D
                                  0;255;3;0;9;422692002 Signature bad
                                  0;255;3;0;9;422692005 Signature verification failed!
                                  0;255;3;0;9;422692011 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422694036 TSF:MSG:READ,16-16-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422694042 Skipping security for command 3 type 16
                                  0;255;3;0;9;422694048 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422694067 Skipping security for command 3 type 17
                                  0;255;3;0;9;422694075 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:6AEE2250F8701E4E2B0ABF997B5A8EC57C57793EBC9B09F689
                                  0;255;3;0;9;422694087 Transmitted nonce
                                  0;255;3;0;9;422694386 TSF:MSG:READ,16-16-0,s=255,c=3,t=11,pt=0,l=11,sg=1:Molgan Flur
                                  0;255;3;0;9;422694393 Current nonce: 6AEE2250F8701E4E2B0ABF997B5A8EC57C57793EBC9B09F689AAAAAAAAAAAAAA
                                  0;255;3;0;9;422694478 HMAC: C9B71FFDB9E225BFB122680DADF0B4C4CF23765378A927279C05A751E4C62D45
                                  0;255;3;0;9;422694487 Signature bad
                                  0;255;3;0;9;422694490 Signature verification failed!
                                  0;255;3;0;9;422694495 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422694499 TSF:MSG:READ,16-16-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422694506 Skipping security for command 3 type 16
                                  0;255;3;0;9;422694511 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422694530 Skipping security for command 3 type 17
                                  0;255;3;0;9;422694538 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F652D897B520B026844F8B8B09417A5C0144B6A1F2ABF01623
                                  0;255;3;0;9;422694550 Transmitted nonce
                                  0;255;3;0;9;422694829 TSF:MSG:READ,16-16-0,s=255,c=3,t=12,pt=0,l=8,sg=1:08042017
                                  0;255;3;0;9;422694836 Current nonce: F652D897B520B026844F8B8B09417A5C0144B6A1F2ABF01623AAAAAAAAAAAAAA
                                  0;255;3;0;9;422694921 HMAC: CCBF0048F9783EBC55219D7F1CFDE6ED46452B4E8897A0393A80EC9F4F20E7F8
                                  0;255;3;0;9;422694929 Signature bad
                                  0;255;3;0;9;422694932 Signature verification failed!
                                  0;255;3;0;9;422694937 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422694941 TSF:MSG:READ,16-16-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422694948 Skipping security for command 3 type 16
                                  0;255;3;0;9;422694953 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422694972 Skipping security for command 3 type 17
                                  0;255;3;0;9;422694983 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:25D2B687E9850102C83439698CA1261AC775BD8E1D6D78D662
                                  0;255;3;0;9;422694995 Transmitted nonce
                                  0;255;3;0;9;422695262 TSF:MSG:READ,16-16-0,s=1,c=0,t=1,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422695268 Current nonce: 25D2B687E9850102C83439698CA1261AC775BD8E1D6D78D662AAAAAAAAAAAAAA
                                  0;255;3;0;9;422695353 HMAC: 189EC417FAF4A2C51F2C03916FF1ABB14C8DD29D78B88681E250FC0F07F7CB4B
                                  0;255;3;0;9;422695361 Signature bad
                                  0;255;3;0;9;422695364 Signature verification failed!
                                  0;255;3;0;9;422695369 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422695374 TSF:MSG:READ,16-16-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422695380 Skipping security for command 3 type 16
                                  0;255;3;0;9;422695386 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422695404 Skipping security for command 3 type 17
                                  0;255;3;0;9;422695413 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:4E135F3710AC0AD6A13A985A81BA4A4EF209A3E57E42717E49
                                  0;255;3;0;9;422695425 Transmitted nonce
                                  0;255;3;0;9;422695687 TSF:MSG:READ,16-16-0,s=2,c=0,t=30,pt=0,l=0,sg=1:
                                  0;255;3;0;9;422695693 Current nonce: 4E135F3710AC0AD6A13A985A81BA4A4EF209A3E57E42717E49AAAAAAAAAAAAAA
                                  0;255;3;0;9;422695778 HMAC: B566AB83CDF3342FE31F3CDC068B7E40AB51E6796F602710D26994D19B39D2AF
                                  0;255;3;0;9;422695786 Signature bad
                                  0;255;3;0;9;422695789 Signature verification failed!
                                  0;255;3;0;9;422695794 !TSF:MSG:SIGN VERIFY FAIL
                                  0;255;3;0;9;422695798 TSF:MSG:READ,16-16-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
                                  0;255;3;0;9;422695805 Skipping security for command 3 type 26
                                  0;255;3;0;9;422695811 Skipping security for command 3 type 16
                                  0;255;3;0;9;422695819 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  0;255;3;0;9;422695827 Nonce requested from 16. Waiting...
                                  0;255;3;0;9;422695953 TSF:MSG:READ,16-16-0,s=255,c=3,t=17,pt=6,l=25,sg=1:B7E56807628A0BB459E81226A682E7C3C3B40087E4B7BE05EA
                                  0;255;3;0;9;422695963 Skipping security for command 3 type 17
                                  0;255;3;0;9;422695969 Nonce received from 16.
                                  0;255;3;0;9;422695973 Proceeding with signing...
                                  0;255;3;0;9;422695977 Signing backend: ATSHA204Soft
                                  0;255;3;0;9;422695983 Current nonce: B7E56807628A0BB459E81226A682E7C3C3B40087E4B7BE05EAAAAAAAAAAAAAAA
                                  0;255;3;0;9;422696067 HMAC: 9EF18CC260F8C4CDEB29C1E277F989482B1C08AB37C6FE9AA39146D8BEBC50AA
                                  0;255;3;0;9;422696075 Message signed
                                  0;255;3;0;9;422696079 Message to send has been signed
                                  0;255;3;0;9;422696110 TSF:MSG:SEND,0-0-16-16,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
                                  Log from the node:
                                  129 TSM:INIT:TSP OK
                                  149 TSM:INIT:STATID=16
                                  174 TSF:SID:OK,ID=16
                                  196 TSM:FPAR
                                  243 TSF:MSÿ1040 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=1:0
                                  1097ð”*ô=ø2318 TSM:FPAR:OK
                                  2334 TSM:ID
                                  2349 TSM:ID:OK
                                  2363 TSM:UPL
                                  2383 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2457 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=1:1
                                  2516 TSF:MSG:PONG RECV,HP=1
                                  2545 TSM:UPL:OK
                                  2564 TSM:READY:ID=16,PAR=0,DIS=1
                                  2605 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                  2680 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                  2746 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                  2820 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=0:882ED3D3B94E6236CCB4FF241128DB984C93F39707EEAC6B7E
                                  3088 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=1,ft=0,st=OK:2.2.0-beta
                                  3174 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  3248 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=1:404FD7260F4410E17E0AD6C07A9A1D04306079F24F9F96CDA1
                                  3514 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
                                  5593 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  5666 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=1:6AEE2250F8701E4E2B0ABF997B5A8EC57C57793EBC9B09F689
                                  5935 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=11,sg=1,ft=0,st=OK:Molgan Flur
                                  6025 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  6098 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=1:F652D897B520B026844F8B8B09417A5C0144B6A1F2ABF01623
                                  6365 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=8,sg=1,ft=0,st=OK:08042017
                                  6449 TSF:MSG:SEND,16-16-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  6520 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=1:25D2B687E9850102C83439698CA1261AC775BD8E1D6D78D662
                                  6789 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=1,pt=0,l=0,sg=1,ft=0,st=OK:
                                  6862 TSF:MSG:SEND,16-16-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                  6934 TSF:MSG:READ,0-0-16,s=255,c=3,t=17,pt=6,l=25,sg=1:4E135F3710AC0AD6A13A985A81BA4A4EF209A3E57E42717E49
                                  7204 TSF:MSG:SEND,16-16-0-0,s=2,c=0,t=30,pt=0,l=0,sg=1,ft=0,st=OK:
                                  7274 MCO:REG:REQ
                                  7294 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
                                  7368 TSF:MSG:READ,0-0-16,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                  7460 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:B7E56807628A0BB459E81226A682E7C3C3B40087E4B7BE05EA
                                  7610 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                                  7821 !TSF:MSG:SIGN VERIFY FAIL
                                  7854 MCO:BGN:STP
                                  7872 MCO:BGN:INIT OK,TSP=1
                                  7901 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
                                  7958 TSF:TDI:TSL
                                  This is done while the node is powered by the usb-to-serial converter so power should be steady.
                                  Any idea why this is not working? The HMAC that the gateway mentions in the log is wrong btw (is this what it gets from the node?)
                                  PS Other nodes are working well with singing (and the same HMAC obviously).
                                  AnticimexA 1 Reply Last reply
                                    I would not trust USB serial converter voltage regulator if I were you.
                                      L
                                      L
                                      LastSamurai
                                      #55
                                      @gohan Thanks, but I just tested it with a real power supply and I get the same errors.
                                      PS I just tested a node where signing is working and the gateway logs also contains these false HMAC keys.. Strange, where are they coming from?
                                      • L LastSamurai
                                        @LastSamurai Maybe @Anticimex can explain what's going on?
                                        • L LastSamurai
                                          Log from gateway:
                                          Log from the node:
                                          129 TSM:INIT:TSP OK
                                          196 TSM:FPAR
                                          2334 TSM:ID
                                          2349 TSM:ID:OK
                                          2363 TSM:UPL
                                          2545 TSM:UPL:OK
                                          7274 MCO:REG:REQ
                                          7854 MCO:BGN:STP
                                          7958 TSF:TDI:TSL
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #57
                                          @LastSamurai I am not sure what you mean by hmac keys in the log? Hmac key is never shown in the log. Where is this hmac key you mention? I only see nonce data and that is (or should be) random.
                                          Edit: the log from the GW shows the resulting hmac signature. Not the key. I guess your personalized keys differ between gw and node.
