  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • mar.conteM mar.conte
    @user2684
    it's ok this code?
    NodeManager nodeManager;
    SensorSwitch swiTch(1,3);
    // before
    void before() {
      Serial.begin(MY_BAUD_RATE);
       * Register below your sensors
    swiTch.setMode(0);
    swiTch.setInitial(0);
    swiTch.setTriggerTime(4000);
      nodeManager.setSleep(SLEEP,60,MINUTES);
      nodeManager.registerSensor(SENSOR_MOTION,3);```
    U
    U
    user2684
    @mar.conte sorry I'm not sure I have understood what you want to achieve. Do you have a motion sensor which is HIGH by default and when triggers goes LOW? Is this what you need?
    mar.conteM 1 Reply Last reply
    • U user2684
      mar.conteM
      mar.conteM
      mar.conte
      @user2684
      Hello, I have a simple pir hcr501 that normally does not send output to pin 3 (so low) but when there is movement becomes HIGH, then my CPU goes to sleep for 60 minutes; the hardware is well configured because this setup I used it with the official mysensors sketches for pir motion; I do not understand why the domoticz controller is always the pir HIGH and does not go into sleep the MCU, thanks
      M.C.
      U 1 Reply Last reply
        @user2684
        U
        U
        user2684
        @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
        Ok, so you don't need any customization in NodeManager since this is meeting the default behavior (LOW by default and triggering on HIGH), sorry for the wrong advice. Let's have a look at the sensor's logs then to see why the node is waking up continuously.
        • U user2684
          mar.conteM
          mar.conteM
          mar.conte
          @user2684
          @gohan
          node
          40 MCO:BGN:BFR
          REG I=1 P=3 P=6 T=0
          NodeManager v1.4
          INT1 M=255
          INT2 M=255
          59 TSM:INIT
          135 TSF:WUR:MS=0
          155 TSM:INIT:TSP OK
          176 TSM:INIT:STATID=100
          202 TSF:SID:OK,ID=100
          225 TSM:FPAR
          370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          2301 TSF:MSG:FPAR OK,ID=0,D=1
          2447 TSM:FPAR:OK
          2463 TSM:ID
          2478 TSM:ID:OK
          2492 TSM:UPL
          2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
          3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          3737 TSF:MSG:PONG RECV,HP=1
          3768 TSM:UPL:OK
          3784 TSM:READY:ID=100,PAR=0,DIS=1
          3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
          4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
          6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
          6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
          RADIO OK
          PRES I=200, T=23
          7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
          PRES I=201, T=30
          7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
          BATT V=3.25 P=93
          SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
          7469 !MCO:SND:NODE NOT REG
          7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
          PRES I=1 T=6
          7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
          READY
          7868 MCO:REG:REQ
          7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
          9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          9078 MCO:PIM:NODE REG=1
          9105 MCO:BGN:STP
          MY I=100 M=1
          9123 MCO:BGN:INIT OK,TSP=1
          THER I=1 V=354.00 T=40.05
           M=1
          SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
          9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
          SLEEP 3600s
          9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
          9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
          9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          9666 !TSF:MSG:LEN,0!=8
          10108 MCO:SLP:TPD```
          Gateway
          0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSF:MSG:BC
          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
          0;255;3;0;9;TSF:PNG:SEND,TO=0
          0;255;3;0;9;TSF:CKU:OK
          0;255;3;0;9;TSF:MSG:GWL OK
          0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
          0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
          0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
          0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
          0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
          M.C.
            @user2684
            @gohan
            node
            40 MCO:BGN:BFR
            REG I=1 P=3 P=6 T=0
            NodeManager v1.4
            INT1 M=255
            INT2 M=255
            59 TSM:INIT
            135 TSF:WUR:MS=0
            155 TSM:INIT:TSP OK
            225 TSM:FPAR
            2447 TSM:FPAR:OK
            2463 TSM:ID
            2478 TSM:ID:OK
            2492 TSM:UPL
            3768 TSM:UPL:OK
            RADIO OK
            PRES I=200, T=23
            PRES I=201, T=30
            BATT V=3.25 P=93
            PRES I=1 T=6
            READY
            7868 MCO:REG:REQ
            9105 MCO:BGN:STP
            MY I=100 M=1
             M=1
            SLEEP 3600s
            Gateway
            U
            U
            user2684
            @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
            • U user2684
              mar.conteM
              mar.conteM
              mar.conte
              wrote on last edited by mar.conte
              #84
              @user2684
              hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
              smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
              M.C.
                @user2684
                U
                U
                user2684
                The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
                • U user2684
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @user2684
                  Yes trig again!!!
                  M.C.
                    @user2684
                    Yes trig again!!!
                    U
                    U
                    user2684
                    Yes trig again!!!
                    Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
                    • U user2684
                      Yes trig again!!!
                      mar.conteM
                      mar.conteM
                      mar.conte
                      wrote on last edited by gohan
                      #88
                      @user2684
                      NODE OUTPUT
                      40 MCO:BGN:BFR
                      REG I=1 P=3 P=1 T=16
                      NodeManager v1.4
                      INT1 M=3
                      INT2 M=255
                      59 TSM:INIT
                      135 TSF:WUR:MS=0
                      153 TSM:INIT:TSP OK
                      200 TSF:SID:OK,ID=100
                      223 TSM:FPAR
                      368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      698 TSF:MSG:FPAR OK,ID=0,D=1
                      2445 TSM:FPAR:OK
                      2461 TSM:ID
                      2476 TSM:ID:OK
                      2490 TSM:UPL
                      2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2693 TSF:MSG:PONG RECV,HP=1
                      2721 TSM:UPL:OK
                      2738 TSM:READY:ID=100,PAR=0,DIS=1
                      2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                      3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
                      5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
                      RADIO OK
                      PRES I=200, T=23
                      5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
                      PRES I=201, T=30
                      5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
                      BATT V=3.21 P=86
                      SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
                      6072 !MCO:SND:NODE NOT REG
                      6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
                      PRES I=1 T=1
                      6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                      READY
                      6445 MCO:REG:REQ
                      6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
                      6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      6678 MCO:PIM:NODE REG=1
                      6705 MCO:BGN:STP
                      MY I=100 M=1
                      6723 MCO:BGN:INIT OK,TSP=1
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
                      6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 3600s
                      6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
                      7684 MCO:SLP:TPD
                      7700 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
                      7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                      SLEEP 3600s
                      7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
                      8667 MCO:SLP:TPD
                      8683 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                      SLEEP 3600s
                      8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
                      9562 MCO:SLP:TPD
                      9578 MCO:SLP:WUP=1
                      WAKE P=3, M=3
                      AWAKE
                      SWITCH I=1 P=3 V=1
                      9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
                      SLEEP 3600s
                      9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
                      9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
                      10541 MCO:SLP:TPD
                      Tanks
                      M.C.
                        @user2684
                        NODE OUTPUT
                        40 MCO:BGN:BFR
                        NodeManager v1.4
                        INT1 M=3
                        INT2 M=255
                        59 TSM:INIT
                        135 TSF:WUR:MS=0
                        153 TSM:INIT:TSP OK
                        223 TSM:FPAR
                        2445 TSM:FPAR:OK
                        2461 TSM:ID
                        2476 TSM:ID:OK
                        2490 TSM:UPL
                        2721 TSM:UPL:OK
                        RADIO OK
                        PRES I=200, T=23
                        PRES I=201, T=30
                        BATT V=3.21 P=86
                        PRES I=1 T=1
                        READY
                        6445 MCO:REG:REQ
                        6705 MCO:BGN:STP
                        MY I=100 M=1
                        SWITCH I=1 P=3 V=1
                        SLEEP 3600s
                        7684 MCO:SLP:TPD
                        7700 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 3600s
                        8667 MCO:SLP:TPD
                        8683 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 3600s
                        9562 MCO:SLP:TPD
                        9578 MCO:SLP:WUP=1
                        WAKE P=3, M=3
                        AWAKE
                        SWITCH I=1 P=3 V=1
                        SLEEP 3600s
                        10541 MCO:SLP:TPD
                        Tanks
                        U
                        U
                        user2684
                        @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
                        Now, if I look at the digital read of the pin waking up the board (V=):
                        SWITCH I=1 P=3 V=1
                        This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
                        mar.conteM 2 Replies Last reply
                        • U user2684
                          SWITCH I=1 P=3 V=1
                          mar.conteM
                          mar.conteM
                          mar.conte
                          @user2684
                          ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
                          M.C.
                          • mar.conteM
                            mar.conteM
                            mar.conte
                            #91
                            I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
                            M.C.
                              U
                              U
                              user2684
                              If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                              nodeManager.setBatteryInternalVcc(false);
                              nodeManager.setBatteryPin(A0);
                              You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
                              • U user2684
                                mar.conteM
                                mar.conteM
                                mar.conte
                                @user2684
                                THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
                                TANKS
                                M.C.
                                  @user2684
                                  TANKS
                                  U
                                  U
                                  user2684
                                  TANKS
                                  If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                                  nodeManager.setBatteryMin(2.7);
                                  nodeManager.setBatteryMax(3.6);
                                  So the percentage will be calculated between the two values.
                                  • U user2684
                                    TANKS
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @user2684
                                    Much easy INFINITE THANKS AND CONGRATULATIONS
                                    M.C.
                                    • U user2684
                                      SWITCH I=1 P=3 V=1
                                      mar.conteM
                                      mar.conteM
                                      mar.conte
                                      #96
                                      @user2684
                                      Solved
                                      I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                                      thanks for the support
                                      This is my reprap printed house for my project
                                      M.C.
                                        @user2684
                                        Solved
                                        U
                                        U
                                        user2684
                                        @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
                                        • mar.conteM
                                          mar.conteM
                                          mar.conte
                                          I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
                                          M.C.
