  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • mar.conteM mar.conte
    @user2684
    @gohan
    node
    40 MCO:BGN:BFR
    REG I=1 P=3 P=6 T=0
    NodeManager v1.4
    INT1 M=255
    INT2 M=255
    59 TSM:INIT
    135 TSF:WUR:MS=0
    155 TSM:INIT:TSP OK
    176 TSM:INIT:STATID=100
    202 TSF:SID:OK,ID=100
    225 TSM:FPAR
    370 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2244 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2301 TSF:MSG:FPAR OK,ID=0,D=1
    2447 TSM:FPAR:OK
    2463 TSM:ID
    2478 TSM:ID:OK
    2492 TSM:UPL
    2639 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    3678 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    3737 TSF:MSG:PONG RECV,HP=1
    3768 TSM:UPL:OK
    3784 TSM:READY:ID=100,PAR=0,DIS=1
    3883 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4003 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4202 !TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=NACK:2.1.1
    4415 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=NACK:0
    6733 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=2,st=NACK:NodeManagerTemplate
    6928 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=3,st=OK:1.0
    RADIO OK
    PRES I=200, T=23
    7137 !TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=NACK:
    PRES I=201, T=30
    7321 TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=1,st=OK:
    BATT V=3.25 P=93
    SEND D=0 I=201 C=0 T=38 S= I=0 F=3.25
    7469 !MCO:SND:NODE NOT REG
    7587 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:93
    PRES I=1 T=6
    7794 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=NACK:
    READY
    7868 MCO:REG:REQ
    7933 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    9019 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    9078 MCO:PIM:NODE REG=1
    9105 MCO:BGN:STP
    MY I=100 M=1
    9123 MCO:BGN:INIT OK,TSP=1
    THER I=1 V=354.00 T=40.05
     M=1
    SEND D=0 I=1 C=0 T=0 S= N=0 F=40.05
    9224 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:40.05
    SLEEP 3600s
    9316 MCO:SLP:MS=3600000,SMS=1,I1=255,M1=255,I2=255,M2=255
    9527 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:287
    9607 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    9666 !TSF:MSG:LEN,0!=8
    10108 MCO:SLP:TPD```
    Gateway
    0;255;3;0;9;TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=100
    0;255;3;0;9;TSF:PNG:SEND,TO=0
    0;255;3;0;9;TSF:CKU:OK
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    0;255;3;0;9;TSF:MSG:PINGED,ID=100,HP=1
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/0/0/17
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=11,pt=0,l=19,sg=0:NodeManagerTemplate
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/11
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=200,c=0,t=23,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/200/0/0/23
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=0,pt=1,l=1,sg=0:85
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    0;255;3;0;9;TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=1,c=1,t=0,pt=7,l=5,sg=0:36.72
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/1/1/0/0
    0;255;3;0;9;TSF:MSG:READ,100-100-0,s=255,c=3,t=22,pt=5,l=4,sg=0:286
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/100/255/3/0/22
    0;255;3;0;9;Message arrived on topic: domoticz/out/MyMQTT/0/0/3/0/18
    0;255;3;0;9;Sending message on topic: domoticz/in/MyMQTT/0/255/3/0/22
    U
    U
    user2684
    @mar.conte there is something strange with this node. First of all the node is still presenting the temperature and not the motion sensor. Then I see a lot of failures during transmit but also while receiving (!TSF:MSG:LEN,0!=8). Are you sure you don't have something like two nodes with the same id?
    mar.conteM 1 Reply Last reply
    • U user2684
      mar.conteM
      mar.conteM
      mar.conte
      wrote on last edited by mar.conte
      #84
      @user2684
      hi, I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node, what do you recommend?
      smotion now appears I had mistakenly entered analog 0 on a wire that went to +Power
      M.C.
      U 1 Reply Last reply
        @user2684
        U
        U
        user2684
        @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
        The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
        • U user2684
          mar.conteM
          mar.conteM
          mar.conte
          @user2684
          Yes trig again!!!
          M.C.
            @user2684
            Yes trig again!!!
            U
            U
            user2684
            Yes trig again!!!
            Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
            • U user2684
              Yes trig again!!!
              mar.conteM
              mar.conteM
              mar.conte
              wrote on last edited by gohan
              #88
              @user2684
              NODE OUTPUT
              40 MCO:BGN:BFR
              REG I=1 P=3 P=1 T=16
              NodeManager v1.4
              INT1 M=3
              INT2 M=255
              59 TSM:INIT
              135 TSF:WUR:MS=0
              153 TSM:INIT:TSP OK
              200 TSF:SID:OK,ID=100
              223 TSM:FPAR
              368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              698 TSF:MSG:FPAR OK,ID=0,D=1
              2445 TSM:FPAR:OK
              2461 TSM:ID
              2476 TSM:ID:OK
              2490 TSM:UPL
              2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2693 TSF:MSG:PONG RECV,HP=1
              2721 TSM:UPL:OK
              2738 TSM:READY:ID=100,PAR=0,DIS=1
              2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
              5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
              5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
              RADIO OK
              PRES I=200, T=23
              5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
              PRES I=201, T=30
              5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
              BATT V=3.21 P=86
              SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
              6072 !MCO:SND:NODE NOT REG
              6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
              PRES I=1 T=1
              6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
              READY
              6445 MCO:REG:REQ
              6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
              6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              6678 MCO:PIM:NODE REG=1
              6705 MCO:BGN:STP
              MY I=100 M=1
              6723 MCO:BGN:INIT OK,TSP=1
              SWITCH I=1 P=3 V=1
              SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
              6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
              SLEEP 3600s
              6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
              7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
              7684 MCO:SLP:TPD
              7700 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
              7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
              SLEEP 3600s
              7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
              8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
              8667 MCO:SLP:TPD
              8683 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
              SLEEP 3600s
              8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
              8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
              9562 MCO:SLP:TPD
              9578 MCO:SLP:WUP=1
              WAKE P=3, M=3
              AWAKE
              SWITCH I=1 P=3 V=1
              9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
              SLEEP 3600s
              9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
              9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
              10541 MCO:SLP:TPD
              Tanks
              M.C.
                @user2684
                NODE OUTPUT
                40 MCO:BGN:BFR
                NodeManager v1.4
                INT1 M=3
                INT2 M=255
                59 TSM:INIT
                135 TSF:WUR:MS=0
                153 TSM:INIT:TSP OK
                223 TSM:FPAR
                2445 TSM:FPAR:OK
                2461 TSM:ID
                2476 TSM:ID:OK
                2490 TSM:UPL
                2721 TSM:UPL:OK
                RADIO OK
                PRES I=200, T=23
                PRES I=201, T=30
                BATT V=3.21 P=86
                PRES I=1 T=1
                READY
                6445 MCO:REG:REQ
                6705 MCO:BGN:STP
                MY I=100 M=1
                SWITCH I=1 P=3 V=1
                SLEEP 3600s
                7684 MCO:SLP:TPD
                7700 MCO:SLP:WUP=1
                WAKE P=3, M=3
                AWAKE
                SWITCH I=1 P=3 V=1
                SLEEP 3600s
                8667 MCO:SLP:TPD
                8683 MCO:SLP:WUP=1
                WAKE P=3, M=3
                AWAKE
                SWITCH I=1 P=3 V=1
                SLEEP 3600s
                9562 MCO:SLP:TPD
                9578 MCO:SLP:WUP=1
                WAKE P=3, M=3
                AWAKE
                SWITCH I=1 P=3 V=1
                SLEEP 3600s
                10541 MCO:SLP:TPD
                Tanks
                U
                U
                user2684
                @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
                Now, if I look at the digital read of the pin waking up the board (V=):
                SWITCH I=1 P=3 V=1
                This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
                mar.conteM 2 Replies Last reply
                • U user2684
                  SWITCH I=1 P=3 V=1
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @user2684
                  ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
                  M.C.
                  • mar.conteM
                    mar.conteM
                    mar.conte
                    #91
                    I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
                    M.C.
                      U
                      U
                      user2684
                      If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                      nodeManager.setBatteryInternalVcc(false);
                      nodeManager.setBatteryPin(A0);
                      You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
                      • U user2684
                        mar.conteM
                        mar.conteM
                        mar.conte
                        @user2684
                        THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
                        TANKS
                        M.C.
                          @user2684
                          TANKS
                          U
                          U
                          user2684
                          TANKS
                          If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                          nodeManager.setBatteryMin(2.7);
                          nodeManager.setBatteryMax(3.6);
                          So the percentage will be calculated between the two values.
                          • U user2684
                            TANKS
                            mar.conteM
                            mar.conteM
                            mar.conte
                            @user2684
                            Much easy INFINITE THANKS AND CONGRATULATIONS
                            M.C.
                            • U user2684
                              SWITCH I=1 P=3 V=1
                              mar.conteM
                              mar.conteM
                              mar.conte
                              #96
                              @user2684
                              Solved
                              I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                              thanks for the support
                              This is my reprap printed house for my project
                              M.C.
                                @user2684
                                Solved
                                U
                                U
                                user2684
                                @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
                                • mar.conteM
                                  mar.conteM
                                  mar.conte
                                  I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
                                  M.C.
                                  • JonnyDev13J
                                    JonnyDev13J
                                    JonnyDev13
                                    Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
                                      U
                                      U
                                      user2684
                                      So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
                                      • JonnyDev13J JonnyDev13
                                        U
                                        U
                                        user2684
                                        @JonnyDev13 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                                        Good advice thanks! I've changed the website link on Sourceforge as well as added a note in the description and redirected the "Support" link.
                                        JonnyDev13J 1 Reply Last reply
                                        • U user2684
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @user2684
                                          Yes of course but payload =1 pir movimento detect
                                          M.C.
