  3. NodeManager
  4. NodeManager: plugin for a rapid development of battery-powered sensors
223 Posts 23 Posters 125.6k Views 26 Watching
  • U user2684
    @mar.conte said in NodeManager: plugin for a rapid development of battery-powered sensors:
    I noticed that the zero node has a child called S_Arduino_Repeater with an id equal to 255 child node, called 100 S_Arduino_Node
    The node 0 is the gateway which presents itself as S_ARDUINO_REPEATER, the child id 255 is the broadcast address, the node id 100 is instead you node. This is all correct (with or without NodeManager). Glad to hear the motion sensor is now showing up. Is it still trigger continuously?
    mar.conteM
    mar.conteM
    mar.conte
    @user2684
    Yes trig again!!!
    M.C.
    U 1 Reply Last reply
    • mar.conteM mar.conte
      @user2684
      Yes trig again!!!
      U
      U
      user2684
      Yes trig again!!!
      Ok, if triggers continuously, please share the logs of the node now that has been fixed so we can have a look.
      mar.conteM 1 Reply Last reply
      • U user2684
        Yes trig again!!!
        mar.conteM
        mar.conteM
        mar.conte
        wrote on last edited by gohan
        #88
        @user2684
        NODE OUTPUT
        40 MCO:BGN:BFR
        REG I=1 P=3 P=1 T=16
        NodeManager v1.4
        INT1 M=3
        INT2 M=255
        59 TSM:INIT
        135 TSF:WUR:MS=0
        153 TSM:INIT:TSP OK
        176 TSM:INIT:STATID=100
        200 TSF:SID:OK,ID=100
        223 TSM:FPAR
        368 TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        641 TSF:MSG:READ,0-0-100,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        698 TSF:MSG:FPAR OK,ID=0,D=1
        2445 TSM:FPAR:OK
        2461 TSM:ID
        2476 TSM:ID:OK
        2490 TSM:UPL
        2512 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2633 TSF:MSG:READ,0-0-100,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2693 TSF:MSG:PONG RECV,HP=1
        2721 TSM:UPL:OK
        2738 TSM:READY:ID=100,PAR=0,DIS=1
        2785 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2904 TSF:MSG:READ,0-0-100,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        3018 TSF:MSG:SEND,100-100-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
        3229 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=NACK:0
        5316 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=1,st=OK:NodeManagerTemplate
        5541 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.0
        RADIO OK
        PRES I=200, T=23
        5715 TSF:MSG:SEND,100-100-0-0,s=200,c=0,t=23,pt=0,l=0,sg=0,ft=1,st=OK:
        PRES I=201, T=30
        5922 !TSF:MSG:SEND,100-100-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=NACK:
        BATT V=3.21 P=86
        SEND D=0 I=201 C=0 T=38 S= I=0 F=3.21
        6072 !MCO:SND:NODE NOT REG
        6164 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:86
        PRES I=1 T=1
        6371 !TSF:MSG:SEND,100-100-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
        READY
        6445 MCO:REG:REQ
        6531 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
        6619 TSF:MSG:READ,0-0-100,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        6678 MCO:PIM:NODE REG=1
        6705 MCO:BGN:STP
        MY I=100 M=1
        6723 MCO:BGN:INIT OK,TSP=1
        SWITCH I=1 P=3 V=1
        SEND D=0 I=1 C=0 T=16 S= N=1 F=0.00
        6817 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        SLEEP 3600s
        6897 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
        7104 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:264
        7684 MCO:SLP:TPD
        7700 MCO:SLP:WUP=1
        WAKE P=3, M=3
        AWAKE
        SWITCH I=1 P=3 V=1
        SEND D=0 I=1 C=1 T=16 S= N=1 F=0.00
        7786 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
        SLEEP 3600s
        7876 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
        8087 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:1243
        8667 MCO:SLP:TPD
        8683 MCO:SLP:WUP=1
        WAKE P=3, M=3
        AWAKE
        SWITCH I=1 P=3 V=1
        8757 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
        SLEEP 3600s
        8859 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
        8982 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=OK:2226
        9562 MCO:SLP:TPD
        9578 MCO:SLP:WUP=1
        WAKE P=3, M=3
        AWAKE
        SWITCH I=1 P=3 V=1
        9621 TSF:MSG:SEND,100-100-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:1
        SLEEP 3600s
        9754 MCO:SLP:MS=3600000,SMS=1,I1=1,M1=3,I2=255,M2=255
        9961 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=22,pt=5,l=4,sg=0,ft=0,st=NACK:3121
        10541 MCO:SLP:TPD
        Tanks
        M.C.
          @user2684
          NODE OUTPUT
          40 MCO:BGN:BFR
          NodeManager v1.4
          INT1 M=3
          INT2 M=255
          59 TSM:INIT
          135 TSF:WUR:MS=0
          153 TSM:INIT:TSP OK
          223 TSM:FPAR
          2445 TSM:FPAR:OK
          2461 TSM:ID
          2476 TSM:ID:OK
          2490 TSM:UPL
          2721 TSM:UPL:OK
          RADIO OK
          PRES I=200, T=23
          PRES I=201, T=30
          BATT V=3.21 P=86
          PRES I=1 T=1
          READY
          6445 MCO:REG:REQ
          6705 MCO:BGN:STP
          MY I=100 M=1
          SWITCH I=1 P=3 V=1
          SLEEP 3600s
          7684 MCO:SLP:TPD
          7700 MCO:SLP:WUP=1
          WAKE P=3, M=3
          AWAKE
          SWITCH I=1 P=3 V=1
          SLEEP 3600s
          8667 MCO:SLP:TPD
          8683 MCO:SLP:WUP=1
          WAKE P=3, M=3
          AWAKE
          SWITCH I=1 P=3 V=1
          SLEEP 3600s
          9562 MCO:SLP:TPD
          9578 MCO:SLP:WUP=1
          WAKE P=3, M=3
          AWAKE
          SWITCH I=1 P=3 V=1
          SLEEP 3600s
          10541 MCO:SLP:TPD
          Tanks
          U
          U
          user2684
          @mar.conte ok, this looks better, the node is presenting correctly and I see the sensor triggering continuously. You still have a lot of radio failures while sending but this is another story and it is not related to the issue but keep in mind you are losing a few messages.
          Now, if I look at the digital read of the pin waking up the board (V=):
          SWITCH I=1 P=3 V=1
          This is HIGH so the board correctly wakes up. Since the signal apparently stays high, the board goes in and out of sleep so looks like an expected behavior. The are a couple of functions available to prevent this (setTriggerTime() and setDebounce()) but before giving direction I'd ask you to measure the voltage at pin 3 with a multimeter because it looks like the motion sensor goes HIGH and stay HIGH for a long time. If we know this timeframe, we can adjust the settings accordingly. Btw you should have the same behavior with the example sketch at https://www.mysensors.org/build/motion.
          mar.conteM 2 Replies Last reply
          • U user2684
            SWITCH I=1 P=3 V=1
            mar.conteM
            mar.conteM
            mar.conte
            @user2684
            ok, I will check first the voltage of the pir and even the power of the MCU, it seems to me that the rfm69 module does not communicate with each other (node-gateway), it seems strange because with the sketch of links that you suggested it all works well ! thanks anyway I'll do my tests and let you know soon ...
            M.C.
            • mar.conteM
              mar.conteM
              mar.conte
              wrote on last edited by mar.conte
              #91
              I wanted to know what are the connections to monitor the batteries of my sensor, do I connect the battery V+ to the analog pin A0?
              M.C.
                U
                U
                user2684
                If you are connecting the arduino directly to the battery (e.g. no step-up-down), then you don't need any connection since NodeManager is able to sense and measure the input vcc (and according to my measures it is very accurate). In case instead you need to use the method here https://www.mysensors.org/build/battery, you need the following:
                nodeManager.setBatteryInternalVcc(false);
                nodeManager.setBatteryPin(A0);
                You can even customize the default 0.003363075 voltage per bit with setBatteryVoltsPerBit()
                • U user2684
                  mar.conteM
                  mar.conteM
                  mar.conte
                  @user2684
                  THEN MY NODE WILL BE CONNECTED TO A BATTERY 3.6 VOLT AA 2600 MAH, SO I DO NOT RIGHT CONNECTIONS? BUT I HAVE TO CHANGE OTHER PARAMETERS TO BEING 3.6?
                  TANKS
                  M.C.
                    @user2684
                    TANKS
                    U
                    U
                    user2684
                    TANKS
                    If directly connected to the battery you don't need any other connection. To set minimum and maximum voltage to have an accurate battery percentage level calculated you need to use e.g.:
                    nodeManager.setBatteryMin(2.7);
                    nodeManager.setBatteryMax(3.6);
                    So the percentage will be calculated between the two values.
                    • U user2684
                      TANKS
                      mar.conteM
                      mar.conteM
                      mar.conte
                      @user2684
                      Much easy INFINITE THANKS AND CONGRATULATIONS
                      M.C.
                      • U user2684
                        SWITCH I=1 P=3 V=1
                        mar.conteM
                        mar.conteM
                        mar.conte
                        #96
                        @user2684
                        Solved
                        I solved it by putting settriggertime (5000) setdebounce (50); also solved the supply problems because if power is ftdi with the sensor was always high, with batteries the pir is stable and works well
                        thanks for the support
                        This is my reprap printed house for my project
                        M.C.
                          @user2684
                          Solved
                          U
                          U
                          user2684
                          @mar.conte great to hear it is working now! For anybody else interested in these parameters, setDebounce() will set a debounce interval, e.g. the value of the input is checked after the interval from the wakeup so to avoid false positives, while seTriggerTime() ignore any input after the pir has triggered to avoid the sensor to trigger continuously. Btw, very nice and clean packaging!
                          • mar.conteM
                            mar.conteM
                            mar.conte
                            I have a problem, my node is in sleep for 60 minutes and hourly reads the battery voltage but when you wake the pir is high and in addition to the high volts sends me even then the controller sends me a pir pir movement false; how can I avoid it?
                            M.C.
                            • JonnyDev13J
                              JonnyDev13J
                              JonnyDev13
                              Can I suggest updated sourceforge to say that the code has been moved to github, and leaving little else there? That way it's easier to update everything in the same place. I was browsing on sourceforge for a while and wondering "Why isn't this on github instead?" It wasn't even until I came back and started skimming this thread that I realized it was moved to github.
                                U
                                U
                                user2684
                                So you are saying when the node wakes up not from the pir interrupt at the end of the sleeping cycle to report battery level, is it also reporting a V_TRIPPED with payload 0? Thanks
                                • JonnyDev13J JonnyDev13
                                  U
                                  U
                                  user2684
                                  @JonnyDev13 said in NodeManager: plugin for a rapid development of battery-powered sensors:
                                  Good advice thanks! I've changed the website link on Sourceforge as well as added a note in the description and redirected the "Support" link.
                                  JonnyDev13J 1 Reply Last reply
                                  • U user2684
                                    mar.conteM
                                    mar.conteM
                                    mar.conte
                                    @user2684
                                    Yes of course but payload =1 pir movimento detect
                                    M.C.
                                      What's the problem if it reports no motion?
                                      • U user2684
                                        JonnyDev13J
                                        JonnyDev13J
                                        JonnyDev13
                                        @user2684 Looks great!
                                          mar.conteM
                                          mar.conteM
                                          mar.conte
                                          @gohan
                                          The problem is that motion report whenever sleep goes to wake to send me the battery status every 60 minutes ,then every 60 minutes sends me battery status and motion pir
                                          M.C.
