  3. 💬 MySWeMosGWShield - WeMos Mini MySensors Gateway Shield
contest2017rfm69wemosesp8266mysensorsgatewaynrf24l01
40 Posts 10 Posters 15.4k Views 8 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Ok, this is a really stupid question but how do I use this with for example Domoticz? Do I still need to connect it to the usb-port or do I connect using MQTT or some other way?
      @Cliff-Karlsson add it as an MySensors ethernet gateway.
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Ok, I just soldered two of the shield using smd nrf-radios but I only got alot of errors from the serial monitor. Also the boards got hot as hell after a minute. The wemos was really hot and the nrf was untuchable.
        I through that had done something wrong with the first shield so I soldered another but it was also as hot as the first.
        And should I enter the SSID and password for my home wifi-network or should I use the sketch to create a new? I tried both with no success as I got some default network called aitinker or similar both times.
        • E
          E
          emc2
          It should not get hot at all. The Wemos can get a few °C above room temperature but definitively not "hot as hell"
          It happened to me once, when I had some solder joints between 2 pins of the NRF. You may want to test with a multimeter if, when the WeMos is unplugged, you have any shorts between adjacent pins.
          A picture of the soldered board may help too.
          Best way is to edit the example sketch by adding your Wifi credentials on it before uploading them.
          • Nca78N
            Hello, After soldering the radio and before connecting to power you should use a multimeter in "continuity" mode and make sure you have no contact between adjacent pins of the radio. I never connect a circuit using SMD nrf24 without having done this test.
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              @Nca78 said in 💬 MySWeMosGWShield:
              Ok, I have tried several times now soldering/resoldreing the radio with same result. Continuity, that means direct contact? I get several hundreds of ohms between a few of the pads but it does not "beep" anywhere :)
              Can something in my sketch cause this or is it 100% hardware issue?
              This is what I am using:
              // ** WiFi and network configuration **
              #define MY_ESP8266_SSID "My SSID"
              #define MY_ESP8266_PASSWORD "My password"
              #define MY_ESP8266_HOSTNAME "MySWeMosGWNRF"
              // Enable UDP communication
              //#define MY_USE_UDP
              #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
              #define MY_PORT 5003
              // ** OTA updates configuration **
              // Enable OTA updates for ESP8266 based gateway
              #define ESP8266_OTA
              // Define password for OTA updates (recommended but optional)
              //#define ESP8266_OTA_PASSWORD "MySuperSecretOTAPassword"
              // ** MySensors Radio configuration **
              // RF24 settings
              // Use custom RF24 channel (default 76)
              //#define MY_RF24_CHANNEL 42
              // Decrease RF24 power transmission, useful to test in case of Tx problems.
              // If your problem is fixed consider adding the 5V to 3.3V voltage regulator
              // RF69 settings
              // RFM69 Frequency, default = 868MHz
              #define MY_RFM69_FREQUENCY RF69_868MHZ // RFM69 frequency to use (RF69_433MHZ for 433MHz, RF69_868MHZ for 868MHz or RF69_915MHZ for 915MHz)
              // RFM69 Network ID. Use the same for all nodes that will talk to each other, default = 100
              //#define MY_RFM69_NETWORKID     42
              // Disable this if you're not running the RFM69HW model (RFM69HW is recommended on the gateway for better coverage)
              #define MY_IS_RFM69HW
              // ** Mysensors additional functions **
              // Enable inclusion mode
              //#define MY_INCLUSION_MODE_BUTTON_PIN  D3  // GPIO 0
              // Software signing settings
              //#define MY_SIGNING_SOFT
              //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A0
              // Hardware signing settings (currently unsupported?)
              //#define MY_SIGNING_ATSHA204
              //#define MY_SIGNING_ATSHA204_PIN D0  // GPIO 16
              // General signing settings
              // Enable this if you want destination node to sign all messages sent to this gateway.
              // Enable node whitelisting
              // Flash leds on rx/tx/err
              // Set blinking period
              // LED_BUILTIN, the on board LED is used (D4, GPIO 2)
              #define MY_DEFAULT_ERR_LED_PIN LED_BUILTIN // Error led pin
              #define MY_DEFAULT_RX_LED_PIN  LED_BUILTIN // Receive led pin
              #define MY_DEFAULT_TX_LED_PIN  LED_BUILTIN // Transmit led pin
              // You probably don't need to edit below //
              Nca78N 1 Reply Last reply
                #define ESP8266_OTA
                // RF24 settings
                // RF69 settings
                @Cliff-Karlsson said in 💬 MySWeMosGWShield:
                You've got your answer here. You should have MOhms especially between Vcc and GND pins where I have infinite resistance.
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  another stupid question, do I need the capacitator on the radio-side for it to work?
                  • E
                    E
                    emc2
                    It should indeed "beep" between all the pins.
                    NRF modules are also very fragile, once incorrectly plugged they are usually definitively toasted. So even if you desoldered and then resoldered them correctly it is unlikely they will work correctly.
                    Yes you need the capacitor radio side, it's the only required component, everything else is optional. It don't have to be 4.7µF, anything between 4.7 and 47µF will do, as stated in the assembly instructions.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      I have got some strange issue when using RFM69HW. I modified the sketch by chosing RFM instead of NRF, and also uncommented the line "MY_IS_RMF69HW"
                      Everything looks like it is working when using the serial console, the wemos gets an ip and I can add it to domoticz. But after a couple of minutes it stops working. Same if I power it from mobile charger directly, works a while then dies. I have tried with different Wemos and it is the same. Can a faulty radio cause this or could it be something other?
                      • E
                        E
                        emc2
                        Not sure. I do not have any RFM sensors, I tested the gateway for a little more than a week with a mock sensor and it was working. Maybe some logs could help?
                        You can also hook up the RFM shield to a regular arduino nano to do a serial gateway, this way you can check if it's radio dependent or not.
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Sometimes my own stupidity still amazes me. The pins of all my wemos where soldered at the oposite side as the ones in your examples. all the radios then got powered using 5v instead of 3.3v, not very suprising that the nrf radios got hot as h*ll and that nothing worked as it should.
                          Suprisingly the RFM69 seams to have survived. I guess the smd nrf24 all are toast.
                          Everything works perfekt now when I connected it correctly :)
                          • E
                            E
                            emc2
                            Glad to see you have it working!
                            Let me know if something was unclear in the instructions or if it can be improved to prevent people to solder them flipped.
                              Mynasru
                              Is it possible to free D2 on the WEMOS, it is used on most WEMOS shields for I2C.
                              E 1 Reply Last reply
                              • M Mynasru
                                E
                                E
                                emc2
                                @Mynasru unfortunately the only other suitable pin would be D1, SCL.
                                Wemos do not have enough pins to do gateway + I2C, you will need to switch to a nodeMCU or similar.
                                Also keep in mind that D2 is a MySensor default for ESP8266, I tried to have it moved when support was added https://github.com/mysensors/MySensors/issues/408#issuecomment-191403862 but without success, meaning you will need to reassign CE in your code.
                                • E emc2
                                  Mynasru
                                  @emc2 Hmm that's a pity. I could not find why specifically it was assigned to that pin other than that it is a MySensor default, so I thought maybe it can be changed (manually).
                                  I wanted to use the WEMOS system for my nodes, not as the gateway. But if it is not possible to free up D1 & D2, there is no benefit in using them. This board is the best I could find, I would order them if D2 is freed for D4. Could you make it possible to use one of both (with a jumper of some sort) so it is compatible with either WEMOS shields, or the MySensor defaults?
                                  • F
                                    F
                                    Fabien
                                    Very bad result with this PCB and Ebyte NRF24 PA+LNA module.
                                    If the shield is distant from the Wemos D1 (not upside) it works fine. There is interference between ESP and NRF I think.
                                    • F Fabien
                                      E
                                      E
                                      emc2
                                      @fabien Never heard of the "Ebyte NRF24 PA+LNA module", do you have a link for it somewhere?
                                      So far I've been using a few of these with the "regular no name" PA+LNA from Aliexpress and did not have any problems. What are the symptoms you are observing?
                                      • Nca78N
                                        I'm using EByte module with external antenna, and I have good results
                                        https://www.aliexpress.com/store/product/New-E01-ML01SP4-Ebyte-20dBm-1800m-2-4g-rf-module-smd-nRF24L01-PA-rf-wireless-receiver/2077046_32687064881.html
                                        Chip or integrated antenna with pa+lna are not efficient, I had poor radio performance with them...
                                        • E
                                          E
                                          emc2
                                          Looks like a neat module indeed.
                                          Never tried these, but yes I guess if the external antenna and the wifi antenna are too close it may leat to some interferences.
                                          Would also need to check that the 3.3V is powerful enough to properly feed the esp and this chip at the same time, I guess it may depends on the antenna plugged to it too.
