๐ฌ MySWeMosGWShield - WeMos Mini MySensors Gateway Shield
Ok, this is a really stupid question but how do I use this with for example Domoticz? Do I still need to connect it to the usb-port or do I connect using MQTT or some other way?
Ok, I just soldered two of the shield using smd nrf-radios but I only got alot of errors from the serial monitor. Also the boards got hot as hell after a minute. The wemos was really hot and the nrf was untuchable.
I through that had done something wrong with the first shield so I soldered another but it was also as hot as the first.
And should I enter the SSID and password for my home wifi-network or should I use the sketch to create a new? I tried both with no success as I got some default network called aitinker or similar both times.
It should not get hot at all. The Wemos can get a few ยฐC above room temperature but definitively not "hot as hell"
It happened to me once, when I had some solder joints between 2 pins of the NRF. You may want to test with a multimeter if, when the WeMos is unplugged, you have any shorts between adjacent pins.
A picture of the soldered board may help too.Best way is to edit the example sketch by adding your Wifi credentials on it before uploading them.
Hello, After soldering the radio and before connecting to power you should use a multimeter in "continuity" mode and make sure you have no contact between adjacent pins of the radio. I never connect a circuit using SMD nrf24 without having done this test.
@Nca78 said in ๐ฌ MySWeMosGWShield:
Ok, I have tried several times now soldering/resoldreing the radio with same result. Continuity, that means direct contact? I get several hundreds of ohms between a few of the pads but it does not "beep" anywhere :)
Can something in my sketch cause this or is it 100% hardware issue?
This is what I am using:
// ** WiFi and network configuration ** #define MY_ESP8266_SSID "My SSID" #define MY_ESP8266_PASSWORD "My password" // Set the hostname for the WiFi Client. This is the hostname // it will pass to the DHCP server if not static. #define MY_ESP8266_HOSTNAME "MySWeMosGWNRF" // Enable UDP communication //#define MY_USE_UDP // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP) //#define MY_IP_ADDRESS 192,168,178,87 // If using static ip you need to define Gateway and Subnet address as well #define MY_IP_GATEWAY_ADDRESS 192,168,178,1 #define MY_IP_SUBNET_ADDRESS 255,255,255,0 // The port to keep open on node server mode #define MY_PORT 5003 // How many clients should be able to connect to this gateway (default 1) #define MY_GATEWAY_MAX_CLIENTS 2 // Controller ip address. Enables client mode (default is "server" mode). // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere. //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68 // ** OTA updates configuration ** // Enable OTA updates for ESP8266 based gateway #define ESP8266_OTA // Define password for OTA updates (recommended but optional) //#define ESP8266_OTA_PASSWORD "MySuperSecretOTAPassword" // ** MySensors Radio configuration ** // Enables and select radio type (if attached) #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 // RF24 settings // Use custom RF24 channel (default 76) //#define MY_RF24_CHANNEL 42 // Decrease RF24 power transmission, useful to test in case of Tx problems. // If your problem is fixed consider adding the 5V to 3.3V voltage regulator //#define MY_RF24_PA_LEVEL RF24_PA_LOW // Enables RF24 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key) //#define MY_RF24_ENABLE_ENCRYPTION // RF69 settings // RFM69 Frequency, default = 868MHz #define MY_RFM69_FREQUENCY RF69_868MHZ // RFM69 frequency to use (RF69_433MHZ for 433MHz, RF69_868MHZ for 868MHz or RF69_915MHZ for 915MHz) // RFM69 Network ID. Use the same for all nodes that will talk to each other, default = 100 //#define MY_RFM69_NETWORKID 42 // Enables RFM69 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key) //#define MY_RFM69_ENABLE_ENCRYPTION // Disable this if you're not running the RFM69HW model (RFM69HW is recommended on the gateway for better coverage) #define MY_IS_RFM69HW // ** Mysensors additional functions ** // Enable inclusion mode //#define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway //#define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) //#define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button //#define MY_INCLUSION_MODE_BUTTON_PIN D3 // GPIO 0 // Software signing settings //#define MY_SIGNING_SOFT //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A0 // Hardware signing settings (currently unsupported?) //#define MY_SIGNING_ATSHA204 //#define MY_SIGNING_ATSHA204_PIN D0 // GPIO 16 // General signing settings // Enable this if you want destination node to sign all messages sent to this gateway. //#define MY_SIGNING_REQUEST_SIGNATURES // Enable node whitelisting //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}} // Flash leds on rx/tx/err // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Led pins used if blinking feature is enabled above // LED_BUILTIN, the on board LED is used (D4, GPIO 2) #define MY_DEFAULT_ERR_LED_PIN LED_BUILTIN // Error led pin #define MY_DEFAULT_RX_LED_PIN LED_BUILTIN // Receive led pin #define MY_DEFAULT_TX_LED_PIN LED_BUILTIN // Transmit led pin // Enable debug prints to serial monitor #define MY_DEBUG // **************************************// // You probably don't need to edit below // // **************************************// ... -
// ** WiFi and network configuration ** #define MY_ESP8266_SSID "My SSID" #define MY_ESP8266_PASSWORD "My password" // Set the hostname for the WiFi Client. This is the hostname // it will pass to the DHCP server if not static. #define MY_ESP8266_HOSTNAME "MySWeMosGWNRF" // Enable UDP communication //#define MY_USE_UDP // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP) //#define MY_IP_ADDRESS 192,168,178,87 // If using static ip you need to define Gateway and Subnet address as well #define MY_IP_GATEWAY_ADDRESS 192,168,178,1 #define MY_IP_SUBNET_ADDRESS 255,255,255,0 // The port to keep open on node server mode #define MY_PORT 5003 // How many clients should be able to connect to this gateway (default 1) #define MY_GATEWAY_MAX_CLIENTS 2 // Controller ip address. Enables client mode (default is "server" mode). // Also enable this if MY_USE_UDP is used and you want sensor data sent somewhere. //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68 // ** OTA updates configuration ** // Enable OTA updates for ESP8266 based gateway #define ESP8266_OTA // Define password for OTA updates (recommended but optional) //#define ESP8266_OTA_PASSWORD "MySuperSecretOTAPassword" // ** MySensors Radio configuration ** // Enables and select radio type (if attached) #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 // RF24 settings // Use custom RF24 channel (default 76) //#define MY_RF24_CHANNEL 42 // Decrease RF24 power transmission, useful to test in case of Tx problems. // If your problem is fixed consider adding the 5V to 3.3V voltage regulator //#define MY_RF24_PA_LEVEL RF24_PA_LOW // Enables RF24 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key) //#define MY_RF24_ENABLE_ENCRYPTION // RF69 settings // RFM69 Frequency, default = 868MHz #define MY_RFM69_FREQUENCY RF69_868MHZ // RFM69 frequency to use (RF69_433MHZ for 433MHz, RF69_868MHZ for 868MHz or RF69_915MHZ for 915MHz) // RFM69 Network ID. Use the same for all nodes that will talk to each other, default = 100 //#define MY_RFM69_NETWORKID 42 // Enables RFM69 encryption (all nodes and gateway must have this enabled, and all must be personalized with the same AES key) //#define MY_RFM69_ENABLE_ENCRYPTION // Disable this if you're not running the RFM69HW model (RFM69HW is recommended on the gateway for better coverage) #define MY_IS_RFM69HW // ** Mysensors additional functions ** // Enable inclusion mode //#define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway //#define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) //#define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button //#define MY_INCLUSION_MODE_BUTTON_PIN D3 // GPIO 0 // Software signing settings //#define MY_SIGNING_SOFT //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A0 // Hardware signing settings (currently unsupported?) //#define MY_SIGNING_ATSHA204 //#define MY_SIGNING_ATSHA204_PIN D0 // GPIO 16 // General signing settings // Enable this if you want destination node to sign all messages sent to this gateway. //#define MY_SIGNING_REQUEST_SIGNATURES // Enable node whitelisting //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}} // Flash leds on rx/tx/err // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Led pins used if blinking feature is enabled above // LED_BUILTIN, the on board LED is used (D4, GPIO 2) #define MY_DEFAULT_ERR_LED_PIN LED_BUILTIN // Error led pin #define MY_DEFAULT_RX_LED_PIN LED_BUILTIN // Receive led pin #define MY_DEFAULT_TX_LED_PIN LED_BUILTIN // Transmit led pin // Enable debug prints to serial monitor #define MY_DEBUG // **************************************// // You probably don't need to edit below // // **************************************// ...@Cliff-Karlsson said in ๐ฌ MySWeMosGWShield:
You've got your answer here. You should have MOhms especially between Vcc and GND pins where I have infinite resistance.
another stupid question, do I need the capacitator on the radio-side for it to work?
It should indeed "beep" between all the pins.
NRF modules are also very fragile, once incorrectly plugged they are usually definitively toasted. So even if you desoldered and then resoldered them correctly it is unlikely they will work correctly.
Yes you need the capacitor radio side, it's the only required component, everything else is optional. It don't have to be 4.7ยตF, anything between 4.7 and 47ยตF will do, as stated in the assembly instructions.
I have got some strange issue when using RFM69HW. I modified the sketch by chosing RFM instead of NRF, and also uncommented the line "MY_IS_RMF69HW"
Everything looks like it is working when using the serial console, the wemos gets an ip and I can add it to domoticz. But after a couple of minutes it stops working. Same if I power it from mobile charger directly, works a while then dies. I have tried with different Wemos and it is the same. Can a faulty radio cause this or could it be something other? -
Not sure. I do not have any RFM sensors, I tested the gateway for a little more than a week with a mock sensor and it was working. Maybe some logs could help?
You can also hook up the RFM shield to a regular arduino nano to do a serial gateway, this way you can check if it's radio dependent or not.
Sometimes my own stupidity still amazes me. The pins of all my wemos where soldered at the oposite side as the ones in your examples. all the radios then got powered using 5v instead of 3.3v, not very suprising that the nrf radios got hot as h*ll and that nothing worked as it should.
Suprisingly the RFM69 seams to have survived. I guess the smd nrf24 all are toast.
Everything works perfekt now when I connected it correctly :)
Glad to see you have it working!
Let me know if something was unclear in the instructions or if it can be improved to prevent people to solder them flipped.
@Mynasru unfortunately the only other suitable pin would be D1, SCL.
Wemos do not have enough pins to do gateway + I2C, you will need to switch to a nodeMCU or similar.Also keep in mind that D2 is a MySensor default for ESP8266, I tried to have it moved when support was added https://github.com/mysensors/MySensors/issues/408#issuecomment-191403862 but without success, meaning you will need to reassign CE in your code.
@emc2 Hmm that's a pity. I could not find why specifically it was assigned to that pin other than that it is a MySensor default, so I thought maybe it can be changed (manually).
I wanted to use the WEMOS system for my nodes, not as the gateway. But if it is not possible to free up D1 & D2, there is no benefit in using them. This board is the best I could find, I would order them if D2 is freed for D4. Could you make it possible to use one of both (with a jumper of some sort) so it is compatible with either WEMOS shields, or the MySensor defaults?
Very bad result with this PCB and Ebyte NRF24 PA+LNA module.
If the shield is distant from the Wemos D1 (not upside) it works fine. There is interference between ESP and NRF I think.@fabien Never heard of the "Ebyte NRF24 PA+LNA module", do you have a link for it somewhere?
So far I've been using a few of these with the "regular no name" PA+LNA from Aliexpress and did not have any problems. What are the symptoms you are observing?
I'm using EByte module with external antenna, and I have good results
https://www.aliexpress.com/store/product/New-E01-ML01SP4-Ebyte-20dBm-1800m-2-4g-rf-module-smd-nRF24L01-PA-rf-wireless-receiver/2077046_32687064881.htmlChip or integrated antenna with pa+lna are not efficient, I had poor radio performance with them...
With your input, this post could be even better ๐
