  3. 💬 MySensors Light Switch
solid state relaymysensorshlk-pm01nrf24l01
10 Posts 8 Posters 6.6k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/342/MySensors-Light-Switch
      sundberg84S
      sundberg84S
      @dpressle - Nice work!
      • T
        Toyman
        Can it be installed as normal in-wall switch ie with one wire only? or it needs both L and N 220v wires?
          You would need both L/N. The node requires power to operate.
          I've only seen a few dimmer solutions that can drive themselves (with only L) by letting a small current pass through the load all the time. This is not possible when dealing with relays.
          dpressleD 1 Reply Last reply
          • T
            Toyman
            Thanks. AFAIK, Livolo switches can do that
              dpressleD
              dpressleD
              dpressle
              @hek ++++1
              • L
                L
                Lucien
                Hi, I like your project. Can you share the schematic? I maybe would like to minimize the print by using only 1 relay channel. Thanks in advance.
                • L Lucien
                  dpressleD
                  dpressleD
                  dpressle
                  @Lucien Sorry for the delay, i will post it soon.
                  • dirkcD
                    dirkcD
                    dirkc
                    wrote on last edited by dirkc
                    What kind of Solid State Relay do you use? Can you switch 230V/4W LED bulbs with this Solid State Relay? I tried some "Songle" relays once and that causes the bulb to flicker all the time.
                    Controller: Home Assistant & FHEM - Gateway: ESP8266wifi - MySensors: 2.3.2 (nRF24)
                    • dbemowskD
                      dbemowskD
                      I like those relays. Is that 3 different switched outputs? One thing I always liked about european wall switches is that they give you more room for components. I would like to use a similar type of relay for my in-wall switches, but with the way US single gang wall boxes are, there is a pretty narrow space constraint. I might be able to fit it if I did away with the thermal fuse, but I don't want to give up tat bit of added safety just for that.
