  2. Announcements
  3. 💬 FOTA (Wireless Programming)
wirelessupdateover the airsensebenderfotafirmware over the airwireless programming
130 Posts 46 Posters 81.9k Views 44 Watching
  • maghacM maghac
    I'd like to try this on my Pro Mini clone, but unfortunately I find the instructions very confusing.
    What are fuses and why do I need to change them? To what do I need to change them?
    I cannot see "Arduino Mini pro MYSBootloader" in Boards.
    I am using Mysensors 2.1.
    sundberg84S
    sundberg84S
    #44
    @maghac - https://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5 here is a good tutorial how to burn a bootloader. You need to select a bootloader you want to use. They all have different properties. The fuses are burned when you burn the bootloader. The wirelsess programming tutorial is found here: https://www.mysensors.org/about/ota
      The suggested bootloader programmers in the article work with all Arduino Mini pro, UNO, MEGA and so on? I have searched around Aliexpress for "USBASP" but it seems they support only windows 7 and the common description is " USBASP USBISP AVR Programmer USB ATMEGA8 ATMEGA128" so it's kind of confusing for me
      • tbowmoT
        tbowmoT
        tbowmo
        They should work with all of the "old" AVR line of atmel processors (attiny, atmega)
        If you go with newer processors like atsam procssor line, you need to have a CMSIS adapter instead.
        Btw. they should work on both windows and linux (and newer versions of windows as well)
        • H
          H
          hiddenuser
          Hi there,
          I have a RPI running my gateway(/dev/ttyUSB020) and domoticz is running on the rpi too. How do I used MYSBootloader to push sketches to my sensors?
          gohanG 1 Reply Last reply
          • H hiddenuser
            Hi there,
            @hiddenuser https://www.mysensors.org/about/ota
            Then I suggest you configure the gateway as an ethernet gateway and use myscontroller to assign the firmware to the nodes
            • B
              B
              bilbolodz
              It's not quite clear for my how to use MYSBootloader for OTA. I'm running Domoticz as a controller (on RPI) and my gateway also is running on RPI (NRF on GPIO). Should have I one more arduino gateway connected to Windows machine running MYSController? As far I know there could be only one gateway in mysensors network.
                You just connect myscontroller to the gateway running on the RPI if it is configured as ethernet
                maghacM 1 Reply Last reply
                  maghacM
                  maghacM
                  maghac
                  I installed mycontroller.org for this purpose (OTA updates).
                  I have a MQTT gateway running on a NodeMCU, which connects to my MQTT server (mosquitto running on a ubuntu server) via wifi. This setup works very well, and I don't have to keep anything running on my desktop machine (which is a windows 10 box) while the OTA updates are being pushed out (which takes ages, since they are running on battery and only wake up once every few hours).
                  • maghacM maghac
                    rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    @maghac said in 💬 Wireless Programming:
                    updates a
                    lately I was also tinkering with the OTA updates. I'm using RPI as a gateway and controller at the same time. I'm using MQTT gateway and the controller software is OpenHAB. As I studied the documentation about OTA I learned that it is not working with MQTT gateway. Can You explain how to setup OTA with MQTT gateway ? For now I have to kill the MQTT gateway process and launch serial gateway with virtual serial port which in turn has to be shared through the network with the ser2net to be able to use it with mycontroller running on my desktop.
                    • rozpruwaczR rozpruwacz
                      updates a
                      maghacM
                      maghacM
                      maghac
                      @rozpruwacz Have a look here: https://forum.mysensors.org/topic/4345/mqtt-client-gateway-node-controller-ota
                      • hoegaarden_bierH
                        hoegaarden_bierH
                        hoegaarden_bier
                        Not sure what I am doing wrong here,... I followed the instructions for bootloader MYSController using an 'Arduino as ISP',... now when trying eg. the Blink sketch, I see that it takes about 10 seconds before it starts and after some 'blinks' it seems to miss some 'blinks',... any suggestions what might be wrong? The normal optiboot seems to work fine...
                        • maghacM
                          maghacM
                          maghac
                          I just enabled OTA on a non-sleeping node - it doesn't call smartSleep() and the loop function is mostly empty (except for sending one initial message). I do have a receive() function since I need to respond to incoming messages.
                          How can I properly enable OTA in this kind of node? Sending the "New firmware" command in MyController sends the message which gets caught by receive() and just gives me an error message since it's not one of the message types I expect. Telling the node to reboot sends it into some sort of endless loop which I cannot break unless I kill power to the board.
                          • maghacM maghac
                            @maghac did you see this? https://forum.mysensors.org/topic/6769/node-reboot-issue/7
                              maghacM
                              maghacM
                              maghac
                              @gohan Thanks. I seem to have the same issue and I'm also using a 5V pro mini, although I actually am using the MYSBootloader.
                              • maghacM
                                maghacM
                                maghac
                                I am having problems flashing a new bootloader on a 5V 16Mhz Pro Mini board. Or rather. the flashing is fine, it's just that I cannot upload a new sketch via FTDI afterwards.
                                Here are my custom entries from boards.txt:
                                proMYSBL.name=ATmega328 16Mhz MYSBootloader 1.3 beta
                                proMYSBL.upload.tool=avrdude
                                proMYSBL.upload.speed=115200
                                proMYSBL.bootloader.extended_fuses=0xfe
                                proMYSBL.build.mcu=atmega328p
                                proMYSBL.build.board=AVR_UNO
                                proMYSBL.build.core=arduino
                                proMYSBL16.name=ATmega328 16Mhz MYSBootloader 1.3 beta DEV
                                proMYSBL16.upload.tool=avrdude
                                proMYSBL16.upload.protocol=arduino
                                proMYSBL16.upload.maximum_size=30720
                                proMYSBL16.upload.maximum_data_size=2048
                                proMYSBL16.upload.speed=57600
                                proMYSBL16.bootloader.tool=avrdude
                                proMYSBL16.bootloader.low_fuses=0xF7
                                proMYSBL16.bootloader.high_fuses=0xDA
                                proMYSBL16.bootloader.extended_fuses=0xFD
                                proMYSBL16.bootloader.unlock_bits=0x3F
                                proMYSBL16.bootloader.lock_bits=0x0F
                                proMYSBL16.bootloader.file=MySensors/MYSBootloader_16MHz.hex
                                proMYSBL16.build.mcu=atmega328p
                                proMYSBL16.build.f_cpu=16000000L
                                proMYSBL16.build.board=AVR_UNO
                                proMYSBL16.build.core=arduino
                                proMYSBL16.build.variant=standard
                                proMYSBL8.name=ATmega328 8Mhz MYSBootloader 1.3 beta DEV
                                proMYSBL8.upload.tool=avrdude
                                proMYSBL8.upload.speed=57600
                                proMYSBL8.bootloader.high_fuses=0xD2
                                proMYSBL8.bootloader.extended_fuses=0xFE
                                proMYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
                                proMYSBL8.build.board=AVR_UNO
                                proMYSBL8.build.core=arduino
                                MYSBootloader.hex is from the master branch of MYSBootloader 1.3.0-beta.3, the other two are from the development branch.
                                Doesn't matter which one I use, I can never get my 5V 16MHz boards to accept a new sketch via FTDI cable. I have to go back to the standard Pro Mini bootloader.
                                • maghacM maghac
                                  @maghac why don't you use the ota feature?
                                    maghacM
                                    maghacM
                                    maghac
                                    @gohan Good question :)
                                    I was afraid it would get stuck in a neverending loop and I would have to cycle power to the board, but actually OTA programming with mycontroller works fine.
                                    The problem is that OTA uploades takes around 10 mins, which is annoying if I want to test something while I have the node on my desk, before placing it somewhere in my house. So while I anyway have it on the desk, I'd like to use the FTDI cable.
                                    Anyway, things seem to work fine now :)
                                    • A
                                      arraWX
                                      Is it possible to do FOTA from my raspberry pi (serial gateway + domoticz)?
                                      As it is now I move the gateway from the rpi to a windows pc running MYSController. It would be nice to avoid this step.
                                      V 1 Reply Last reply
                                      • A arraWX
                                        V
                                        V
                                        Viciousman
                                        wrote on last edited by Viciousman
                                        #62
                                        @arraWX you can create a Ethernet gateway in raspberry pi and connect MYScontroller to you raspberry pi gateway.
                                        See instructions to create raspberrypi ethernet gateway on https://www.mysensors.org/build/raspberry
                                        From there you can perform FOTA in MYScontroller.
                                        A 1 Reply Last reply
                                        • V Viciousman
                                          arraWX
                                          @Viciousman Thank you!
                                          How do I create a Ethernet gateway?
                                          Will I have to build this: https://www.mysensors.org/build/ethernet_gateway
                                          or
                                          Will I have to do some kind of configuration on the rpi and continue using my serial gateway?
