  3. Central Heating Controls
4 Posts 2 Posters 2.3k Views 3 Watching
  • AndyDHillA Offline
    AndyDHillA Offline
    AndyDHill
    Has anyone developed a Central Heating control / Water heating control time clock that links via mysensors to HA envioronment? No point in re-inventing the wheel if its already mysensor invented?
    If not would anybody be interested in one ?
      That's a quite general project. Heating systems may differ quite a lot from one another, so sw solution should be made accordingly
        AndyDHillA Offline
        AndyDHill
        This :
        alt text iS typical UK time clock for central heating, has anyone built one like this for control ....
          It depends if it is a normal relay on/off command or a bus communication. If it is the first case you could replace it with a node and a relay (could be arduino mini pro or esp8266 + relay) and a temperature sensor and set up the controller with time schedule and temperatures you want during the day. My personal suggestion if you have just an on/off command is to get something like a Netatmo thermostat (I have one and I am so happy with it) because they use a learning algorithm that adapts automatically according to your house heating system that keeps temperature constant taking advantage of the heating inertia (implementing it in a controller is really an hassle). For water heating it is simpler as you may just need a relay and schedule on/off on the controller
