  3. Gateway just another sensor node?
11 Posts 5 Posters 4.1k Views 5 Watching
  • A
    Akkarin
    Hello
    in the release notes for API 2.0 i was reading: "Gateway just another sensor node!". But i wasn't able to find the solution.
    I've already read this (and sublinks):
    [https://forum.mysensors.org/topic/4066/ethernet-gateway-working-as-sensor-node-it-s-possible](link url)
    What i'm trying to test is a combination of arduino nano+W5100+MQ9 gas sensor. For test purposes i would only like to transmit the voltage value to controller (FHEM). Therefor i've merged some of examples and adjusted them the way i thought it would work. The sketch is based on the GatewayW5100 example. RF communication is disabled.Library v.2.1.1 (new installation)
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    //#ifndef MY_RF24_CE_PIN
    //#define MY_RF24_CE_PIN 5
    //#endif
    //#ifndef MY_RF24_CS_PIN
    //#define MY_RF24_CS_PIN 6
    //#endif
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,0,151   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 101
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    #define CHILD_ID_MQ 15
    float valMQ =0.0;
    float lastMQ =0.0;
    MyMessage msg(CHILD_ID_MQ, V_LEVEL);
        sendSketchInfo("Air Quality Sensor - Test", "1.0");
        present(CHILD_ID_MQ, S_AIR_QUALITY);
      float sensor_volt;
      float RS_air; //  Get the value of RS via in a clear air
      float R0;  // Get the value of R0 via in LPG
      float sensorValue;
    /*--- Get a average data by testing 100 times ---*/
        for(int x = 0 ; x < 100 ; x++)
        sensorValue = sensorValue + analogRead(A0);
      sensorValue = sensorValue/100.0;
      sensor_volt = sensorValue/1024*5.0;
      RS_air = (5.0-sensor_volt)/sensor_volt; // omit *RL
      R0 = RS_air/9.9; // The ratio of RS/R0 is 9.9 in LPG gas
      Serial.print("sensor_volt = ");
      Serial.print(sensor_volt);
      Serial.println("V");
      Serial.print("R0 = ");
      Serial.println(R0);
      uint16_t valMQ = R0;
      if (valMQ != lastMQ) {
          send(msg.set((int16_t)ceil(valMQ)));
          lastMQ = ceil(valMQ);
      delay(10000);
    Connection from gateway to controller is opened, but no values arrive.
    Serial output is repeating every second and missing some output values and delay:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
    IP: 192.168.0.151
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    sensor_volt = 0.0
    If i put comments on the "send" command the serial output is correct.
    Any idea which settings are wrong/ missing to get the setup run as ethernet connected sensor?
    Thx in advance
      I think the code is missing the send command for the voltage. Also include a little longer serial output. Did you check with myscontroller if actually no values are sent?
        Use wait(), never delay().
        A 1 Reply Last reply
        • A
          Akkarin
          i'm trying to send the R0 value which is calculated from voltage
            OK, but you need to post complete code that gives problem and longer serial output
              Akkarin
              @hek
              i've changed delay to wait, but the behaviour is still the same. Seems like "my" serial output in the loop is overwritten by the "debug" serial output.
              It is somehow related to the send command and usage of gateway as a sensor, but i don't get whats wrong :confused:
                Akkarin
                @gohan
                the code was complete in the first post (now its only "wait" instead of "delay" in the end).
                Here is a longer serial output for active "send command":
                IP: 192.168.0.151
                sensor_volt = 0.0;0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
                IP: 192.168.0.151
                IP: 192.168.0.151
                IP: 192.168.0.151
                IP: 192.168.0.151
                IP: 192.168.0.151
                And here is how its look like if send command is commented:
                IP: 192.168.0.151
                sensor_volt = 0.05V
                R0 = 10.84
                sensor_volt = 0.05V
                R0 = 10.83
                sensor_volt = 0.05V
                R0 = 10.83
                  You cannot print your own debug messages on a serial gateway as it is the mean of communication against the gateway. The controller will try to interpret your prints according to the serial protocol.
                  core_cC 1 Reply Last reply
                  • Michiel van der WulpM
                    Please check if you are not having resets in your gateway due to this:
                    https://forum.mysensors.org/topic/4462/gatewayw5100-unable-to-get-working-w-v2-0-0
                    https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/6
                    Regards,
                    Michiel
                    • A
                      Akkarin
                      @Michiel-van-der-Wulp and @hek
                      Guys, thank you for fast help. Both answers helped me to solve the problem!
                        core_cC
                        core_cC
                        core_c
                        @hek I found that out while testing my very first/current gateway. Also, it is no good idea to define MY_DISABLED_SERIAL. (sssst, don't tell anyone i did that).
                        ..but still, it's assuring to have my findings confirmed by an expert.
