  3. Gateway just another sensor node?
11 Posts 5 Posters 4.1k Views 5 Watching
    I think the code is missing the send command for the voltage. Also include a little longer serial output. Did you check with myscontroller if actually no values are sent?
      Use wait(), never delay().
      A 1 Reply Last reply
      • A
        Akkarin
        i'm trying to send the R0 value which is calculated from voltage
        for(int x = 0 ; x < 100 ; x++)
          sensorValue = sensorValue + analogRead(A0);
        sensorValue = sensorValue/100.0;
        sensor_volt = sensorValue/1024*5.0;
        RS_air = (5.0-sensor_volt)/sensor_volt; // omit *RL
        R0 = RS_air/9.9; // The ratio of RS/R0 is 9.9 in LPG gas
          OK, but you need to post complete code that gives problem and longer serial output
            Akkarin
            @hek
            i've changed delay to wait, but the behaviour is still the same. Seems like "my" serial output in the loop is overwritten by the "debug" serial output.
            It is somehow related to the send command and usage of gateway as a sensor, but i don't get whats wrong :confused:
              Akkarin
              @gohan
              the code was complete in the first post (now its only "wait" instead of "delay" in the end).
              Here is a longer serial output for active "send command":
              0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
              IP: 192.168.0.151
              0;255;3;0;9;MCO:BGN:STP
              0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
              sensor_volt = 0.0;0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
              IP: 192.168.0.151
              IP: 192.168.0.151
              IP: 192.168.0.151
              IP: 192.168.0.151
              IP: 192.168.0.151
              And here is how its look like if send command is commented:
              IP: 192.168.0.151
              sensor_volt = 0.05V
              R0 = 10.84
              sensor_volt = 0.05V
              R0 = 10.83
              sensor_volt = 0.05V
              R0 = 10.83
                You cannot print your own debug messages on a serial gateway as it is the mean of communication against the gateway. The controller will try to interpret your prints according to the serial protocol.
                core_cC 1 Reply Last reply
                • Michiel van der WulpM
                  Please check if you are not having resets in your gateway due to this:
                  https://forum.mysensors.org/topic/4462/gatewayw5100-unable-to-get-working-w-v2-0-0
                  https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/6
                  Regards,
                  Michiel
                  • A
                    Akkarin
                    @Michiel-van-der-Wulp and @hek
                    Guys, thank you for fast help. Both answers helped me to solve the problem!
                      core_cC
                      core_cC
                      core_c
                      @hek I found that out while testing my very first/current gateway. Also, it is no good idea to define MY_DISABLED_SERIAL. (sssst, don't tell anyone i did that).
                      ..but still, it's assuring to have my findings confirmed by an expert.
