  3. Double Micro (nano) Ampere meter
54 Posts 9 Posters 24.0k Views 11 Watching
  • korttomaK
    korttomaK
    korttoma
    I need this! Please publish instructions ;)
    • Tomas
    • D
      DavidZH
      Awsome!
      I'd like to compare your impressive array of measurement devices against my Agilent U1273A. Actually to decide if I need a µCurrent.... Maybe in an upcoming meetup in NL or BE this summer?
      AWIA 1 Reply Last reply
        That looks impressive. I'll be waiting for the instructions too 😀
        • Nca78N
          Wow, that looks nice, I'm stucked with my multimeter and couldn't find the parts avaiable for delivery here to build a µcurrent gold.
          Please publish the build instructions !
          (Maybe if you could give use the BOM first, then you'll have plenty of time to publish build instruction before we get delivered ;))
          • D DavidZH
            Awsome!
            AWIA
            AWIA
            AWI
            @DavidZH Impressive only by numbers ;-) I am prepared to trade my µCurrent for the Agilent :blush:
            A meetup sounds good..any specific plans yet?
            D 1 Reply Last reply
            • AWIA
              AWIA
              AWI
              There it is Micro (nano) ampere meter (double). I need to add a schematic drawing. Any suggestions/ questions are welcome.
                Why all those headers are needed?
                • korttomaK
                  korttomaK
                  korttoma
                  Parts ordered :D
                  • Tomas
                    AWIA
                    AWIA
                    AWI
                    @gohan As mentioned in the description: I use it as a "patch panel" to distribute the power and ground to different devices. Wiring tends to get messy on my workbench...
                    0_1493190896839_upload-a61c084d-a4db-4964-957e-b3c442ec570e
                    Not mine but similar ;-)
                      Oh ok, you use it like an integrated breadboard 😀
                      • AWIA AWI
                        sundberg84S
                        sundberg84S
                        @AWI - did you steal my image on my workbench ;) j/k.
                        We need to revive the old workbench topic again!
                          Are resistor needed with a tight tolerance or else?
                            AWIA
                            AWIA
                            AWI
                            @gohan No special tolerance resistors needed. The only reason for choosing metal film resistors is that their temperature coefficient is better than carbon types (typical 50ppm/°C compared to 200-500ppm/°C).
                            As you will be calibrating the circuit you can choose from a large range (0.1 Ohm - 100 Ohm) for the shunt. This will only influence the burden voltage / sensitivity and range (Ohm's laws).
                            • AWIA AWI
                              DavidZH
                              @AWI Lemme think about that..... Uuuuuhm. no... 😈
                              I have no plans for a meetup. Lacking a proper venue for such a thing. Unfortunately.
                              • AWIA AWI
                                A very low current (double) stand alone uA meter to tune MySensors battery nodes..
                                0_1493111992919_upload-0091f8f7-8b1a-4d26-8c5d-f66cffe3408c
                                I de' MySensor'ized this project because it is more usefull on the workbench for measuring the very low currents of MySensors battery nodes. I own several Ampere meters including the famous µCurrent. Many of these are not accurate enough or need a lot of wiring and additional equipment (µCurrent). I just wanted something simple and stand alone
                                Using the low cost HX711 weight scale 24 bit AD converter a sub 10€ cost double µA meter was born. Some characteristics to fit MySensors projects:
                                • range channel A: ± 20mA 5½-6½ digit µA
                                • range channel B: ±40mA 5½-6½ digit µA
                                • burden voltage 1µV/1µA (internal resistance 1Ω)
                                • 'patch panel' on the connectors.
                                • easy calibration.
                                In comparison with the µCurrent and a standard multimeter in uA range
                                0_1493113275783_upload-2a33c4be-759a-46c6-af8f-57862ecf4e3c
                                The internals:
                                0_1493113146906_upload-9152b445-76e8-44e6-8625-530f33a80d20
                                Although it cannot compare in accuracy with the µCurrent (in combination with a good multimeter) it is more than useable and accurate to do some serious MySensors tuning.
                                If there is some interest I will try to publish a decent built instruction on Openhardware.io.
                                I'm interested.
                                Nca78N 1 Reply Last reply
                                  I'm interested.
                                  @NeverDie said in Double Micro (nano) Ampere meter:
                                  I'm interested.
                                  In case you haven't seen it, it's here :
                                  https://forum.mysensors.org/topic/6723/micro-nano-ampere-meter-double/5
                                  • Nca78N Nca78
                                    I'm interested.
                                    @Nca78 said in Double Micro (nano) Ampere meter:
                                    I'm interested.
                                    Thanks! It looks a bit complicated to me. I've used one of these breakout boards (https://www.amazon.com/gp/product/B00OPVBEQO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) as a way to measure 24-bit voltage on capacitors, and it works really well. As you can perhaps tell from the photo:
                                    the chip is fairly simple to use. What I especially liked is that there was already a demo arduino sketch for interfacing with it. That was a real time saver. If I were to build something, I might try that first, if only because it seems like it might be easier (though perhaps, in part, because I'm already comfortable with it). Would using it in conjunction with a sense resistor be all it would take to make an accurate, high resolution current sensor?
                                    AWIA 2 Replies Last reply
                                      I'm interested.
                                      AWIA
                                      AWIA
                                      AWI
                                      @NeverDie that one would work as well. Maybe harder to get and a little more pricy :moneybag:
                                        I'm interested.
                                        AWIA
                                        AWIA
                                        AWI
                                        btw. Which part looks complicated? It's just a few resistors attached to an ADC board (and sketch ready) I am curious on how you can build something simpler with the ADS1220 (which seems to be a better ADC if you are able to find it somewhere ;-))
                                          #23
                                          It sounds like I was mistaken then. In my quick read I thought that I had to implement the entire schematic, not just add a couple of resistors to a pre-made breakout board. I suppose if the schematic were more of a block diagram, that might be clearer for other future readers to quickly grasp, or maybe it's just me.
                                          Why would the ADS1220 be a better ADC? I really haven't looked into doing a comparison. I bought the breakout board that I pictured above from Amazon , but I see that it's out of stock now. I believe the company which made it is in India. I seem to recall that it's open source, so there's always that I suppose. I didn't mind ringing the till for the maker: it was all pre-made, it did what I needed at the time (which was watching in real-time the voltage leakage from supercapacitors that I was testing), it was available with free Amazon Prime delivery, and I wanted something sooner rather than later. So, it fit what I needed at the time. Most of those reasons relate to rapid availability though rather than technical reasons.
