  3. Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]
29 Posts 3 Posters 7.5k Views 4 Watching
    The mysensors protocol relies on the gateway, you can't do without it unless you are using other ping pong code that are not relying on mysensors.
    mppM 1 Reply Last reply
      mppM
      mppM
      mpp
      @gohan then shouldn't there be a note in the documentation of the ping pong sketch about this?
      MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
        I'll take a look
          I'll take a look
          mppM
          mppM
          mpp
          @gohan thanks!
            Actually it is explained in this page how the mysensors network works, but I'll see how to add a line in the example sketch
              mppM
              mppM
              mpp
              @gohan thanks for the feedback. According to that page it seems you not only need a gateway but also a controller. This explains why my nodes don't get a node id automatically.
                The controller is needed for auto ID, but it can also be used myscontroller. It is also written in different places that manual id should be set also in case of problems.
                  mppM
                  mppM
                  mpp
                  @gohan indeed you're right. What did you mean with "myscontroller"?
                  Setting the node id manually for the ping pong sketch makes them communicate to the Gateway:
                  #define MY_NODE_ID 201
                  Would auto ID work with the ESP MQTT Gateway and OpenHab controller?
                  I have an MQTT server up and running and OpenHab is installed with the following configuration in /etc/openhab2/services/mqtt.cfg:
                  broker.url=tcp://127.0.0.1:1883
                  broker.clientId=OpenHab
                  broker.retain=true
                  broker.async=false
                  Yet I still get !TSM:FPAR:NO REPLY
                    https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors
                    I'd start from the ethernet gateway and work it out from there, myscontroller works with ethernet gateway. In openhab I don't know how to enable auto id, but there must be something in documentation. To be honest assigning manually ID has to be done only once because it is saved in eeprom and read at every boot, so I don't see it so mandatory to have the controller handling it.
                      mppM
                      mppM
                      mpp
                      @gohan, do you mean http://www.mycontroller.org? I can't find any project page with downloads on the link you provided. There is a download link to a zip file somewhere in the comments but impossible to say if that is still up to date as it dates from 2015.
                        yes, it's the zip file. It is a windows app. Mycontroller it is actually a controller like Domoticz or Openhab. I know it is a little old, but it works.
                        • mppM
                          mppM
                          mpp
                          wrote on last edited by mpp
                          @gohan, I switched over to mycontroller (from OpenHab) and I'm using Arduino's nodes and I'm still getting errors not finding the parent.
                          I'm using the Mock sketch and tested with setting the ID manually but no luck.
                          4 TSM:INIT
                          4 TSF:WUR:MS=0
                          108 TSM:INIT:TSP OK
                          110 TSM:INIT:STATID=99
                          112 TSF:SID:OK,ID=99
                          114 TSM:FPAR
                          3241 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          5249 !TSM:FPAR:NO REPLY
                          5251 TSM:FPAR
                          8378 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          10385 !TSM:FPAR:NO REPLY
                          10387 TSM:FPAR
                          13514 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          15521 !TSM:FPAR:NO REPLY
                          15523 TSM:FPAR
                          Edit: adding a 4.7 capacitor didn't change this. Neither did downgrading to 2.0.
                          Starting sensor (RRNNA-, 2.0.0)
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=254)
                          TSM:FPAR
                          TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          Any idea?
                            On the gateway do you see any message received? Can you post the gateway log when nodes are registering?
                              mppM
                              mppM
                              mpp
                              @gohan, when using the WemosD1 (without capacitor!) and a static ID, I get the following:
                              0;255;3;0;9;TSF:MSG:READ,253-253-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:BC
                              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=253
                              0;255;3;0;9;TSF:PNG:SEND,TO=0
                              0;255;3;0;9;TSF:CKU:OK
                              0;255;3;0;9;TSF:MSG:GWL OK
                              0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                              0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              0;255;3;0;9;TSF:MSG:PINGED,ID=253,HP=1
                              0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                              0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                              0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                              0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/253/255/0/0/17
                              When I do the same for the Pro Mini, there is nothing to see. When I flash a Moteino test sketch it works properly.
                              gohanG 1 Reply Last reply
                              • mppM mpp
                                @mpp the gateway is getting the message and it replies so you could either have a power issue on gateway or range problem. How far are the gw and node?
                                  mppM
                                  mppM
                                  mpp
                                  @gohan tested with less than a meter up to 10 meters. In fact the Wemos Node now is working as it shows up in mycontroller but the Pro Mini doesn't receive a response from the GW.
                                    wrote on last edited by gohan
                                    #24
                                    Do you have other radio modules to try? If not, if you swap the radios do you see any changes? Are the radio rfm69 right?
                                      mppM
                                      mppM
                                      mpp
                                      @gohan I have several RFM69 radio's and they're all working (with the Moteino sketch) on a Pro Mini.
                                      Here's my config:
                                      #define MY_RADIO_RFM69
                                      #define MY_IS_RFM69HW
                                      #define MY_RF69_IRQ_PIN 4
                                      #define MY_RF69_SPI_CS 15
                                      #define MY_RFM69_NETWORKID 99
                                      #define MY_NODE_ID 123
                                      • mppM mpp
                                        Here's my config:
                                        mppM
                                        mppM
                                        mpp
                                        Removing some of the config lines seems to have an effect:
                                        4 TSM:INIT
                                        4 TSF:WUR:MS=0
                                        8 TSM:INIT:TSP OK
                                        10 TSF:SID:OK,ID=254
                                        12 TSM:FPAR
                                        143 TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                        1232 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        1239 TSF:MSG:FPAR OK,ID=0,D=1
                                        2150 TSM:FPAR:OK
                                        2150 TSM:ID
                                        2152 TSM:ID:OK
                                        2154 TSM:UPL
                                        2285 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        2314 TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        2320 !TSF:MSG:LEN,0!=8
                                        2435 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        2441 TSF:MSG:PONG RECV,HP=1
                                        2443 TSM:UPL:OK
                                        2445 TSM:READY:ID=254,PAR=0,DIS=1
                                        2580 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                                        2717 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=1,l=1,sg=0:1
                                        2723 !TSF:MSG:LEN,0!=8
                                        2795 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2936 !TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.1.1
                                        3076 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
                                        3110 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                                        3117 !TSF:MSG:LEN,0!=9
                                        Send Sketch Info: 5197 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=14,sg=0,ft=3,st=OK:MockMySensors
                                        5341 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=NACK:v0.5
                                        MockMySensors v0.5
                                        5480 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                                        5486 !TSF:MSG:LEN,0!=9
                                        Get Config: Metric
                                        Presenting Nodes
                                        ________________
                                          S_DOOR
                                        6375 TSF:MSG:SEND,254-254-0-0,s=1,c=0,t=0,pt=0,l=12,sg=0,ft=1,st=OK:Outside Door
                                        ________________
                                        6434 MCO:REG:REQ
                                        6567 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
                                        6664 TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=6,l=2,sg=0:0100
                                        6670 !TSF:MSG:LEN,0!=9
                                        6744 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        6750 MCO:PIM:NODE REG=1
                                        6752 MCO:BGN:STP
                                        GW Started
                                        7254 MCO:BGN:INIT OK,TSP=1
                                        RandomNumber:36
                                        Send Battery Level
                                        7290 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:36
                                        Request Time
                                        7929 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=NACK:
                                        Door is: Open
                                        8509 TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                                        System is: Armed
                                        8646 !TSF:MSG:SEND,254-254-0-0,s=1,c=1,t=15,pt=1,l=1,sg=0,ft=0,st=NACK:1
                                        8783 !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=NACK:36
                                        8792 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        8798 !TSF:MSG:LEN,0!=8
                                        So now the node is sending data but there's no ack/Invalid message length.
                                          Are they RFM69HW? What antenna are you using on them?
