  3. Ping Pong with ESP8266 results in !TSM:FPAR:NO REPLY [solved]
29 Posts 3 Posters 7.5k Views 4 Watching
    I forgot to ask: are you using any nrf24 or rfm69 radio or are you trying to make the esp8266 talk to each other over wifi?
    mppM 1 Reply Last reply
      mppM
      mppM
      mpp
      @gohan i'm using rfm69. Somehow I got it to work with one ESP gateway and 2 ESP nodes. All three have an rfm69 chip. I don't understand why you need a gateway to do ping pong?
      MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
        The mysensors protocol relies on the gateway, you can't do without it unless you are using other ping pong code that are not relying on mysensors.
          mppM
          mppM
          mpp
          @gohan then shouldn't there be a note in the documentation of the ping pong sketch about this?
            I'll take a look
              I'll take a look
              mppM
              mppM
              mpp
              @gohan thanks!
                Actually it is explained in this page how the mysensors network works, but I'll see how to add a line in the example sketch
                  mppM
                  mppM
                  mpp
                  @gohan thanks for the feedback. According to that page it seems you not only need a gateway but also a controller. This explains why my nodes don't get a node id automatically.
                    The controller is needed for auto ID, but it can also be used myscontroller. It is also written in different places that manual id should be set also in case of problems.
                      mppM
                      mppM
                      mpp
                      @gohan indeed you're right. What did you mean with "myscontroller"?
                      Setting the node id manually for the ping pong sketch makes them communicate to the Gateway:
                      #define MY_NODE_ID 201
                      Would auto ID work with the ESP MQTT Gateway and OpenHab controller?
                      I have an MQTT server up and running and OpenHab is installed with the following configuration in /etc/openhab2/services/mqtt.cfg:
                      broker.url=tcp://127.0.0.1:1883
                      broker.clientId=OpenHab
                      broker.retain=true
                      broker.async=false
                      Yet I still get !TSM:FPAR:NO REPLY
                        https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors
                        I'd start from the ethernet gateway and work it out from there, myscontroller works with ethernet gateway. In openhab I don't know how to enable auto id, but there must be something in documentation. To be honest assigning manually ID has to be done only once because it is saved in eeprom and read at every boot, so I don't see it so mandatory to have the controller handling it.
                          mppM
                          mppM
                          mpp
                          @gohan, do you mean http://www.mycontroller.org? I can't find any project page with downloads on the link you provided. There is a download link to a zip file somewhere in the comments but impossible to say if that is still up to date as it dates from 2015.
                            yes, it's the zip file. It is a windows app. Mycontroller it is actually a controller like Domoticz or Openhab. I know it is a little old, but it works.
                            • mppM
                              mppM
                              mpp
                              wrote on last edited by mpp
                              @gohan, I switched over to mycontroller (from OpenHab) and I'm using Arduino's nodes and I'm still getting errors not finding the parent.
                              I'm using the Mock sketch and tested with setting the ID manually but no luck.
                              4 TSM:INIT
                              4 TSF:WUR:MS=0
                              108 TSM:INIT:TSP OK
                              110 TSM:INIT:STATID=99
                              112 TSF:SID:OK,ID=99
                              114 TSM:FPAR
                              3241 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              5249 !TSM:FPAR:NO REPLY
                              5251 TSM:FPAR
                              8378 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              10385 !TSM:FPAR:NO REPLY
                              10387 TSM:FPAR
                              13514 TSF:MSG:SEND,99-99-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              15521 !TSM:FPAR:NO REPLY
                              15523 TSM:FPAR
                              Edit: adding a 4.7 capacitor didn't change this. Neither did downgrading to 2.0.
                              Starting sensor (RRNNA-, 2.0.0)
                              TSM:INIT
                              TSM:RADIO:OK
                              TSP:ASSIGNID:OK (ID=254)
                              TSM:FPAR
                              TSP:MSG:SEND 254-254-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              Any idea?
                                On the gateway do you see any message received? Can you post the gateway log when nodes are registering?
                                  mppM
                                  mppM
                                  mpp
                                  @gohan, when using the WemosD1 (without capacitor!) and a static ID, I get the following:
                                  0;255;3;0;9;TSF:MSG:READ,253-253-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;TSF:MSG:BC
                                  0;255;3;0;9;TSF:MSG:FPAR REQ,ID=253
                                  0;255;3;0;9;TSF:PNG:SEND,TO=0
                                  0;255;3;0;9;TSF:CKU:OK
                                  0;255;3;0;9;TSF:MSG:GWL OK
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                  0;255;3;0;9;TSF:MSG:PINGED,ID=253,HP=1
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  0;255;3;0;9;TSF:MSG:SEND,0-0-253-253,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  0;255;3;0;9;TSF:MSG:READ,253-253-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.1.1
                                  0;255;3;0;9;Sending message on topic: mpp-mygateway1-out/253/255/0/0/17
                                  When I do the same for the Pro Mini, there is nothing to see. When I flash a Moteino test sketch it works properly.
                                  gohanG 1 Reply Last reply
                                  • mppM mpp
                                    @mpp the gateway is getting the message and it replies so you could either have a power issue on gateway or range problem. How far are the gw and node?
                                      mppM
                                      mppM
                                      mpp
                                      @gohan tested with less than a meter up to 10 meters. In fact the Wemos Node now is working as it shows up in mycontroller but the Pro Mini doesn't receive a response from the GW.
                                        wrote on last edited by gohan
                                        #24
                                        Do you have other radio modules to try? If not, if you swap the radios do you see any changes? Are the radio rfm69 right?
                                          mppM
                                          mppM
                                          mpp
                                          @gohan I have several RFM69 radio's and they're all working (with the Moteino sketch) on a Pro Mini.
                                          Here's my config:
                                          #define MY_RADIO_RFM69
                                          #define MY_IS_RFM69HW
                                          #define MY_RF69_IRQ_PIN 4
                                          #define MY_RF69_SPI_CS 15
                                          #define MY_RFM69_NETWORKID 99
                                          #define MY_NODE_ID 123
