  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
  • Nicolas CharrierN
    Nicolas CharrierN
    Nicolas Charrier
    With this bootloader, i can not upload scetch with serial or USB.
    Where does i made a mistake?
    Is there a configuration that is specific to the bootloader?
    tekkaT 1 Reply Last reply
    • Nicolas CharrierN Nicolas Charrier
      tekkaT
      tekkaT
      tekka
      @Nicolas-Charrier Welcome to MySensors. Please do not post the same question in different threads. Maybe you can give additional information that help to understand what you tried so far (logs, screenshots, HW configuration, CPU frequency, etc.). Did you follow the OTA/bootloader instructions here?
      Nicolas CharrierN AffordableTechA 2 Replies Last reply
      • tekkaT tekka
        Nicolas CharrierN
        Nicolas CharrierN
        Nicolas Charrier
        @tekka
        I can now program my board with serial line. It's work perfectly.
        It's an issue with my serial converteur and an usb hub. The usb hub add a delay that is not compatible with the bootloader.
        Sorry for the question.
        Nico
          @tekka
          Nico
          tekkaT
          tekkaT
          tekka
          @Nicolas-Charrier Good to know, thanks for your feedback :)
          • kk02067K
            kk02067K
            kk02067
            Excuse me for beeing an idiot. But how do you compile the bootloader from source? Do you do it from Atmel studio or from Arduino IDE. And how is it done? When I compile it in Atmel studio it gets an base adress of 0x0000 which is wrong.
            I am used to program in assembler in Atmel studio and when I program in C i don't touch anyting else than the .c file. So some form of tutorial kind of thing would be helpful.
            Thank you
            • R
              R
              rvweert
              Hey all,
              I've compiled the bootloader and was able to install it with Arduino as ISP to a Nano. I couldn't find the lines necessary for the Nano in boards.txt so I created this:
              nanomysbootloader.name=Arduino Nano MYSBootloader
              nanomysbootloader.upload.tool=avrdude
              nanomysbootloader.upload.protocol=arduino
              nanomysbootloader.bootloader.tool=avrdude
              nanomysbootloader.bootloader.unlock_bits=0x3F
              nanomysbootloader.bootloader.lock_bits=0x0F
              nanomysbootloader.build.f_cpu=16000000L
              nanomysbootloader.build.board=AVR_NANO
              nanomysbootloader.build.core=arduino
              nanomysbootloader.build.variant=eightanaloginputs
              ## Arduino Nano w/ ATmega328
              nanomysbootloader.menu.cpu.atmega328=ATmega328
              nanomysbootloader.menu.cpu.atmega328.upload.maximum_size=30720
              nanomysbootloader.menu.cpu.atmega328.upload.maximum_data_size=2048
              nanomysbootloader.menu.cpu.atmega328.upload.speed=115200
              nanomysbootloader.menu.cpu.atmega328.bootloader.low_fuses=0xFF
              nanomysbootloader.menu.cpu.atmega328.bootloader.high_fuses=0xDA
              nanomysbootloader.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
              nanomysbootloader.menu.cpu.atmega328.bootloader.file=MySensors/MYSBootloader.hex
              nanomysbootloader.menu.cpu.atmega328.build.mcu=atmega328p
              Is this correct? Besides, on some devices I cannot program over serial anymore now, only through another ISP. Could that be caused by incorrect settings? Is it possible to recover from that?
              The error I'm getting is this one:
              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
              Thanks and happy easter!
              Rene
              • tekkaT tekka
                AffordableTechA
                AffordableTechA
                AffordableTech
                Hi All,
                I'm currently upgrading to MySensors 2.0.0 and it would make sense to change over to the MYSBootloader as I upgrade each node. (I'd like to be able to use the remote re-boot command from MYSController).
                I have been reading about the MYSBootloader and have some questions . . .
                Q1 - My nodes are a mixture of Pro-Micro's, Leonardo's, Mega 2560's and the odd UNO. From what I can see, the MYSbootloader.hex file is for the Mega328p, is this correct, or can the same bootloader be adjusted (fuse settings etc) for others like the Leonardo processor?
                Q2 - One post I read seemed to imply that to use the remote reboot feature you needed 'either' the MYSBootloader OR OptiBoot. In the OptiBoot readme, it doesn't mention reboot as a feature, so I am wondering if it really does support reboot - can anyone please confirm?
                Many thanks,
                Paul
                  Q1) Yes, correct.
                  Q2) The reboot is handled automatically when new firmware has been downloaded by the library. Note: When using DualOptiboot you must also enable the MY_OTA_FIRMWARE_FEATURE when compiling the sketch to allow updates.
                    studzin
                    Is it possible to add support for rs485 network? In my opinion bootloader which exists need only de-pin management. I'm using hardware serial (rx tx) in nod's.
                      slt1
                      Can someone please tell me how long it is supposed to take to upload a hex file with MYSBootloader. I am trying out OTA Updates with the latest dev branch of MYSBootloader and it takes almost 2 hours to upload a 64k hex file. Is this normal or should it be a lot quicker?
                        How far is the node from gateway? It should take much less time actually
                        S 1 Reply Last reply
                          slt1
                          @gohan I have tried 2 different nodes in 2 different locations. The one node is about 8m away from the gateway. The other node is around 12m away.
                            Ok, if you put it like 2 meters away do you notice any difference?
                              slt1
                              @gohan Seems to be taking the same time at 2 meters apart. Can you tell me how long it should take to do an OTA update? You say "much less time" .. what should it take for a 64k update?
                                I don't have direct experience (I am waiting for my mini pro to be delivered) but I read other sending in around 10 minutes but I don't know what was the hex file size.
                                I asked for the distance just to make sure it wasn't related to range issues.
                                  slt1
                                  I am getting good range here. I have a repeater node (not using MYSBootloader yet) that is 100m away and works fine and another node 200 to 300m away (hence the repeater at 100m). The far node was dropping some messages but that is not too critical as its only a water tank level sensor. I plan to put in a long range PA+SMA type nrf24L01 on that one. The gateway and repeater already have the long range nrf's. I am now testing OTA to a weather station node that is just outside - around 10m from gateway. And I have a test node on my desk around 8m from the gateway. Both the weather station and the test node on my desk give same results for OTA - around 30min or so for every 20k of hex file.
                                    how long is the sleep time of your nodes?
                                      slt1
                                      @gohan The weather station does not sleep - it uses wait() and does so for 5 seconds every loop. The test node first waits for 5 seconds then sleeps for 55 seconds. Both these node seem to update at the same rate. However, it also seems MYSBootloader does the firmware update then launches the sketch code, so the wait / sleep cycle is irrelevant as it first updates the bootloader then runs the sketch
                                        it is relevant because if it is long, the node will start the ota update only when it exits the sleep, so I was just making sure you didn't overlooked that :)
                                          slt1
                                          @gohan not overlooked :) All seems to be working - range is good, MYSBootloader and OTA updates work. It just incredibly slow. It seems to do some message updates then pause for maybe 5 seconds or so, then carry on going. So when there are 1000 messages - these 5 sec pauses probably add up to what is making it take hours instead of minutes
                                          J 1 Reply Last reply
