  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.7k Views 42 Watching
  • J
    J
    jkandasa
    @tekka, I tested this bootloader and facing an issue.
    https://github.com/mysensors/MySensorsBootloaderRF24/issues/7
    • AndurilA
      AndurilA
      Anduril
      How do I do a remote reboot of a node? Node is not responding to MYSController command (I think due to changed things as with reassigning node-ID). DO I have to write a receive event or enable it somehow? Node is sleeping most time, maybe that's a problem.
        Samuel235
        #59
        I'm very interested in testing your development for the latest MYSBootloader as the bootloader for OTA updates on my new hardware designs that i'm starting to design, but i would like a stable one first to make sure my system and setup are working fine with the stable. Is the stable bootloader the one in the master branch of https://github.com/mysensors/MySensorsBootloaderRF24/tree/master. The MYSBootloader.hex file or does this still need to be compiled for use?
        Or do you happen to have a download link for the stable version, should we be using the one that you bundle together with MYSController?
        Also, @tekka - Do you advise a stable one that works for MyController.org please?
        MySensors 2.1.1
        • Nicolas CharrierN
          Nicolas CharrierN
          Nicolas Charrier
          With this bootloader, i can not upload scetch with serial or USB.
          Where does i made a mistake?
          Is there a configuration that is specific to the bootloader?
          tekkaT 1 Reply Last reply
          • Nicolas CharrierN Nicolas Charrier
            tekkaT
            tekkaT
            tekka
            @Nicolas-Charrier Welcome to MySensors. Please do not post the same question in different threads. Maybe you can give additional information that help to understand what you tried so far (logs, screenshots, HW configuration, CPU frequency, etc.). Did you follow the OTA/bootloader instructions here?
            Nicolas CharrierN AffordableTechA 2 Replies Last reply
            • tekkaT tekka
              Nicolas CharrierN
              Nicolas CharrierN
              Nicolas Charrier
              @tekka
              I can now program my board with serial line. It's work perfectly.
              It's an issue with my serial converteur and an usb hub. The usb hub add a delay that is not compatible with the bootloader.
              Sorry for the question.
              Nico
                @tekka
                Nico
                tekkaT
                tekkaT
                tekka
                @Nicolas-Charrier Good to know, thanks for your feedback :)
                • kk02067K
                  kk02067K
                  kk02067
                  Excuse me for beeing an idiot. But how do you compile the bootloader from source? Do you do it from Atmel studio or from Arduino IDE. And how is it done? When I compile it in Atmel studio it gets an base adress of 0x0000 which is wrong.
                  I am used to program in assembler in Atmel studio and when I program in C i don't touch anyting else than the .c file. So some form of tutorial kind of thing would be helpful.
                  Thank you
                  • R
                    R
                    rvweert
                    Hey all,
                    I've compiled the bootloader and was able to install it with Arduino as ISP to a Nano. I couldn't find the lines necessary for the Nano in boards.txt so I created this:
                    nanomysbootloader.name=Arduino Nano MYSBootloader
                    nanomysbootloader.upload.tool=avrdude
                    nanomysbootloader.upload.protocol=arduino
                    nanomysbootloader.bootloader.tool=avrdude
                    nanomysbootloader.bootloader.unlock_bits=0x3F
                    nanomysbootloader.bootloader.lock_bits=0x0F
                    nanomysbootloader.build.f_cpu=16000000L
                    nanomysbootloader.build.board=AVR_NANO
                    nanomysbootloader.build.core=arduino
                    nanomysbootloader.build.variant=eightanaloginputs
                    ## Arduino Nano w/ ATmega328
                    nanomysbootloader.menu.cpu.atmega328=ATmega328
                    nanomysbootloader.menu.cpu.atmega328.upload.maximum_size=30720
                    nanomysbootloader.menu.cpu.atmega328.upload.maximum_data_size=2048
                    nanomysbootloader.menu.cpu.atmega328.upload.speed=115200
                    nanomysbootloader.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                    nanomysbootloader.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                    nanomysbootloader.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                    nanomysbootloader.menu.cpu.atmega328.bootloader.file=MySensors/MYSBootloader.hex
                    nanomysbootloader.menu.cpu.atmega328.build.mcu=atmega328p
                    Is this correct? Besides, on some devices I cannot program over serial anymore now, only through another ISP. Could that be caused by incorrect settings? Is it possible to recover from that?
                    The error I'm getting is this one:
                    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
                    Thanks and happy easter!
                    Rene
                    • tekkaT tekka
                      AffordableTechA
                      AffordableTechA
                      AffordableTech
                      Hi All,
                      I'm currently upgrading to MySensors 2.0.0 and it would make sense to change over to the MYSBootloader as I upgrade each node. (I'd like to be able to use the remote re-boot command from MYSController).
                      I have been reading about the MYSBootloader and have some questions . . .
                      Q1 - My nodes are a mixture of Pro-Micro's, Leonardo's, Mega 2560's and the odd UNO. From what I can see, the MYSbootloader.hex file is for the Mega328p, is this correct, or can the same bootloader be adjusted (fuse settings etc) for others like the Leonardo processor?
                      Q2 - One post I read seemed to imply that to use the remote reboot feature you needed 'either' the MYSBootloader OR OptiBoot. In the OptiBoot readme, it doesn't mention reboot as a feature, so I am wondering if it really does support reboot - can anyone please confirm?
                      Many thanks,
                      Paul
                        Q1) Yes, correct.
                        Q2) The reboot is handled automatically when new firmware has been downloaded by the library. Note: When using DualOptiboot you must also enable the MY_OTA_FIRMWARE_FEATURE when compiling the sketch to allow updates.
                          studzin
                          Is it possible to add support for rs485 network? In my opinion bootloader which exists need only de-pin management. I'm using hardware serial (rx tx) in nod's.
                            slt1
                            Can someone please tell me how long it is supposed to take to upload a hex file with MYSBootloader. I am trying out OTA Updates with the latest dev branch of MYSBootloader and it takes almost 2 hours to upload a 64k hex file. Is this normal or should it be a lot quicker?
                              How far is the node from gateway? It should take much less time actually
                              S 1 Reply Last reply
                                slt1
                                @gohan I have tried 2 different nodes in 2 different locations. The one node is about 8m away from the gateway. The other node is around 12m away.
                                  Ok, if you put it like 2 meters away do you notice any difference?
                                    slt1
                                    @gohan Seems to be taking the same time at 2 meters apart. Can you tell me how long it should take to do an OTA update? You say "much less time" .. what should it take for a 64k update?
                                      I don't have direct experience (I am waiting for my mini pro to be delivered) but I read other sending in around 10 minutes but I don't know what was the hex file size.
                                      I asked for the distance just to make sure it wasn't related to range issues.
                                        slt1
                                        I am getting good range here. I have a repeater node (not using MYSBootloader yet) that is 100m away and works fine and another node 200 to 300m away (hence the repeater at 100m). The far node was dropping some messages but that is not too critical as its only a water tank level sensor. I plan to put in a long range PA+SMA type nrf24L01 on that one. The gateway and repeater already have the long range nrf's. I am now testing OTA to a weather station node that is just outside - around 10m from gateway. And I have a test node on my desk around 8m from the gateway. Both the weather station and the test node on my desk give same results for OTA - around 30min or so for every 20k of hex file.
                                          how long is the sleep time of your nodes?
