  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
  • A andreground
    @tekka thanks, it works.
    2 more questions:
    1. Should the clearing eeprom function in MYSBootloader be working?
    2. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
    tekkaT
    tekkaT
    tekka
    @andreground said in MYSBootloader 1.3.0-beta.3:
    2 more questions:
    No, this has also been moved to the MySensors framework:
    Add:
    If MY_DEBUG is disabled, you can add
    #define MY_SPECIAL_DEBUG
    and then send a C_INTERNAL / I_DEBUG / E to the node. For the sake of completeness, here are the special debug commands:
    E: Clear EEPROM (node replies with OK and reboots)
    V: Report CPU voltage in mV (if supported)
    F: Report frequency in cHz
    M: Report free memory
    R: Report routing table (if node is a repeater/gateway)
    1. From what I understand, Watchdog is enabled by default (8S timeout) in the bootloader; that means that I've to either call wdt_reset in my loop or call wdt_disable in setup to prevent unexpected reboots. Am i right?
    wdt_reset() is called within the framework, so no need to call it unless you have blocking code of >8s. Alternatively, you can also disable it (AVR: if the wdton fuse is cleared).
    • A andreground
      2 more questions:
      Mark SwiftM
      Mark SwiftM
      Mark Swift
      @tekka
      I've never used the clear EEPROM feature but would like to.
      I've added:
      To my sketches. Using the latest MYSController, will the menu option 'Clear EEPROM' still do the trick, or does the application need some updates?
      • J
        J
        jacikaas
        Is there going to be 1 and 8MHz MySBootloader hex files? :)
        • J
          J
          jkandasa
          @tekka, I tested this bootloader and facing an issue.
          https://github.com/mysensors/MySensorsBootloaderRF24/issues/7
          • AndurilA
            AndurilA
            Anduril
            How do I do a remote reboot of a node? Node is not responding to MYSController command (I think due to changed things as with reassigning node-ID). DO I have to write a receive event or enable it somehow? Node is sleeping most time, maybe that's a problem.
              Samuel235
              #59
              I'm very interested in testing your development for the latest MYSBootloader as the bootloader for OTA updates on my new hardware designs that i'm starting to design, but i would like a stable one first to make sure my system and setup are working fine with the stable. Is the stable bootloader the one in the master branch of https://github.com/mysensors/MySensorsBootloaderRF24/tree/master. The MYSBootloader.hex file or does this still need to be compiled for use?
              Or do you happen to have a download link for the stable version, should we be using the one that you bundle together with MYSController?
              Also, @tekka - Do you advise a stable one that works for MyController.org please?
              MySensors 2.1.1
              • Nicolas CharrierN
                Nicolas CharrierN
                Nicolas Charrier
                With this bootloader, i can not upload scetch with serial or USB.
                Where does i made a mistake?
                Is there a configuration that is specific to the bootloader?
                tekkaT 1 Reply Last reply
                • Nicolas CharrierN Nicolas Charrier
                  tekkaT
                  tekkaT
                  tekka
                  @Nicolas-Charrier Welcome to MySensors. Please do not post the same question in different threads. Maybe you can give additional information that help to understand what you tried so far (logs, screenshots, HW configuration, CPU frequency, etc.). Did you follow the OTA/bootloader instructions here?
                  Nicolas CharrierN AffordableTechA 2 Replies Last reply
                  • tekkaT tekka
                    Nicolas CharrierN
                    Nicolas CharrierN
                    Nicolas Charrier
                    @tekka
                    I can now program my board with serial line. It's work perfectly.
                    It's an issue with my serial converteur and an usb hub. The usb hub add a delay that is not compatible with the bootloader.
                    Sorry for the question.
                    Nico
                      @tekka
                      Nico
                      tekkaT
                      tekkaT
                      tekka
                      @Nicolas-Charrier Good to know, thanks for your feedback :)
                      • kk02067K
                        kk02067K
                        kk02067
                        Excuse me for beeing an idiot. But how do you compile the bootloader from source? Do you do it from Atmel studio or from Arduino IDE. And how is it done? When I compile it in Atmel studio it gets an base adress of 0x0000 which is wrong.
                        I am used to program in assembler in Atmel studio and when I program in C i don't touch anyting else than the .c file. So some form of tutorial kind of thing would be helpful.
                        Thank you
                        • R
                          R
                          rvweert
                          Hey all,
                          I've compiled the bootloader and was able to install it with Arduino as ISP to a Nano. I couldn't find the lines necessary for the Nano in boards.txt so I created this:
                          nanomysbootloader.name=Arduino Nano MYSBootloader
                          nanomysbootloader.upload.tool=avrdude
                          nanomysbootloader.upload.protocol=arduino
                          nanomysbootloader.bootloader.tool=avrdude
                          nanomysbootloader.bootloader.unlock_bits=0x3F
                          nanomysbootloader.bootloader.lock_bits=0x0F
                          nanomysbootloader.build.f_cpu=16000000L
                          nanomysbootloader.build.board=AVR_NANO
                          nanomysbootloader.build.core=arduino
                          nanomysbootloader.build.variant=eightanaloginputs
                          ## Arduino Nano w/ ATmega328
                          nanomysbootloader.menu.cpu.atmega328=ATmega328
                          nanomysbootloader.menu.cpu.atmega328.upload.maximum_size=30720
                          nanomysbootloader.menu.cpu.atmega328.upload.maximum_data_size=2048
                          nanomysbootloader.menu.cpu.atmega328.upload.speed=115200
                          nanomysbootloader.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                          nanomysbootloader.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                          nanomysbootloader.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
                          nanomysbootloader.menu.cpu.atmega328.bootloader.file=MySensors/MYSBootloader.hex
                          nanomysbootloader.menu.cpu.atmega328.build.mcu=atmega328p
                          Is this correct? Besides, on some devices I cannot program over serial anymore now, only through another ISP. Could that be caused by incorrect settings? Is it possible to recover from that?
                          The error I'm getting is this one:
                          avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
                          Thanks and happy easter!
                          Rene
                          • tekkaT tekka
                            AffordableTechA
                            AffordableTechA
                            AffordableTech
                            Hi All,
                            I'm currently upgrading to MySensors 2.0.0 and it would make sense to change over to the MYSBootloader as I upgrade each node. (I'd like to be able to use the remote re-boot command from MYSController).
                            I have been reading about the MYSBootloader and have some questions . . .
                            Q1 - My nodes are a mixture of Pro-Micro's, Leonardo's, Mega 2560's and the odd UNO. From what I can see, the MYSbootloader.hex file is for the Mega328p, is this correct, or can the same bootloader be adjusted (fuse settings etc) for others like the Leonardo processor?
                            Q2 - One post I read seemed to imply that to use the remote reboot feature you needed 'either' the MYSBootloader OR OptiBoot. In the OptiBoot readme, it doesn't mention reboot as a feature, so I am wondering if it really does support reboot - can anyone please confirm?
                            Many thanks,
                            Paul
                              Q1) Yes, correct.
                              Q2) The reboot is handled automatically when new firmware has been downloaded by the library. Note: When using DualOptiboot you must also enable the MY_OTA_FIRMWARE_FEATURE when compiling the sketch to allow updates.
                                studzin
                                Is it possible to add support for rs485 network? In my opinion bootloader which exists need only de-pin management. I'm using hardware serial (rx tx) in nod's.
                                  slt1
                                  Can someone please tell me how long it is supposed to take to upload a hex file with MYSBootloader. I am trying out OTA Updates with the latest dev branch of MYSBootloader and it takes almost 2 hours to upload a 64k hex file. Is this normal or should it be a lot quicker?
                                    How far is the node from gateway? It should take much less time actually
                                    S 1 Reply Last reply
                                      slt1
                                      @gohan I have tried 2 different nodes in 2 different locations. The one node is about 8m away from the gateway. The other node is around 12m away.
                                        Ok, if you put it like 2 meters away do you notice any difference?
                                          slt1
                                          @gohan Seems to be taking the same time at 2 meters apart. Can you tell me how long it should take to do an OTA update? You say "much less time" .. what should it take for a 64k update?
