  3. 💬 MDMSNode "Power"
💬 MDMSNode "Power"
arduinoatsha204ahlk-pm01mysensorsdc-dcnrf24l01atmega328prelayrfm69acs711
33 Posts 7 Posters 11.1k Views 5 Watching
    Samuel235
    Awesome, might be beneficial to add to the openhardware description too.
    MySensors 2.1.1
    kalinaK 1 Reply Last reply
    • S Samuel235
      kalinaK
      kalinaK
      kalina
      @Samuel235 I agree, it will be done.
      S 1 Reply Last reply
      • kalinaK kalina
        Samuel235
        @kalina - Perfect, I notice you have published design files for the rest of your designs but not this. Can't help but wonder why....
        MySensors 2.1.1
        • S Samuel235
          kalinaK
          kalinaK
          kalina
          @Samuel235 Because I have already found mistake with ACS711 connection... i will upload source files later, don't worry :)
          • kalinaK kalina
            Samuel235
            @kalina I Look forward to seeing the files ;)
            Do you design your boards to a certain sizing to fit in certain containers/enclosures or do you just size your boards according to the contained hardware?
            I've recently noticed that there isn't much price difference from say a 50 x 50mm to a 100 x 100mm board. When i started to get boards made, there were 50 x 50mm prototyping board packages that were much cheaper than the 100mm counterparts. This opens up a much more interesting scope for products made here now.
            MySensors 2.1.1
            • S Samuel235
              kalinaK
              kalinaK
              kalina
              @Samuel235 Firstly I choose the type of device that I want to design, then I look for suitable enclosure. Further work involves the placement of everything in the enclosure. In addition to that, I always use 3D modeling for appreciating the ability to do the task.
              • kalinaK kalina
                Samuel235
                @kalina - It's always nice to see how other people work :) Thank you for sharing your methods.
                MySensors 2.1.1
                • kalinaK
                  kalinaK
                  kalina
                  I have received pcbs and i am waiting for components now for device testing.
                  PCBWAY.com sent me pcbs in less than 2 weeks, as always super quality, thanks to them!
                  • kalinaK kalina
                    Samuel235
                    @kalina - I can't recommend PCBWay.com enough to people considering their price point, they're pretty high quality. Hope to see the tests completed without issue for you :)
                    MySensors 2.1.1
                    • S Samuel235
                      kalinaK
                      kalinaK
                      kalina
                      @Samuel235 said in 💬 MDMSNode "Power":
                      Thanks! But for the first release it sounds extremely optimistic :bowtie:
                      • kalinaK kalina
                        Samuel235
                        @kalina - We can be positive ;)
                        MySensors 2.1.1
                        • kalinaK
                          kalinaK
                          kalina
                          Luckily, the device has started up without problems. Yesterday I tested it, even the kettle worked through the device (9A). Now I can share the source files of the project (already are refreshed).
                          3_1495287454163_MDMSNode_Power_11.jpg 2_1495287454163_MDMSNode_Power_10.jpg 1_1495287454163_MDMSNode_Power_9.jpg 0_1495287454163_MDMSNode_Power_8.jpg
                          S sundberg84S 2 Replies Last reply
                          • kalinaK kalina
                            Samuel235
                            @kalina - I knew you could do it o.O
                            MySensors 2.1.1
                            • kalinaK kalina
                              sundberg84S
                              sundberg84S
                              @kalina what is the purpose of the vias on the AC traces? Thermal relief from the components on the other side?
                              • sundberg84S sundberg84
                                kalinaK
                                kalinaK
                                kalina
                                @sundberg84, vias connect the AC traces on the TOP and BOT layers (see picture). This was done for reduce resistance of the conductors and distribute the heat caused by the flow of large currents through them.
                                • J
                                  J
                                  JWB
                                  Kalina,
                                  What CAD program are you using for this project? The board file does not seem to be Eagle or KiCad.
                                  • J JWB
                                    Kalina,
                                    kalinaK
                                    kalinaK
                                    kalina
                                    @JWB said in 💬 MDMSNode "Power":
                                    I use Altium Designer.
                                    • L
                                      L
                                      lagrosso69
                                      hello have you a sample program to try MDMSNode power
                                      thank you
                                      • L lagrosso69
                                        thank you
                                        kalinaK
                                        kalinaK
                                        kalina
                                        #22
                                        @lagrosso69 said in 💬 MDMSNode "Power":
                                        Hi @lagrosso69. Do you mean a sketch? Did you order pcb and solder MDMSNode "Power" by yourself?
                                        L 1 Reply Last reply
                                        • kalinaK kalina
                                          L
                                          L
                                          lagrosso69
                                          @kalina no i bought your mdmsnode by ebay and i would love to try it here
