  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 256.4k Views 53 Watching
    No, I haven't heard of any near plans in the core team about doing multi radio/sub-network support in 2.0.
    This requires some extra thoughts and would probably only fit on SAMD/ESP nodes.
    alexsh1A
    alexsh1A
    alexsh1
    @hek Which is good as the Sensebender GW is based on SAMD! So it is ready to be the first 2-in-1 GW.
    Anyway, keep on doing a great work! I'll patiently wait until the combined GW is there.
    • NiklasON
      NiklasON
      NiklasO
      wrote on last edited by NiklasO
      #217
      Ordered from ITEAD. Nice to get rid of this stuff:
      Just nudging anything result in problems. ;-)
      Time to fire up the 3D-printer.
      • NiklasON
        NiklasON
        NiklasO
        #218
        Aaaand, it's up! Very good fit (the box).
        The box on top is just me trying out different colors of the case. ;)
        The one on top has better look. Different brands of PLA.
        • nick van alstN
          nick van alstN
          nick van alst
          @NiklasO that looks very good!
          Are you willing to share your design files with us?
          i just ordered my gateway to get rid of cables and lose components :D a case would really make it complete!
            @NiklasO
            great :+1:
            @nick-van-alst
            you can get enclosure design files here https://www.mysensors.org/hardware/sensebender-gateway (on page bottom)
            I designed different variants so pick which one you need.
            • M meddie
              Ok i just connected the W5100 and NRF24 Module and uploaded the GatewayW5100 Sketch and when the upload is done after reset i dont get any output on serial monitor.
              The orange, green and red led are lighting.
              When i upload the SensebenderGatewaySerial then i get output on serial monitor. It think the problem must be the w5100. But what going wrong?
              alexsh1A
              alexsh1A
              alexsh1
              @meddie said in 💬 Sensebender Gateway:
              @meddie Did you figure out what the problem is? I have exactly the same issue
              M tbowmoT 2 Replies Last reply
              • alexsh1A alexsh1
                meddie
                @alexsh1
                hi, yes it was very simple :-D the gateway has worked fine in this time, i thought that when nothing shown in serial monitor that the gateway dont work, but it did it, after i connected the gateway to FHEM (my controller) i saw that FHEM connects t mys Gateway.
                So it worked all the time
                Greets Eddie
                • alexsh1A alexsh1
                  tbowmoT
                  tbowmoT
                  tbowmo
                  @alexsh1
                  Have you tried to enable the debug output in the GatewayW5100 example? I think it is disabled by default, due to the limited memory on the small atmega 328p
                  alexsh1A 1 Reply Last reply
                  • tbowmoT tbowmo
                    @alexsh1
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @tbowmo
                    Yes, I did
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      #225
                      I am running Arduino IDE 1.8.1 on Windows 10
                      Arduino AVR 1.6.18
                      Arduino SAMD 1.6.12
                      MySensors SAMD 1.0.5
                      EDIT: I have tried to upload the default sketch on macbook with Arduino IDE 1.6.2
                      It is still the same - no debug info in the terminal
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        #226
                        OK, I did manage to get debug working partially.
                        The gateway reads messages, but does not work as the gateway
                        0;255;3;0;9;MCO:BGN:STP
                        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=17,pt=5,l=4,sg=0:348
                        0;255;3;0;9;TSF:MSG:READ,26-10-0,s=3,c=1,t=24,pt=5,l=4,sg=0:51219479
                        0;255;3;0;9;TSF:MSG:READ,10-10-0,s=1,c=1,t=24,pt=5,l=4,sg=0:51219482
                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=2,c=1,t=37,pt=7,l=5,sg=0:1717.62
                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=0,c=1,t=37,pt=7,l=5,sg=0:5338.44
                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.75
                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=3,c=1,t=37,pt=7,l=5,sg=0:10.76
                        0;255;3;0;9;TSF:MSG:READ,11-11-0,s=4,c=1,t=37,pt=4,l=4,sg=0:880
                        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=2,c=1,t=1,pt=7,l=5,sg=0:64.8
                        0;255;3;0;9;TSF:MSG:READ,6-6-0,s=0,c=1,t=4,pt=7,l=5,sg=0:1015
                        I never had a message:
                        Gateway startup complete.
                        EDIT: Self-test with SensebenderSerial sketch gives me this:
                        Sensebender GateWay test routine
                        Mysensors core version : 2.1.1
                        GateWay sketch version : 0.2
                        - > SHA204 Failed to wakeup SHA204
                        - > SD CARD SD CARD did not initialize!
                         -> EEPROM PASSED
                        -> analog : 38 Failed
                        tbowmoT 1 Reply Last reply
                        • alexsh1A alexsh1
                           -> EEPROM PASSED
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @alexsh1
                          Could you check the soldering of the samd?
                          SD card fails, if you haven't inserted a card, when running the self test.
                          • tbowmoT tbowmo
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #228
                            @tbowmo
                            I do not have the SD card so that's fine
                            The samd looks fine - no bridges etc
                            I can try to re-solder it with a hot fan
                            Do you think samd may be at fault even though the serial GW is working?
                            Unfortunately, I do not have another Ethernet w5100 to try it. Probably have to order a new one
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @alexsh1
                              I know that @Anticimex had problems with one of the pre-production samples that we got from China, with various problems, that was solved with "reflowing" the samd with a hot air gun.. So it was just a thought, that it could be a bad solder joint..
                              The W5100 is using it's own dedicated SPI port, so even though that the radio works, doesn't mean that there couldn't be any solder problems around the samd pins for W5100.
                              We have 3 different SPI ports in use on the gateway, one for the MysX connector, one for radio / sdcard, and one for W5100..
                              • tbowmoT tbowmo
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo I do not have the oven to reflow the whole board, but can mount / unmount or re-work certain components 0805 or 0603. Below this it is a pain in the a***
                                Another observation - The GW behaves like this with or without W5100 mounted.
                                Seems like an SPI problem to me. How can I wire W5100 to MYSX please and what shall I can in the sketch please? Thank for your help - very much appreciate it
                                AnticimexA 1 Reply Last reply
                                • alexsh1A alexsh1
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alexsh1 The ATSHA is not connected to the SPI and is totally unrelated, so I am also inclined to suspect that perhaps one side of the SAMD is not entirely in contact with the pads. I had to hot-airgun mine to get USB working well but it was an early prototype like @tbowmo said.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @tbowmo OK, I manage to find the answer here -
                                    MYSX
                                    D11 - MOSI
                                    D12 - MISO
                                    D13 - SCK
                                    D14 -CS
                                    #define MY_SOFTSPI
                                    #define MY_SOFT_SPI_SCK_PIN 13
                                    #define MY_SOFT_SPI_MISO_PIN 12
                                    #define MY_SOFT_SPI_MOSI_PIN 11
                                    MY_RF24_CS_PIN 14
                                    RF24_CE_PIN ???
                                    Am I correct?
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      My current config for nrf24l01+ and w5100 is as follows:
                                      #define MY_GATEWAY_W5100
                                      #define MY_SOFTSPI
                                      #define MY_RF24_CE_PIN 5
                                      #define MY_RF24_CS_PIN 6
                                      Why CE / CS pins are 5 and 6?
                                      Should that be 27 and 3?
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #234
                                        @tbowmo I have just re-worked SAMD and all the connectors (nrf24l01+ and NET_SPI), but still have the same issue sadly.
                                        EDIT: If I change to rfm69, the same behavior is observed. It seems that Net_SPI is just not working.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          #235
                                          @alexsh1
                                          Configuration of the pins are handled by the hardware configuration file, https://github.com/mysensors/ArduinoHwSAMD/blob/master/variants/mysensors_gw/variant.h#L227
                                          If you look in the gatewayW5100 sketch, the settings for CE / CS pins are enclosed in ifdefs, so they are only used if they are not defined previously.
                                          If you want to connect the W5100 to the mysx connector, you can change line 174 in the hardware definition file, use SPI2 instead of SPI1 for SPI_ETH
                                          It could also be a defective W5100 shield? Can you verify that it works on other hardware?
