  3. 💬 MyMultisensors
💬 MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 95.0k Views 35 Watching
  • scalzS scalz
    @tonnerre33 sorry for delay. yep, sure i finished it a while (rev 1.1 nrf), never ordered it, i use rfm for this node. but i'll upload this week oki
    tonnerre33T
    tonnerre33T
    tonnerre33
    @scalz Thx a lot ! I tried to replace the transmitter myself but the routing is too hard for me.
    I'll try to check the schema before order the board ;)
    • B
      B
      Bigbug
      This looks like an awesome unit! Is there a way to buy this with components assembled? Looks like a lot of work to solder all those smds..
      • P
        P
        pointbre
        I also wish I could buy assembled ones.
        tomtasticT 1 Reply Last reply
        • P pointbre
          tomtasticT
          tomtasticT
          tomtastic
          Likewise, to be able to buy assembled would be great
          • alexsh1A
            alexsh1A
            alexsh1
            @scalz hi, excellent sensor! Do you know if the atmega328 memory is enough? You must have a large sketch for all sensors + signin
              #82
              @alexsh1 thx :)
              memory ok if sketch optimized (radio driver footprint too) and without much debug msg.
              V2 will improve memory, cost and device size (will be 9in1 this time so i needed more mem) but for nrf24 networks only. i should release it soon if i can get rid of a little sw bug..
              bjornhallbergB alexsh1A 2 Replies Last reply
              • mppM
                mppM
                mpp
                How long can you get these running on a single battery?
                MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
                alexsh1A 1 Reply Last reply
                • scalzS scalz
                  @alexsh1 thx :)
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @scalz Would also be very interested in buying assembled modules. But why no more RFM69?
                  • mppM mpp
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @mpp I suppose depends on which battery and what sensors - there are a few options here.
                    • scalzS scalz
                      @alexsh1 thx :)
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @scalz atmega328 is only good for simple sketches nowadays. I am struggling with a simple temp/hum/baro sensor with signing and debug as It runs on low memory and the sensor freezes after a few hours. I suppose we have to move to SAMD.
                      Do you have the STL file for the box please?
                      AnticimexA 1 Reply Last reply
                      • alexsh1A alexsh1
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @alexsh1 regarding low memory problems, debug is intended for just that; debug. Once deployed, you can disable debug to ensure the longevity of your program. Probably the sketch eventually dies due to stack shortage.
                        • AnticimexA Anticimex
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Anticimex Completely agree. Having said that I have a few nodes where I left debug purely for convenience. I do not want to re-flash the node to debug it in case need be. Right now I am in the process of changing the GW and may need to see node's debug.
                            #89
                            @alexsh1
                            I agree with you about 328 and 8bits. And that's a while i've done a board for these ;)
                            I won't use it in v2 though, tiny 9in1... not possible!
                            I also have custom SAMD boards, missing time to release those one too, but imho these mcu are not ultra low power (SAML is).
                            I'll publish stl this week..
                            • scalzS scalz
                              @alexsh1
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @scalz ATSAM D21 is already compatible with MySensors, whereas ATSAM L21 may be in the pipeline. So for now, we all are stuck with SAMD.
                              Looking forward to your stl
                              • K
                                K
                                Konrad Walsh
                                Phenomenal!
                                I have a stupid question.. clicking buy on the page.. what exactly does that buy you>?
                                • K Konrad Walsh
                                  Phenomenal!
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Konrad-Walsh You buy PCBs (10 0r 15 of them).
                                  • K
                                    K
                                    Konrad Walsh
                                    I am sorry.. I should have been more clear...
                                    When you say PCB.. Is that a fully assembled product with all the mentioned sensors? Or is it a board and you add sensors to it..
                                    Please excuse my ignorance
                                    • K Konrad Walsh
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Konrad-Walsh Click on the link and see it yourself ;-)
                                      PCB means a bare board and not a ready product. You have to procure parts and assemble it.
                                      K 1 Reply Last reply
                                      • alexsh1A alexsh1
                                        K
                                        K
                                        Konrad Walsh
                                        @alexsh1 Thank you
                                        • K Konrad Walsh
                                          @alexsh1 Thank you
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Konrad-Walsh said in 💬 MyMultisensors:
                                          you
                                          No problem.
                                          @scalz There is a lot of interest from others to have an assembled sensor. Maybe as a suggestion, you would be interested talking to Itead or similar guys to get it arranged?
                                          Personally, I am comfortable assembling an SMD board down to 0605 (though it is more difficult with the fan). My preference would be 0805 and up
