  3. Powering mote 24/7 using only a supercap and solar
239 Posts 10 Posters 134.7k Views 14 Watching
    https://www.aliexpress.com/item/2Pcs-Ultra-Capacitor-5-5v4f-Super-Capacitor-H-Style-for-Promotion-Now-Lowest-Price/32772347560.html
    E 1 Reply Last reply
    • E Ed1500
      @Nca78 Wow. I guess you are a loyal Aliexpress customer :-)
      You are right @Ed1500, I receive so many shipments from AliExpress that now the postman is fed up with puting non-delivery notices in my mailbox, now he leaves the packages at the management office of my building, where they advance the tax for me when needed :)
      @NeverDie yes I have some local shops, with very cheap delivery options, less than 1$ a;nd delivered the next day when they have stock. But unfortunately the inventory is pretty limited, I use them when the price difference is not worth the wait from AliExpress.
        E
        E
        Ed1500
        @gohan yes, saw those. please keep us informed abt yr experience with those
          @Ed1500 said in Powering mote 24/7 using only a supercap and solar:
          @NeverDie Actually I had expected that for DigiKey Europe as well... but it says 'all shipping from USA'
          Well, Europe has a Mouser.com presence, I think. Plus, surely there's other stuff there, like in Germany or the UK or something.
          E
          E
          Ed1500
          @NeverDie Oh dont worry, plenty of local online shops here for electronic components plus distributors for adafruit and similar.
          However, I can order in china and have it delivered to my door often for less money than just the gas would cost me to drive to a local store, or to have it delivered from a local webstore.
          The only thing is that sometimes I have to wait 2-3-4 weeks
            These look quite inexpensive:
            https://www.aliexpress.com/item/30-x-ultra-capacitor-2-7v3f/32570929215.html?spm=2114.10010108.1000023.15.qq5cZ7
              E
              E
              Ed1500
              wrote on last edited by Ed1500
              #196
              @NeverDie indeed. but 2.7 Volt is a just a bit of a difficult value to work with and putting them in series makes the capacity drop, but I think one could run the attiny 13-25-45-85 from 1.8V so that might be a good combo
              • E Ed1500
                #197
                @Ed1500
                Or, maybe this then:
                https://www.aliexpress.com/item/Universal-Capacitors-Ultracapacitors-2-7V10F-super-capacitor-10F-2-7V-low-ESR-fast-charging-small-power/32688216790.html?spm=2114.10010108.1000013.4.G3WV1v&traffic_analysisId=recommend_2088_2_81019_new2&scm=1007.13339.81019.0&pvid=1ecf1af6-9158-4f9f-99ff-acaa16690ce2&tpp=1
                It's just a wild card as to whether they actually perform according to the advertised specs, though. That's why I think it's helpful if we all share what we're actually using, and whether it meets expectations or not.
                • E Ed1500
                  Yeah, and the RFM69--which is what I use--runs as low as 1.8v as well, so it's possibly a good match.
                    @Ed1500
                    E
                    E
                    Ed1500
                    @NeverDie 10F now we are talking. But yes I very well understood yr request to share experience. I acn only say thet the 1.5 F's i had performed well and with an RC network thrown together, they seemed in the right ballparc... but apparently seller now sells 1F and I cant vouch for those
                    The supercap is still a very viable alternative for smaller devices, so I will probably buy more in future and thus interested in which ones are good or not
                      E
                      E
                      Ed1500
                      @NeverDie ah yes it does, but the RFM is usually connected to a microcontroller :-) So that is limited choice
                      i wonder if 1.8 Volt would seriously affect the range of the RFM69 (running mine from 3.3)
                        Maybe a small booster to 3.3v could be used, since power efficiency shouldn't be a huge deal since the you will have the panel charging most of the time
                        • E Ed1500
                          Interestingly enough, the lower voltage doesn't seem to affect the range.
                          ATmega328p's can run at 1.8v also. In theory it should be set to run at 4mhz, but neither I nor anyone I know of has had problems running at 8Mhz down to 1.8v. If you run with BOD off and internal 8Mhz resonator, it only consumes about 150na while sleeping. That's why I haven't bothered going to ATtiny's. Maybe there are other reasons to do so though?
                            #203
                            So, I just ordered this:
                            https://www.aliexpress.com/item/3PCS-fala-capacitor-2-7v10f-super-capacitor-high-current-Low-ESR-fast-delivery-2-7V10F-ultra/32715563451.html?spm=2114.13010608.0.0.qFbHqn
                            and this:
                            https://www.aliexpress.com/item/CNIKESIN-2PCS-Fala-Capacitor-2-7v10F-Super-Capacitor-High-Current-Low-ESR-Fast-Delivery-2-7V10F/32804681189.html?spm=2114.13010608.0.0.qFbHqn
                            from the same seller that gohan used. It's a risk, but if either of them check out, I may buy more of that brand.
                            I'll make a posting after I receive them to say whether they seem to be good or not. :)
                              #204
                              I recently purchased one of these:
                              https://www.aliexpress.com/item/Mega328-Transistor-Tester-Diode-Triode-Capacitance-ESR-Meter-MOS-PNP-NPN-M328/32685741297.html?spm=2114.01010208.3.92.KtC8xS
                              and, for the price, it seems to do a decent job of measuring capacitance and ESR.
                                E
                                E
                                Ed1500
                                @NeverDie I have used Attiny's mainly for their size. Pricewise, compared to a pro mini clone it is a bit foolish, unless you use the smd versions.
                                I had an attiny+ 433Mhz transmitter built in one of those garden lamps with a moisture sensor at the base where it sticks in the soil. Worked well, Not ideal, but it was nice to play around with
                                  E
                                  E
                                  Ed1500
                                  @NeverDie interesting. May get one too
                                  gohanG 1 Reply Last reply
                                  • E Ed1500
                                    @Ed1500 I got the bigger brother of that one. Look at the workshop discussion. I can't wait to start testing this stuff with all the voltage regulators I got and see how much energy I can actually store in the same 2 caps both in series and parallel
                                    E NeverDieN 2 Replies Last reply
                                      E
                                      E
                                      Ed1500
                                      @gohan keep us updated :-)
                                        @gohan said in Powering mote 24/7 using only a supercap and solar:
                                        Uh, what workshop discussion would that be?
                                          https://forum.mysensors.org/topic/229/your-workshop
