  3. Cutting the voltage regulator
10 Posts 4 Posters 4.9k Views 3 Watching
  • mppM
    mppM
    mpp
    wrote on last edited by mpp
    It's not clear to me how to properly cut the regulator. According to this documentation it should suffice to cut one leg but then I don't see how this could work?
    This is the board I'm using:
    This is the board I'm using.
    Should I completely remove the regulator? Or how will it work if I only cut the lower right leg?
    I tried cutting the wire just before the circle as marked on the image but then I couldn't program the board anymore. Perhaps I cut it in the wrong place or I'm feeding it gnd/vcc wrongly?
    MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
    • mppM mpp
      sundberg84S
      sundberg84S
      @mpp - i find it much harder to cut a leg/trace then desolder everything. I put my soldering iron on one side over all pins and bend gently upp. When they are free from the pads i desolder the other side and it comes off. Same with led/resistor. I never cut, always desolder. I have broken to many trying to cut.
      mppM 1 Reply Last reply
      • sundberg84S sundberg84
        mppM
        mppM
        mpp
        thanks @sundberg84, seems like I broke mine as well. Some questions remain:
        • How can the board keep working when it is completely removed, don't you need to bridge some pads?
        • What pins should I use to program it (There's only one VCC pint but some arduino clones seem indicate several GND pins where some other indicate blk or dtr)
        • What voltage do I supply without the regulator (I assume 3.3)?
        • mppM mpp
          sundberg84S
          sundberg84S
          @mpp
          No, you need to feed a regulated voltage to VCC. The "easy" explanation is that the voltage regulator is only engaged when providing a powersource to RAW.
          On the short side there are the ftdi header you use to program the board with. Check here (swedish but you see the pictures)
          You need to regulate to voltage to a stable 3.3v (or below depending on BOD/fuses) and provide it to VCC.
          • Nca78N
            I agree with @sundberg84 it's much easier to unsolder it than butchering the PCB :)
            Check the video here, not good quality but you will get the point
            https://www.youtube.com/watch?v=7qujkC72dYs
            • Nca78N Nca78
              sundberg84S
              sundberg84S
              @Nca78 - great informative video!
              I remove the regulator to the right (marked 102) since this is connected in series (same result as removing the led) with the led and easier to get to. The led is cramped in between the regulator and the capacitor so might be easier if the setup is the same on your boards...
              Nca78N 1 Reply Last reply
                @sundberg84 yes you are right, and resistors heat up more easily also so it might be a 2 seconds job, I'll do it next time.
                And in any case it would be better to remove regulator first.
                  Great @Nca78, I added the video here:
                  https://www.mysensors.org/build/battery
                    @mpp
                    mppM
                    mppM
                    mpp
                    Thanks for the tips.
                    I don't get this, I never use RAW so there's no advantage in removing the regulator.. ?
                    Isn't it the other way round, that the regulator is only engaged when using VCC?
                    • mppM mpp
                      sundberg84S
                      sundberg84S
                      @mpp - No, the voltage regulator is engaged when providing power to RAW and regulates the voltages down from whatever you input to 5v. Therefore you can remove it when providing a stable power source to VCC. What happens though is that there is a drain/leakage of current even when you provide power to VCC. Therefore its good to remove it.
                      Edit: Therefore... I love my Swedenglish...
