  3. MySensors controller with Rasberry Pi 3 & Windows IoT
15 Posts 6 Posters 5.1k Views 4 Watching
  • scalzS scalz
    I think you should start by taking a look at a Serial UART example for VS, for learning how com port session, communication are handled.
    A very good exercise, could be to start by trying to code a Serial monitor. Then it should be easier to understand.
    See above link from @mfalkvidd for the serial api and use it from your homemade Serial monitor, sending command, reading etc..
    Or as sugested too, you could take a look how Homegenie works (serial communication, threads, database etc.)
    MrVince
    @scalz I will look thanks :)
      Keep in mind that mysensors gw also works over ethernet and mqtt
        MrVince
        Hy everyone ! So, THIS IS WORKING ! Thanks a lot :)
        Now, new problemes ! (It's not funny without)
        I build a serial gateway and a motionsensor
        This is my log
        0_1496323093938_Screenshot_1.jpg image url)
        0;0;3;0;9 -> ok it's a gateway init
        0;0;3;0;14 -> gateway is ready
        but, what is the next one? Normally I will receive just x;x;x;x;x; right? what's about read: 255-255....
        Thank you :)
          take a look at https://www.mysensors.org/build/parser
            MrVince
            Ok, if I right, there is a trouble with a motionsensor who want an ID ?
            Do I need to give it one, or it's done by a gateway?
            • M MrVince
              sundberg84S
              sundberg84S
              @MrVince - It is done by the controller. The GW never assign ID.
              You could set a static ID in the node as well.
              • sundberg84S sundberg84
                MrVince
                @sundberg84 It's work ! Thank you :)
                  MrVince
                  wrote on last edited by MrVince
                  Hi everyone !
                  Let's do a check up :
                  • Read from a GW in serial connection : ok
                  • Read information when I give a static ID : ok
                  • Find a node who want an ID : ok
                  • Give an ID to a node with my controller : nope
                  So, the question is, if I receive '255;255;3;0;3;' my controller understand it's an ID_REQUEST and I need to use an ID_RESPONSE, but if I want to give an ID I need to build something like this :
                  node-id ; child-sensor-id ; command ; ack ; type ; payload
                  node-id : ??
                  child-id : ??
                  command : 3 for internal
                  ack : 0 ?
                  type : 4 for response
                  payload : new ID (ex: 101)
                  What are the node-id & child-id if the sensor doesn't have one?
                  One more time, I want to thank's all of you, with your help it's more easier to understand and I start to see the end !
                  EDIT : One more thing, I have an idea. I want to open a pop-up when a new sensor is on to choose for wich room is it.
                  Can I give an temporary ID (like 254), wait for a first message with ID 254, with a first message I can see what type of sensor is, open a pop up, and give a new ID after I choose the room?
                    the controller should keep track of the assigned IDs and respond with the following free one, I don't think you can change the ID via software, unless there is a way to change it in eeprom and reboot node so it will read it from eeprom and boot with that
                      MrVince
                      @gohan ok
                      I understand for the controller, but I think I miss something about the ID_RESPONSE
                      Imagine this situation:
                      I have just one sensor with no ID
                      The GW send me (the controller) : '255;255;3;0;3;' // Sensor want a node_ID
                      If I want to give it the ID 1, what I need to send to the gw? I think something like '255;255;3;0;4;1', that's right?
                      EDIT : I try and it's work now, but I need to clear EEPROM first
                      • C
                        C
                        carolynlawson
                        Thank you for sharing the details.
