  2. Announcements
  3. 💬 Log Parser
💬 Log Parser
27 Posts 17 Posters 9.8k Views 16 Watching
  • H Offline
    H Offline
    wrote on last edited by hek
    This thread contains comments for the article "Log Parser" posted on MySensors.org.
    • B Offline
      B Offline
      bobbybobbybobby
      • Ivan ZI Offline
        Ivan ZI Offline
        Ivan Z
        I crash parser
        0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
        4 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=15
        15 TSM:FPAR
        51 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2059 !TSM:FPAR:NO REPLY
        2061 TSM:FPAR
        2097 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2610 TSF:MSG:READ,5-5-15,s=255,c=3,t=8,pt=1,l=1,sg=0:1
        2615 TSF:MSG:FPAR OK,ID=5,D=2
        3053 TSF:MSG:READ,0-0-15,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        3057 TSF:MSG:FPAR OK,ID=0,D=1
        4105 TSM:FPAR:OK
        4106 TSM:ID
        4107 TSM:ID:OK
        4109 TSM:UPL
        4146 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
        6153 TSM:UPL
        6190 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
        8197 TSM:UPL
        8233 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
        10241 TSM:UPL
        10244 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=OK:1
        10250 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        10255 TSF:MSG:PONG RECV,HP=1
        10258 TSM:UPL:OK
        10259 TSM:READY:ID=15,PAR=0,DIS=1
        10267 TSF:MSG:SEND,15-15-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFF40016FF10300
        10311 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
        12322 TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=1,st=OK:2.1.1
        12331 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        12562 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=0:M
        12578 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Lighting
        12597 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
        12613 TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=3,pt=0,l=11,sg=0,ft=0,st=OK:Light relay
        12628 TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=6,pt=0,l=15,sg=0,ft=0,st=OK:Key temperature
        12641 TSF:MSG:SEND,15-15-0-0,s=3,c=0,t=30,pt=0,l=14,sg=0,ft=0,st=OK:Source current
        • H Offline
          H Offline
          Ok, fixed the problem. Thanks for reporting.
          • U Offline
            U Offline
            user2684
            Hi, I wonder why the following is parsed as a S_LIGHT presentation. Shouldn't be S_BINARY the type number 3? (https://www.mysensors.org/download/serial_api_20). Thanks!
            0;1;0;0;3;
            • H Offline
              H Offline
              @user2684
              Yes, it should be S_BINARAY. Thanks for reporting. Updated.
              • B Offline
                B Offline
                ben999
                I have just discovered "The Log Parser" !!!
                WOW that's huge !
                Thumbs up to those involved in that !!! Thanks a lot :)
                • raptorjrR Offline
                  raptorjrR Offline
                  raptorjr
                  The link "More details about the log messages." don't work. 404
                  • raptorjrR raptorjr
                    @raptorjr thanks for reporting. Could you describe where this link exists?
                    Edit: Found it. The link is fixed now. Thanks!
                    raptorjrR 1 Reply Last reply
                      raptorjrR Offline
                      raptorjrR Offline
                      raptorjr
                      @mfalkvidd I'm sorry. Thought it was obviuos since I posted in the comment section of the article where the link was =) But I will be more clear if I find a problem some other time.
                      Thanks for fixing the link.
                      • wesW Offline
                        wesW Offline
                        wes
                        wrote on last edited by wes
                        I think the log parser needs to be updated for new message types in MySensors v2.2.0 - they are currently being shown in the log parser as "Undefined":
                        I_SIGNAL_REPORT_REQUEST = 29,
                        I_SIGNAL_REPORT_REVERSE = 30,
                        I_SIGNAL_REPORT_RESPONSE = 31,
                        I_PRE_SLEEP_NOTIFICATION = 32,
                        I_POST_SLEEP_NOTIFICATION = 33
                        Is the source code for this parser somewhere on Github? If not, could we get it put on Github so it's easier to maintain?
                        Blog: https://www.wes.id.au/
                        Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                        Gateway & Controller: Raspberry Pi 3 + Home Assistant
                        • H Offline
                          H Offline
                          @Wes,
                          Here's a gist with the code for the log parser
                          https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                          • wesW Offline
                            wesW Offline
                            wes
                            @hek I believe this should fix the issue:
                            https://gist.github.com/liwenyip/de6ff2a646ee417fcf2629eae64e6974/revisions#diff-a83c26f29ff664a062308cb4387554c0
                            AFAIK you can't do a pull request on Github Gists.
                            Hope that helps.
                            • H Offline
                              H Offline
                              Thanks, updated.
                              • N Offline
                                N Offline
                                Hello, it seems only the two rightmost columns are filled, I have the same problem with all the browsers.
                                Example:
                                https://www.mysensors.org/build/parser?log=TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A40 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A40 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A45 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A45 TSF%3AMSG%3AACK TSF%3AMSG%3AREAD%2C0-0-255%2Cs%3D255%2Cc%3D3%2Ct%3D20%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A TSF%3AMSG%3ABC TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D21%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A0 TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A50 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A50 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A55 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A55 TSF%3AMSG%3AACK
                                • B Offline
                                  B Offline
                                  BoresExpress
                                  wrote on last edited by BoresExpress
                                  Seems like log parser incorrectly prints command types for signature messages (see picture):
                                  • G Offline
                                    G Offline
                                    gbsmith
                                    Just started MySensors 2.3 project. I have the same problem as Nca78 had 5 months again.
                                    Only the two right columns are filled. Better than nothing but not perfect as intended.
                                    And yes I tried running this code directly: https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                                    Is anyone maintaining this code?
                                    • G Offline
                                      G Offline
                                      gbsmith
                                      Clearly the debug log format has changed to something that this tool does not support.
                                      My log entries look like:
                                      228642 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      The old log entries looked like this:
                                      0;255;3;0;9;TSF:MSG:READ,12-4-0,s=18,c=1,t=16,pt=1,l=1,sg=0:1
                                      • H Offline
                                        H Offline
                                        The gist has now been updated to the lastest running on mysensors.org
                                        A 1 Reply Last reply
                                        • berkseoB Offline
                                          berkseoB Offline
                                          berkseo
                                          think it's time to add passive node support :) ||| Unknown | ?TSF:MSG:SEND... | |
                                          12.1k
