  2. Announcements
  3. 💬 Log Parser
💬 Log Parser
27 Posts 17 Posters 11.0k Views 16 Watching
  • bobbybobbybobbyB
    bobbybobbybobbyB
    bobbybobbybobby
    • Ivan ZI
      Ivan ZI
      Ivan Z
      I crash parser
      0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
      4 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSF:SID:OK,ID=15
      15 TSM:FPAR
      51 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2059 !TSM:FPAR:NO REPLY
      2061 TSM:FPAR
      2097 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2610 TSF:MSG:READ,5-5-15,s=255,c=3,t=8,pt=1,l=1,sg=0:1
      2615 TSF:MSG:FPAR OK,ID=5,D=2
      3053 TSF:MSG:READ,0-0-15,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      3057 TSF:MSG:FPAR OK,ID=0,D=1
      4105 TSM:FPAR:OK
      4106 TSM:ID
      4107 TSM:ID:OK
      4109 TSM:UPL
      4146 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
      6153 TSM:UPL
      6190 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
      8197 TSM:UPL
      8233 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
      10241 TSM:UPL
      10244 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=OK:1
      10250 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
      10255 TSF:MSG:PONG RECV,HP=1
      10258 TSM:UPL:OK
      10259 TSM:READY:ID=15,PAR=0,DIS=1
      10267 TSF:MSG:SEND,15-15-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFF40016FF10300
      10311 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
      12322 TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=1,st=OK:2.1.1
      12331 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
      12562 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=0:M
      12578 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Lighting
      12597 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
      12613 TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=3,pt=0,l=11,sg=0,ft=0,st=OK:Light relay
      12628 TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=6,pt=0,l=15,sg=0,ft=0,st=OK:Key temperature
      12641 TSF:MSG:SEND,15-15-0-0,s=3,c=0,t=30,pt=0,l=14,sg=0,ft=0,st=OK:Source current
        Ok, fixed the problem. Thanks for reporting.
        • U
          U
          user2684
          Hi, I wonder why the following is parsed as a S_LIGHT presentation. Shouldn't be S_BINARY the type number 3? (https://www.mysensors.org/download/serial_api_20). Thanks!
          0;1;0;0;3;
            @user2684
            Yes, it should be S_BINARAY. Thanks for reporting. Updated.
            • ben999B
              ben999B
              ben999
              I have just discovered "The Log Parser" !!!
              WOW that's huge !
              Thumbs up to those involved in that !!! Thanks a lot :)
              • raptorjrR
                raptorjrR
                raptorjr
                The link "More details about the log messages." don't work. 404
                • raptorjrR raptorjr
                  @raptorjr thanks for reporting. Could you describe where this link exists?
                  Edit: Found it. The link is fixed now. Thanks!
                  raptorjrR 1 Reply Last reply
                    raptorjrR
                    raptorjrR
                    raptorjr
                    @mfalkvidd I'm sorry. Thought it was obviuos since I posted in the comment section of the article where the link was =) But I will be more clear if I find a problem some other time.
                    Thanks for fixing the link.
                    • wesW
                      wesW
                      wes
                      wrote on last edited by wes
                      I think the log parser needs to be updated for new message types in MySensors v2.2.0 - they are currently being shown in the log parser as "Undefined":
                      I_SIGNAL_REPORT_REQUEST = 29,
                      I_SIGNAL_REPORT_REVERSE = 30,
                      I_SIGNAL_REPORT_RESPONSE = 31,
                      I_PRE_SLEEP_NOTIFICATION = 32,
                      I_POST_SLEEP_NOTIFICATION = 33
                      Is the source code for this parser somewhere on Github? If not, could we get it put on Github so it's easier to maintain?
                      Blog: https://www.wes.id.au/
                      Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                      Gateway & Controller: Raspberry Pi 3 + Home Assistant
                        @Wes,
                        Here's a gist with the code for the log parser
                        https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                        • wesW
                          wesW
                          wes
                          @hek I believe this should fix the issue:
                          https://gist.github.com/liwenyip/de6ff2a646ee417fcf2629eae64e6974/revisions#diff-a83c26f29ff664a062308cb4387554c0
                          AFAIK you can't do a pull request on Github Gists.
                          Hope that helps.
                            Thanks, updated.
                            • Nca78N
                              Hello, it seems only the two rightmost columns are filled, I have the same problem with all the browsers.
                              Example:
                              https://www.mysensors.org/build/parser?log=TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A40 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A40 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A45 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A45 TSF%3AMSG%3AACK TSF%3AMSG%3AREAD%2C0-0-255%2Cs%3D255%2Cc%3D3%2Ct%3D20%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A TSF%3AMSG%3ABC TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D21%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A0 TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A50 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A50 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A55 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A55 TSF%3AMSG%3AACK
                              • B
                                B
                                BoresExpress
                                wrote on last edited by BoresExpress
                                Seems like log parser incorrectly prints command types for signature messages (see picture):
                                • G
                                  G
                                  gbsmith
                                  Just started MySensors 2.3 project. I have the same problem as Nca78 had 5 months again.
                                  Only the two right columns are filled. Better than nothing but not perfect as intended.
                                  And yes I tried running this code directly: https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                                  Is anyone maintaining this code?
                                  • G
                                    G
                                    gbsmith
                                    Clearly the debug log format has changed to something that this tool does not support.
                                    My log entries look like:
                                    228642 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    The old log entries looked like this:
                                    0;255;3;0;9;TSF:MSG:READ,12-4-0,s=18,c=1,t=16,pt=1,l=1,sg=0:1
                                      The gist has now been updated to the lastest running on mysensors.org
                                      A 1 Reply Last reply
                                      • berkseoB
                                        berkseoB
                                        berkseo
                                        think it's time to add passive node support :) ||| Unknown | ?TSF:MSG:SEND... | |
                                        • W
                                          W
                                          willemx
                                          No support for Gateway Transport messages?
                                          GWT:TPS:TOPIC=mygateway1-out/19/255/3/0/21,MSG SENT
