  3. 💬 Livolo 3 buttons US/AU switch adapter
contest2017livolowall switchusaumysensorsswitch
75 Posts 12 Posters 30.8k Views 11 Watching
  • A achurak1
    @Nca78 - makes sense :) When are you going to upload the gerber files?
    @achurak1 said in 💬 Livolo 3 buttons US/AU switch adapter:
    When I can confirm all problems are solved :P
    Should not be too long I will send to Seeed tomorrow or Friday and use Fedex or DHL, their prototype PCB price is so insanely low now (4.9$ for up to 10*10cm) that from the 2nd PCB it's cheaper with them using DHL than with DirtyPCB :o
    • Nca78N
      I just posted new design files and gerber files (but please don't order now, I will receive PCBs only on Friday and then I need a few days before I can test them...
      I also put a bit of documentation but it still needs (a lot of) improvements :)
      A 1 Reply Last reply
      • Nca78N Nca78
        achurak1
        @Nca78 - Thanks for the update! Looks like shipping takes a lot of time even with the DHL delivery. Will be waiting for you to test and give us green light to order the PCBs :)
        Nca78N 1 Reply Last reply
        • A achurak1
          I took a lot of time to finish all my other PCBs before sending to Seeed.
          Then they didn't like my panelized boards (they changed rules but didn't update their website) so I lost over a day to repost.
          Then they packed the boards at the end of last week just in time to go on holidays and DHL picked them up only yesterday :(
          • Nca78N
            And now blocked at customs and I have to deal with the insane local DHL customer service again...
            Last time I waste my money with DHL :angry:
            A mtiutiuM 2 Replies Last reply
            • Nca78N Nca78
              achurak1
              @Nca78 - I ordered my PCBs (not Livolo) around the same time you did using Hongkong post and they just arrived yesterday. Never had to deal with the customs...
              • Nca78N Nca78
                mtiutiuM
                mtiutiuM
                mtiutiu
                @Nca78
                Oh man...I wanted things to come faster at my door like you did and in the end I had to pay 6 times!!! the price of the boards because of the customs, DHL fees and so on. But I learned from that and I'll NEVER EVER AGAIN go that way. That's just crazy.
                  @mtiutiu, that's crazy.
                  • mtiutiuM mtiutiu
                    @Nca78
                    @mtiutiu said in 💬 Livolo 3 buttons US/AU switch adapter:
                    @Nca78
                    I had many PCBs to order so it didn't reach those proportions: 39$ for PCBs, 30$ for shipping.
                    Then 8$ of DHL fee and 8$ of VAT.
                    That's too much shipment and customs fees for the time it took to get my order (over 2 weeks)
                    @achurak1 last time I ordered with HK Post and I had an endless wait without tracking, over 1 month, so I decided to never use it again.
                    • A achurak1
                      Soldered a few components today, I will try to finish and start testing before the end of the week.
                      • Nca78N Nca78
                        achurak1
                        @Nca78 - great! By the way, will I be able to use it with my dimmable switches (even if I lose the dimming functionality) or do I need the non-dimmable version?
                        • A achurak1
                          switches
                          I'm not sure it will work with dimmers. I bought a dimmer version to have a look and there's another MCU on the "main" board. So I will need to see how the communicate to implement that on a new version.
                          I will make the test with the dimmer version anyway, and tell you.
                          • Nca78N Nca78
                            switches
                            achurak1
                            @Nca78 - thanks! I can order the non-dimmable versions, but would prefer to avoid this if possible.
                            Is it necessary to use EIA3216 package for the tantalum capacitors or is it just something you've had handy and can be replaced with any other package (e.g. 0805 or 1206)?
                            • Nca78N
                              I used this size to have some margin to put big tantalum capacitor if necessary. But you can use smaller size and ceramic capacitors.
                              The only two that are mandatory are the radio and the input caps, other are just reserve capacitors to help the power supply. Not sure they are really necessary with nrf24 buy it would be a bit stupid to save 0.x$ and risk having an unstable board.
                              • Nca78N Nca78
                                achurak1
                                @Nca78 - great, thanks! I don't mind soldering all of them, just wasn't sure if I needed to buy the specific type/package. Is the voltage regulator (SOT23-3) only necessary if I want to encrypt the messages?
                                • A achurak1
                                  It's the ATSHA204A chip, used to sign the messages (not encrypt them). So yes if you're not planning to sign the messages you don't need to solder it. You could also use software signing but at 1MHz it could be slow, I have never tested.
                                  • Nca78N
                                    Found a bug :(
                                    Small one, one connection was not good in the schema so the resistor of the "extra" led 3 has no ground connection and the led cannot be used.
                                    Everything runs on the bench (touch buttons, other leds, output pins for relays),
                                    I need to test in the wall switch now, but I'm afraid the sensitivity for the button below the radio (1) is still not good enough.
                                    • Nca78N
                                      Not too bad ! I will still improve a bit the button at the bottom (behind the radio) because it's not perfect, but it's still usable as you can see in the video :)
                                      https://youtu.be/1LaFgjvSPj4
                                      • Nca78N Nca78
                                        achurak1
                                        @Nca78 - great news indeed! So you think it's OK to order the PCBs? Did you fix the bug with the resistor or I should add the ground connection myself before ordering the PCBs?
                                        Did you test it with the dimmable switch by the way?
                                        Nca78N 2 Replies Last reply
                                        • A achurak1
                                          I fixed but didn't publish. I'll reduce size of traces and pads of nrf24 to improve touch performance on the button below the radio. Sometimes (after long period without use) it doesn't react well and I have to use thumb to trigger it, I think because of the auto calibration of the TTP223, so I also have to test that with different caps to adjust sensitivity and see if it improves.
                                          I didn't test with dimmable switch yet, I'll try to do it on Monday.
                                          So my advice : do not order yet ;)
                                          12.5k
